fix compilation of dtc-1.6.0 on FreeBSD
Fri Nov 12 22:06:08 UTC 2021
Thanks for the patch. Is this fixed in dtc 1.6.1? Is there any reason
not to just bump to that?
--joel
On Thu, Nov 11, 2021 at 6:44 AM Karel Gardas <karel.gardas at centrum.cz> wrote:
> From b6ac0c3cc24bcda262936d5c2b97ebbb9efb8951 Mon Sep 17 00:00:00 2001
> From: Karel Gardas <karel at functional.vision>
> Date: Thu, 11 Nov 2021 13:39:35 +0100
> Subject: [PATCH 2/3] fix compilation of dtc-1.6.0 on FreeBSD
>  source-builder/config/dtc-1-1.cfg                    |  5 ++++-
>  source-builder/patches/dtc-1.6.0-freebsd13-fix.patch | 10 ++++++++++
>  2 files changed, 14 insertions(+), 1 deletion(-)
>  create mode 100644 source-builder/patches/dtc-1.6.0-freebsd13-fix.patch
> diff --git a/source-builder/config/dtc-1-1.cfg
> b/source-builder/config/dtc-1-1.cfg
> index 686a1e0..3c9084a 100644
> --- a/source-builder/config/dtc-1-1.cfg
> +++ b/source-builder/config/dtc-1-1.cfg
> @@ -18,6 +18,9 @@ URL:     https://www.devicetree.org/
>  # Source
>  %source set dtc
> https://www.kernel.org/pub/software/utils/dtc/dtc-%{dtc_version}.tar.gz
> +%patch add dtc file://dtc-1.6.0-freebsd13-fix.patch
> +%hash sha512 dtc-1.6.0-freebsd13-fix.patch
> 78c2d5336399bf735f16cab6349e54503f90aea0b2b8c40727769b209c6c48fa18e2bad9b6e497cab940f53585140c5ebfa413a52077fcd40db9acef0a39946c
>  # Prepare the source code.
> @@ -26,7 +29,7 @@ URL:     https://www.devicetree.org/
>    build_top=$(pwd)
>    %source setup dtc -q -n dtc-%{dtc_version}
> -  %patch setup dtc -p1
> +  %patch setup dtc -p0
>    cd ${build_top}
> diff --git a/source-builder/patches/dtc-1.6.0-freebsd13-fix.patch
> b/source-builder/patches/dtc-1.6.0-freebsd13-fix.patch
> new file mode 100644
> index 0000000..13ee731
> --- /dev/null
> +++ b/source-builder/patches/dtc-1.6.0-freebsd13-fix.patch
> @@ -0,0 +1,10 @@
> +--- Makefile.orig      2021-11-11 10:04:51.462057000 +0100
> ++++ Makefile   2021-11-11 10:04:57.933978000 +0100
> +@@ -58,6 +58,7 @@
> + ifeq ($(NO_YAML),1)
> +       CFLAGS += -DNO_YAML
> + else
> ++      CFLAGS += $(shell $(PKG_CONFIG) --cflags yaml-0.1)
> +       LDLIBS_dtc += $(shell $(PKG_CONFIG) --libs yaml-0.1)
> + endif
> 2.25.1
> devel mailing list
> devel at rtems.org
