[PATCH 0/6] Fix rtems_task_restart() in combination with priority inheritance, etc.
Sebastian Huber
Mon Nov 15 17:08:54 UTC 2021
Consider the following scenario. Let a high priority task H wait on a priority
inheritance mutex M owned by a low priority task L. Restart task H. This should
remove the priority inherited by H from L. This is currently not the case and
the patch set fixes this.
A test for this is in the new validation test suite which will be sent for
review later.
Sebastian Huber (6):
score: Remove thread timer earlier
score: Add _Thread_MP_Extract_proxy()
score: Simplify thread wait state handling
score: Move _Thread_queue_Extract()
score: _Thread_queue_Surrender_no_priority()
score: Properly continue the thread during restart
cpukit/include/rtems/rtems/ratemonimpl.h | 3 --
cpukit/include/rtems/score/objectdata.h | 2 +-
cpukit/include/rtems/score/status.h | 2 +
cpukit/include/rtems/score/thread.h | 2 +-
cpukit/include/rtems/score/threadimpl.h | 19 +++----
cpukit/include/rtems/score/threadmp.h | 13 +++++
cpukit/include/rtems/score/threadqimpl.h | 25 +++------
cpukit/posix/src/psignalunblockthread.c | 16 ++++--
cpukit/rtems/src/eventsurrender.c | 12 ++---
cpukit/rtems/src/ratemonperiod.c | 2 +-
cpukit/rtems/src/ratemontimeout.c | 4 +-
cpukit/score/src/threadinitialize.c | 2 +-
cpukit/score/src/threadqenqueue.c | 62 +++-------------------
cpukit/score/src/threadqextract.c | 57 ++++++++++++++++++++
cpukit/score/src/threadqextractwithproxy.c | 46 ++++++++--------
cpukit/score/src/threadrestart.c | 17 ++++--
cpukit/score/src/threadtimeout.c | 8 ++-
spec/build/cpukit/librtemscpu.yml | 2 +-
spec/build/cpukit/objmpci.yml | 1 +
testsuites/sptests/spintrcritical08/init.c | 13 +----
testsuites/sptests/spintrcritical09/init.c | 2 +-
testsuites/sptests/spintrcritical10/init.c | 9 ++--
testsuites/sptests/spintrcritical22/init.c | 2 +-
23 files changed, 159 insertions(+), 162 deletions(-)
create mode 100644 cpukit/score/src/threadqextract.c
2.26.2
