[PATCH] RSB: update dtc 1.6.0 -> dtc 1.6.1
Karel Gardas
karel at functional.vision
Sat Nov 13 12:03:36 UTC 2021
Fixes #4221
Note: the patch updates only dtc 1.6.0 occurrences. It leaves all other
dtc (1.4.x) usages as they are just to not break anything which depends
on older dtc versions.
bare/config/devel/dtc-1.6.1-1.cfg | 18 ++++++++++++++++++
bare/config/devel/qemu-couverture.bset | 2 +-
rtems/config/6/rtems-default.bset | 2 +-
rtems/config/7/rtems-default.bset | 2 +-
4 files changed, 21 insertions(+), 3 deletions(-)
create mode 100644 bare/config/devel/dtc-1.6.1-1.cfg
diff --git a/bare/config/devel/dtc-1.6.1-1.cfg b/bare/config/devel/dtc-1.6.1-1.cfg
new file mode 100644
index 0000000..d711f7d
--- /dev/null
+++ b/bare/config/devel/dtc-1.6.1-1.cfg
@@ -0,0 +1,18 @@
+# DTC (Device Tree Compiler) 1.6.1
+%if %{release} == %{nil}
+%define release 1
+%endif
+%include %{_configdir}/base.cfg
+%define dtc_version 1.6.1
+%hash sha256 dtc-%{dtc_version}.tar.gz 38a6257f2c23cb9dfa1781ac4ad122d8358e1a22d33b2da0eb492c190644a376
+# The DTC build instructions. We use 1.x.x Release 1.
+%include %{_configdir}/dtc-1-1.cfg
diff --git a/bare/config/devel/qemu-couverture.bset b/bare/config/devel/qemu-couverture.bset
index fd5547c..60bec8e 100644
--- a/bare/config/devel/qemu-couverture.bset
+++ b/bare/config/devel/qemu-couverture.bset
@@ -22,5 +22,5 @@ devel/gettext-0.18.3.1-1
devel/libffi-3.0.13-1
devel/pixman-0.32.4-1
devel/glib-2.48.2-1
-devel/dtc-1.6.0-1
+devel/dtc-1.6.1-1
devel/qemu-couverture-git-1
diff --git a/rtems/config/6/rtems-default.bset b/rtems/config/6/rtems-default.bset
index 5ee1daf..e602126 100644
--- a/rtems/config/6/rtems-default.bset
+++ b/rtems/config/6/rtems-default.bset
@@ -8,7 +8,7 @@
# GDB needs expat so it needs to be built before.
-devel/dtc-1.6.0-1
+devel/dtc-1.6.1-1
devel/expat-2.1.0-1
devel/gmp-6.1.0
diff --git a/rtems/config/7/rtems-default.bset b/rtems/config/7/rtems-default.bset
index 69bdd5b..83adf89 100644
--- a/rtems/config/7/rtems-default.bset
+++ b/rtems/config/7/rtems-default.bset
@@ -5,7 +5,7 @@
-devel/dtc-1.6.0-1
+devel/dtc-1.6.1-1
devel/expat-2.1.0-1
devel/gmp-6.1.0
2.25.1
