[PATCH 11/26] Consolidate read code for timecounters
Mon Nov 8 06:27:39 UTC 2021
and fix possible overflow in bintime()/binuptime().
The algorithm to read the consistent snapshot of current timehand is
repeated in each accessor, including the details proper rollup
detection and synchronization with the writer.  In fact there are only
two different kind of readers: one for bintime()/binuptime() which has
to do the in-place calculation, and another kind which fetches some
member from struct timehand.
Extract the logic into type-checked macros, GETTHBINTIME() for bintime
calculation, and GETTHMEMBER() for safe read of a structure' member.
This way, the synchronization is only written in bintime_off() and
getthmember().
In bintime_off(), use overflow-safe calculation of th_scale *
delta(timecounter).  In tc_windup, pre-calculate the min delta value
which overflows and require slow algorithm, into the new timehands
th_large_delta member.
This part with overflow fix was written by Bruce Evans.
Reported by:	Mark Millard <marklmi at yahoo.com> (the overflow issue)
Tested by:	pho
Discussed with:	emaste
Sponsored by:	The FreeBSD Foundation (kib)
MFC after:	3 weeks
 cpukit/score/src/kern_tc.c | 232 ++++++++++++++-----------------------
 1 file changed, 87 insertions(+), 145 deletions(-)
diff --git a/cpukit/score/src/kern_tc.c b/cpukit/score/src/kern_tc.c
index 3af77ed05a..aa7e9b0cb2 100644
--- a/cpukit/score/src/kern_tc.c
+++ b/cpukit/score/src/kern_tc.c
@@ -169,6 +169,7 @@ struct timehands {
 	struct timecounter	*th_counter;
 	int64_t			th_adjustment;
 	uint64_t		th_scale;
+	u_int			th_large_delta;
 	uint32_t	 	th_offset_count;
 	struct bintime		th_offset;
 	struct bintime		th_bintime;
@@ -189,6 +190,7 @@ static struct timehands ths[16] = {
     [0] =  {
 	.th_counter = &dummy_timecounter,
 	.th_scale = (uint64_t)-1 / 1000000,
+	.th_large_delta = 1000000,
 	.th_offset = { .sec = 1 },
 	.th_generation = 1,
@@ -359,20 +361,72 @@ tc_delta(struct timehands *th)
  * the comment in <sys/time.h> for a description of these 12 functions.
-#ifdef FFCLOCK
-void
-fbclock_binuptime(struct bintime *bt)
+static __inline void
+bintime_off(struct bintime *bt, u_int off)
 	struct timehands *th;
-	unsigned int gen;
+	struct bintime *btp;
+	uint64_t scale, x;
+	u_int delta, gen, large_delta;
 	do {
 		th = timehands;
 		gen = atomic_load_acq_int(&th->th_generation);
-		*bt = th->th_offset;
-		bintime_addx(bt, th->th_scale * tc_delta(th));
+		btp = (struct bintime *)((vm_offset_t)th + off);
+		*bt = *btp;
+		scale = th->th_scale;
+		delta = tc_delta(th);
+		large_delta = th->th_large_delta;
 		atomic_thread_fence_acq();
 	} while (gen == 0 || gen != th->th_generation);
+	if (__predict_false(delta >= large_delta)) {
+		/* Avoid overflow for scale * delta. */
+		x = (scale >> 32) * delta;
+		bt->sec += x >> 32;
+		bintime_addx(bt, x << 32);
+		bintime_addx(bt, (scale & 0xffffffff) * delta);
+	} else {
+		bintime_addx(bt, scale * delta);
+#define	GETTHBINTIME(dst, member)					\
+do {									\
+	_Static_assert(_Generic(((struct timehands *)NULL)->member,	\
+	    struct bintime: 1, default: 0) == 1,			\
+	    "struct timehands member is not of struct bintime type");	\
+	bintime_off(dst, __offsetof(struct timehands, member));		\
+} while (0)
+getthmember(void *out, size_t out_size, u_int off)
+	struct timehands *th;
