Building a BSP for rtems7
Fri Nov 12 13:46:45 UTC 2021
On 11/11/2021 22:31, Joel Sherrill wrote:
> On Thu, Nov 11, 2021 at 12:56 PM Sebastian Huber
> <sebastian.huber at embedded-brains.de>  wrote:
>> On 11/11/2021 17:47, Joel Sherrill wrote:
>>> Hi
>>> I was looking at the logs for building the rtems7 tools and it seems
>>> that I am missing something on the waf configure for rtems to build
>>> for rtems7. Assuming it is possible. My command was:
>>> ./waf configure --rtems-tools=/home/joel/rtems-cron-7/tools/7
>>> --rtems-bsps=sparc/leon3 --out=b-leon3
>>> --prefix=/home/joel/rtems-cron-7/tools/7/bsp-install
>>> --rtems-config=config-sparc-leon3.ini
>>> And it still tried to find sparc-rtems6-gcc.  Is there an argument i am mising?
>> Try to add
>> __RTEMS_MAJOR__ = 7
>> to the config.ini.
> That isn't in the set dumped by bsp_defaults and using it didn't
> appear to change anything.
Ok, I seem to remember a discussion about this some time ago. Options with
default: null
cannot be changed by the user. I think for the RTEMS version the reason
was that users should be forced to use the right tool chain.
We could change the RTEMS version options to
default: 6
for example.
At the moment you have to patch spec/build/cpukit/optvermaj.yml to build
with a tool chain of the wrong version.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
