[PATCH 02/27] score: Add red-black tree append/prepend
Mon Nov 15 17:12:34 UTC 2021
These functions are a faster alternative to _RBTree_Insert_inline() if
it is known that the new node is the maximum/minimum node.
Update #4531.
 cpukit/include/rtems/score/rbtreeimpl.h | 26 +++++++++++
 cpukit/score/src/rbtreeappend.c         | 58 +++++++++++++++++++++++++
 cpukit/score/src/rbtreeprepend.c        | 58 +++++++++++++++++++++++++
 spec/build/cpukit/librtemscpu.yml       |  2 +
 4 files changed, 144 insertions(+)
 create mode 100644 cpukit/score/src/rbtreeappend.c
 create mode 100644 cpukit/score/src/rbtreeprepend.c
diff --git a/cpukit/include/rtems/score/rbtreeimpl.h b/cpukit/include/rtems/score/rbtreeimpl.h
index 597c24d771..0867240d59 100644
--- a/cpukit/include/rtems/score/rbtreeimpl.h
+++ b/cpukit/include/rtems/score/rbtreeimpl.h
@@ -30,6 +30,32 @@ extern "C" {
+ * @brief Appends the node to the red-black tree.
+ * The appended node is the new maximum node of the tree.  The caller shall
+ * ensure that the appended node is indeed the maximum node with respect to the
+ * tree order.
+ * @param[in, out] the_rbtree is the red-black tree control.
+ * @param the_node[out] is the node to append.
+void _RBTree_Append( RBTree_Control *the_rbtree, RBTree_Node *the_node );
+ * @brief Prepends the node to the red-black tree.
+ * The prepended node is the new minimum node of the tree.  The caller shall
+ * ensure that the prepended node is indeed the minimum node with respect to the
+ * tree order.
+ * @param the_node[out] is the node to prepend.
+void _RBTree_Prepend( RBTree_Control *the_rbtree, RBTree_Node *the_node );
  * @brief Red-black tree visitor.
diff --git a/cpukit/score/src/rbtreeappend.c b/cpukit/score/src/rbtreeappend.c
new file mode 100644
index 0000000000..e36f6bc805
--- /dev/null
+++ b/cpukit/score/src/rbtreeappend.c
@@ -0,0 +1,58 @@
+ * @file
+ * @ingroup RTEMSScoreRBTree
+ * @brief This source file contains the implementation of
+ *   _RBTree_Append().
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/rbtreeimpl.h>
+  RBTree_Node **link;
+  RBTree_Node  *parent;
+  link = _RBTree_Root_reference( the_rbtree );
+  parent = NULL;
+  while ( *link != NULL ) {
+    parent = *link;
+    link = _RBTree_Right_reference( parent );
+  _RBTree_Add_child( the_node, parent, link );
+  _RBTree_Insert_color( the_rbtree, the_node );
diff --git a/cpukit/score/src/rbtreeprepend.c b/cpukit/score/src/rbtreeprepend.c
index 0000000000..f154f51d36
--- /dev/null
+++ b/cpukit/score/src/rbtreeprepend.c
@@ -0,0 +1,58 @@
+ * @file
+ *   _RBTree_Prepend().
+ * are met:
+#endif
+  parent = NULL;
+    parent = *link;
+    link = _RBTree_Left_reference( parent );
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 063917b410..819c479191 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -1475,6 +1475,7 @@ source:
 - cpukit/score/src/pheapwalk.c
 - cpukit/score/src/processormaskcopy.c
 - cpukit/score/src/profilingisrentryexit.c
+- cpukit/score/src/rbtreeappend.c
 - cpukit/score/src/rbtreeextract.c
 - cpukit/score/src/rbtreeinsert.c
 - cpukit/score/src/rbtreeiterate.c
@@ -1482,6 +1483,7 @@ source:
 - cpukit/score/src/rbtreemin.c
 - cpukit/score/src/rbtreenext.c
 - cpukit/score/src/rbtreepostorder.c
+- cpukit/score/src/rbtreeprepend.c
 - cpukit/score/src/rbtreeprev.c
 - cpukit/score/src/rbtreereplace.c
 - cpukit/score/src/sched.c
2.26.2
