Building a BSP for rtems7
Sebastian Huber
Fri Nov 12 15:26:13 UTC 2021
On 12/11/2021 16:17, Joel Sherrill wrote:
> Grrr.. the patch I posted is necessary but not sufficient. Attached is
> the config file in case something in it is wrong. I think somewhere
> else has a 6. :(
Did you add a patch like this to RTEMS:
diff --git a/spec/build/cpukit/optvermaj.yml
b/spec/build/cpukit/optvermaj.yml
index 2596e6ef6a..d01c4ff579 100644
--- a/spec/build/cpukit/optvermaj.yml
+++ b/spec/build/cpukit/optvermaj.yml
@@ -1,11 +1,11 @@
SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
actions:
-- set-value: '6'
+- get-string: null
- env-assign: null
build-type: option
copyrights:
- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
-default: null
+default: '6'
default-by-variant: []
description: ''
enabled-by: true
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