+	u_int gen;
+	do {
+		th = timehands;
+		gen = atomic_load_acq_int(&th->th_generation);
+		memcpy(out, (char *)th + off, out_size);
+		atomic_thread_fence_acq();
+	} while (gen == 0 || gen != th->th_generation);
+#define	GETTHMEMBER(dst, member)					\
+do {									\
+	_Static_assert(_Generic(*dst,					\
+	    __typeof(((struct timehands *)NULL)->member): 1,		\
+	    default: 0) == 1,						\
+	    "*dst and struct timehands member have different types");	\
+	getthmember(dst, sizeof(*dst), __offsetof(struct timehands,	\
+	    member));							\
+} while (0)
+#ifdef FFCLOCK
+void
+fbclock_binuptime(struct bintime *bt)
+	GETTHBINTIME(bt, th_offset);
 void
@@ -396,16 +450,8 @@ fbclock_microuptime(struct timeval *tvp)
 void
 fbclock_bintime(struct bintime *bt)
-	struct timehands *th;
-	unsigned int gen;
-	do {
-		th = timehands;
-		gen = atomic_load_acq_int(&th->th_generation);
-		*bt = th->th_bintime;
-		atomic_thread_fence_acq();
-	} while (gen == 0 || gen != th->th_generation);
+	GETTHBINTIME(bt, th_bintime);
 void
@@ -429,100 +475,55 @@ fbclock_microtime(struct timeval *tvp)
 void
 fbclock_getbinuptime(struct bintime *bt)
-	unsigned int gen;
-	do {
-		th = timehands;
+	GETTHMEMBER(bt, th_offset);
 void
 fbclock_getnanouptime(struct timespec *tsp)
-	unsigned int gen;
+	struct bintime bt;
-	do {
-		th = timehands;
-		bintime2timespec(&th->th_offset, tsp);
+	GETTHMEMBER(&bt, th_offset);
+	bintime2timespec(&bt, tsp);
 void
 fbclock_getmicrouptime(struct timeval *tvp)
-	unsigned int gen;
-	do {
-		th = timehands;
-		bintime2timeval(&th->th_offset, tvp);
+	bintime2timeval(&bt, tvp);
 void
 fbclock_getbintime(struct bintime *bt)
-	unsigned int gen;
-	do {
-		th = timehands;
+	GETTHMEMBER(bt, th_bintime);
 void
 fbclock_getnanotime(struct timespec *tsp)
-	unsigned int gen;
-	do {
-		th = timehands;
-		*tsp = th->th_nanotime;
+	GETTHMEMBER(tsp, th_nanotime);
 void
 fbclock_getmicrotime(struct timeval *tvp)
-	unsigned int gen;
-	do {
-		th = timehands;
-		*tvp = th->th_microtime;
+	GETTHMEMBER(tvp, th_microtime);
 #else /* !FFCLOCK */
 void
-	uint32_t gen;
-	do {
-		th = timehands;
 #ifdef __rtems__
 sbintime_t
@@ -565,16 +566,8 @@ microuptime(struct timeval *tvp)
 void
-	u_int gen;
-	do {
-		th = timehands;
 void
@@ -598,85 +591,47 @@ microtime(struct timeval *tvp)
 void
-	uint32_t gen;
-	do {
-		th = timehands;
 void
-	uint32_t gen;
-	do {
-		th = timehands;
 void
-	uint32_t gen;
-	do {
-		th = timehands;
 void
-	uint32_t gen;
-	do {
-		th = timehands;
 void
-	uint32_t gen;
-	do {
-		th = timehands;
 void
-	uint32_t gen;
-	do {
-		th = timehands;
 #endif /* FFCLOCK */
@@ -692,15 +647,8 @@ getboottime(struct timeval *boottime)
 void
 getboottimebin(struct bintime *boottimebin)
-	u_int gen;
-	do {
-		th = timehands;
-		*boottimebin = th->th_boottime;
+	GETTHMEMBER(boottimebin, th_boottime);
 #ifdef FFCLOCK
@@ -1217,15 +1165,8 @@ getmicrotime(struct timeval *tvp)
 void
 dtrace_getnanotime(struct timespec *tsp)
-	uint32_t gen;
-	do {
-		th = timehands;
 #endif /* __rtems__ */
@@ -1698,6 +1639,7 @@ _Timecounter_Windup(struct bintime *new_boottimebin,
 	scale += (th->th_adjustment / 1024) * 2199;
 	scale /= th->th_counter->tc_frequency;
 	th->th_scale = scale * 2;
+	th->th_large_delta = MIN(((uint64_t)1 << 63) / scale, UINT_MAX);
 	 * Now that the struct timehands is again consistent, set the new
2.31.1
