Building a BSP for rtems7
Fri Nov 12 22:50:50 UTC 2021
On 13/11/21 9:08 am, Joel Sherrill wrote:
> On Fri, Nov 12, 2021 at 3:50 PM Chris Johns <chrisj at rtems.org> wrote:
>> On 13/11/21 12:46 am, Sebastian Huber wrote:
>>> On 11/11/2021 22:31, Joel Sherrill wrote:
>>>> On Thu, Nov 11, 2021 at 12:56 PM Sebastian Huber
>>>> <sebastian.huber at embedded-brains.de>  wrote:
>>>>> On 11/11/2021 17:47, Joel Sherrill wrote:
>>>>>> Hi
>>>>>> I was looking at the logs for building the rtems7 tools and it seems
>>>>>> that I am missing something on the waf configure for rtems to build
>>>>>> for rtems7. Assuming it is possible. My command was:
>>>>>> ./waf configure --rtems-tools=/home/joel/rtems-cron-7/tools/7
>>>>>> --rtems-bsps=sparc/leon3 --out=b-leon3
>>>>>> --prefix=/home/joel/rtems-cron-7/tools/7/bsp-install
>>>>>> --rtems-config=config-sparc-leon3.ini
>>>>>> And it still tried to find sparc-rtems6-gcc.  Is there an argument i am mising?
>>>>> Try to add
>>>>> __RTEMS_MAJOR__ = 7
>>>>> to the config.ini.
>>>> That isn't in the set dumped by bsp_defaults and using it didn't
>>>> appear to change anything.
>>> Ok, I seem to remember a discussion about this some time ago. Options with
>>> default: null
>>> cannot be changed by the user. I think for the RTEMS version the reason was that
>>> users should be forced to use the right tool chain.
>>> We could change the RTEMS version options to
>>> default: 6
>>> for example.
>>> At the moment you have to patch spec/build/cpukit/optvermaj.yml to build with a
>>> tool chain of the wrong version.
>> I think the major version is important enough and needed for development that a
>> top level waf option should be considered. I am not in favour of settings or INI
>> files because these can be archived in user projects. A user should be able to
>> move a config from 6 to 7 to 8 etc without changing it. An option can be used to
>> force the change.
> OK. Patch? :)
Please?
