RSB: add GRUB2 to the tools.
Karel Gardas karel.gardas at centrum.cz
Wed Nov 10 18:44:36 UTC 2021
Looks like attachments are not supported? Hence including patch inline.
>From f66de270bba2ec3496bf3e8504bb4d1e60c52f4c Mon Sep 17 00:00:00 2001
Date: Wed, 10 Nov 2021 19:27:22 +0100
Subject: [PATCH] add GRUB2 to the RSB RTEMS tools and use it in
6/rtems-x86_64
 build set
 rtems/config/6/rtems-x86_64.bset       |  5 +++
 rtems/config/tools/rtems-grub-2.06.cfg |  8 ++++
 source-builder/config/grub2.cfg        | 61 ++++++++++++++++++++++++++
 3 files changed, 74 insertions(+)
 create mode 100644 rtems/config/tools/rtems-grub-2.06.cfg
 create mode 100644 source-builder/config/grub2.cfg
diff --git a/rtems/config/6/rtems-x86_64.bset
b/rtems/config/6/rtems-x86_64.bset
index dbfc9e6..088c9f5 100644
--- a/rtems/config/6/rtems-x86_64.bset
+++ b/rtems/config/6/rtems-x86_64.bset
@@ -1,4 +1,9 @@
 %define release 1
 %define rtems_arch x86_64
 %define with_libgomp
+%define grub2_platform efi
+%define grub2_target x86_64
 %include 6/rtems-default.bset
+tools/rtems-grub-2.06
diff --git a/rtems/config/tools/rtems-grub-2.06.cfg
b/rtems/config/tools/rtems-grub-2.06.cfg
new file mode 100644
index 0000000..977e230
--- /dev/null
+++ b/rtems/config/tools/rtems-grub-2.06.cfg
@@ -0,0 +1,8 @@
+%include %{_configdir}/checks.cfg
+%include %{_configdir}/base.cfg
+%define grub2_version 2.06
+%hash sha512 grub-%{grub2_version}.tar.xz
4f11c648f3078567e53fc0c74d5026fdc6da4be27d188975e79d9a4df817ade0fe5ad2ddd694238a07edc45adfa02943d83c57767dd51548102b375e529e8efe
+%include %{_configdir}/grub2.cfg
diff --git a/source-builder/config/grub2.cfg
b/source-builder/config/grub2.cfg
index 0000000..c9b9c22
--- /dev/null
+++ b/source-builder/config/grub2.cfg
@@ -0,0 +1,61 @@
+# GNU GRUB, the GRand Unified Bootloader
+# This configuration file configure's, make's and install's GRUB2.
+%if %{release} == %{nil}
+%define release 1
+%endif
+Name:      grub2-%{grub2_version}-%{_host}-%{release}
+Summary:   GNU GRUB, the GRand Unified Bootloader v%{grub2_version} for
target %{_target} on host %{_host}
+Version:   %{grub2_version}
+Release:   %{release}
+URL: 	   https://www.gnu.org/software/grub/index.html
+# Source
+%source set grub2 https://ftp.gnu.org/gnu/grub/grub-%{grub2_version}.tar.xz
+# Prepare the source code.
+%prep
+  build_top=$(pwd)
+  %source setup grub2 -q -n grub-%{grub2_version}
+  cd ${build_top}
+%build
+  build_top=$(pwd)
+  cd grub-%{grub2_version}
+  %{host_build_flags}
+  ./configure \
+    --build=%{_build} --host=%{_host} \
+    --verbose \
+    --prefix=%{_prefix} --bindir=%{_bindir} \
+    --exec-prefix=%{_exec_prefix} \
+    --includedir=%{_includedir} --libdir=%{_libdir} \
+    --mandir=%{_mandir} --infodir=%{_infodir} \
+    --with-platform=%{grub2_platform} \
+    --target=%{grub2_target}
+  %{__make} %{?_smp_mflags} all
+  cd ${build_top}
+%install
+  build_top=$(pwd)
+  rm -rf $SB_BUILD_ROOT
+  %{__make} DESTDIR=$SB_BUILD_ROOT install
+  cd ${build_top}
2.25.1
