[PATCH] waf: Add --rtems-version as a configure option
Sebastian Huber
Sun Nov 14 12:15:39 UTC 2021
On 14/11/2021 04:07, chrisj at rtems.org wrote:
> From: Chris Johns <chrisj at rtems.org>
> - Provide the option `--rtems-version` to set the major version
> number
> - Add a method to handle setting action values
> - Return the spec YAML file back to it's original values
> as it does not allow a user to change the version.
> Closes #4548
I would simply revert the optvermaj.yml patch with "git revert".
I don't like the special case approach which violates one design
principle of the build system that the wcript should know the absolute
minimum of the layout of the build specification.
My preferred solution would be that the build item defines that it can
be modified by a command line option, for example:
./waf configure --rtems-set-value=__RTEMS_MAJOR__=7
In spec/build/cpukit/optvermaj.yml:
actions:
- get-string-option: '6'
- env-assign
With this approach you don't give the user the ability to change
everything. However, what can be change is defined by the build
specification and not the wscript.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
