[PATCH 09/26] Initialize timehands linkage much earlier.
Sebastian Huber
Mon Nov 8 06:27:37 UTC 2021
Reported and tested by: trasz
Sponsored by: The FreeBSD Foundation
MFC after: 1 week
cpukit/score/src/kern_tc.c | 34 ++++++++++++++++++++++------------
1 file changed, 22 insertions(+), 12 deletions(-)
diff --git a/cpukit/score/src/kern_tc.c b/cpukit/score/src/kern_tc.c
index 88680db2c3..28a936232b 100644
--- a/cpukit/score/src/kern_tc.c
+++ b/cpukit/score/src/kern_tc.c
@@ -262,7 +262,8 @@ SYSCTL_INT(_kern_timecounter, OID_AUTO, stepwarnings, CTLFLAG_RW,
×tepwarnings, 0, "Log time steps");
static int timehands_count = 2;
-SYSCTL_INT(_kern_timecounter, OID_AUTO, timehands_count, CTLFLAG_RDTUN,
+SYSCTL_INT(_kern_timecounter, OID_AUTO, timehands_count,
+ CTLFLAG_RDTUN | CTLFLAG_NOFETCH,
&timehands_count, 0, "Count of timehands in rotation");
struct bintime bt_timethreshold;
@@ -2259,12 +2260,30 @@ done:
return (0);
+/* Set up the requested number of timehands. */
static void
-inittimecounter(void *dummy)
+inittimehands(void *dummy)
struct timehands *thp;
+ int i;
+ TUNABLE_INT_FETCH("kern.timecounter.timehands_count",
+ &timehands_count);
+ if (timehands_count < 1)
+ timehands_count = 1;
+ if (timehands_count > nitems(ths))
+ timehands_count = nitems(ths);
+ for (i = 1, thp = &ths[0]; i < timehands_count; thp = &ths[i++])
+ thp->th_next = &ths[i];
+ thp->th_next = &ths[0];
+SYSINIT(timehands, SI_SUB_TUNABLES, SI_ORDER_ANY, inittimehands, NULL);
+static void
+inittimecounter(void *dummy)
u_int p;
- int i, tick_rate;
+ int tick_rate;
* Set the initial timeout to
@@ -2291,15 +2310,6 @@ inittimecounter(void *dummy)
ffclock_init();
#endif
- /* Set up the requested number of timehands. */
- if (timehands_count < 1)
- timehands_count = 1;
- if (timehands_count > nitems(ths))
- timehands_count = nitems(ths);
- for (i = 1, thp = &ths[0]; i < timehands_count; thp = &ths[i++])
- thp->th_next = &ths[i];
- thp->th_next = &ths[0];
/* warm up new timecounter (again) and get rolling. */
(void)timecounter->tc_get_timecount(timecounter);
2.31.1
