[PATCH 22/26] timecounter: Load the currently selected tc once in tc_windup()
Sebastian Huber
Mon Nov 8 06:27:50 UTC 2021
Reported by: Sebastian Huber <sebastian.huber at embedded-brains.de>
Reviewed by: kib
MFC after: 1 week
Sponsored by: The FreeBSD Foundation
Differential Revision: https://reviews.freebsd.org/D32729
cpukit/score/src/kern_tc.c | 23 ++++++++++++++++-------
1 file changed, 16 insertions(+), 7 deletions(-)
diff --git a/cpukit/score/src/kern_tc.c b/cpukit/score/src/kern_tc.c
index a2e79b0b25..be3b4c2404 100644
--- a/cpukit/score/src/kern_tc.c
+++ b/cpukit/score/src/kern_tc.c
@@ -127,6 +127,13 @@ atomic_store_rel_int(Atomic_Uint *i, u_int val)
_Atomic_Store_uint(i, val, ATOMIC_ORDER_RELEASE);
+static inline void *
+atomic_load_ptr(void *ptr)
+ return ((void *)_Atomic_Load_uintptr(ptr, ATOMIC_ORDER_RELAXED));
#endif /* __rtems__ */
@@ -1576,6 +1583,7 @@ _Timecounter_Windup(struct bintime *new_boottimebin,
struct bintime bt;
+ struct timecounter *tc;
struct timehands *th, *tho;
uint32_t delta, ncount, ogen;
int i;
@@ -1610,9 +1618,10 @@ _Timecounter_Windup(struct bintime *new_boottimebin,
* changing timecounters, a counter value from the new timecounter.
* Update the offset fields accordingly.
+ tc = atomic_load_ptr(&timecounter);
delta = tc_delta(th);
- if (th->th_counter != timecounter)
- ncount = timecounter->tc_get_timecount(timecounter);
+ if (th->th_counter != tc)
+ ncount = tc->tc_get_timecount(tc);
else
ncount = 0;
#ifdef FFCLOCK
@@ -1678,20 +1687,20 @@ _Timecounter_Windup(struct bintime *new_boottimebin,
bintime2timespec(&bt, &th->th_nanotime);
/* Now is a good time to change timecounters. */
- if (th->th_counter != timecounter) {
+ if (th->th_counter != tc) {
#ifndef __rtems__
#ifndef __arm__
- if ((timecounter->tc_flags & TC_FLAGS_C2STOP) != 0)
+ if ((tc->tc_flags & TC_FLAGS_C2STOP) != 0)
cpu_disable_c2_sleep++;
if ((th->th_counter->tc_flags & TC_FLAGS_C2STOP) != 0)
cpu_disable_c2_sleep--;
#endif
- th->th_counter = timecounter;
+ th->th_counter = tc;
th->th_offset_count = ncount;
#ifndef __rtems__
- tc_min_ticktock_freq = max(1, timecounter->tc_frequency /
- (((uint64_t)timecounter->tc_counter_mask + 1) / 3));
+ tc_min_ticktock_freq = max(1, tc->tc_frequency /
+ (((uint64_t)tc->tc_counter_mask + 1) / 3));
recalculate_scaling_factor_and_large_delta(th);
#ifdef FFCLOCK
2.31.1
