[PATCH] config: CONFIGURE_DISABLE_BSP_SETTINGS
Sebastian Huber
Mon Nov 15 18:18:38 UTC 2021
Evaluate CONFIGURE_DISABLE_BSP_SETTINGS for each affected application
configuration option. This makes the code easier to review since the influence
of CONFIGURE_DISABLE_BSP_SETTINGS is locally visible in the code.
cpukit/include/rtems/confdefs/bsp.h | 15 ++-------------
cpukit/include/rtems/confdefs/extensions.h | 3 ++-
cpukit/include/rtems/confdefs/iodrivers.h | 3 ++-
cpukit/include/rtems/confdefs/malloc.h | 10 +++++++---
cpukit/include/rtems/confdefs/percpu.h | 9 ++++++---
5 files changed, 19 insertions(+), 21 deletions(-)
diff --git a/cpukit/include/rtems/confdefs/bsp.h b/cpukit/include/rtems/confdefs/bsp.h
index 03ad9bf55f..bc96713765 100644
--- a/cpukit/include/rtems/confdefs/bsp.h
+++ b/cpukit/include/rtems/confdefs/bsp.h
@@ -41,19 +41,8 @@
#error "Do not include this file directly, use <rtems/confdefs.h> instead"
#endif
-#ifdef CONFIGURE_INIT
-#ifdef CONFIGURE_DISABLE_BSP_SETTINGS
- #undef BSP_IDLE_TASK_BODY
- #undef BSP_IDLE_TASK_STACK_SIZE
- #undef BSP_INITIAL_EXTENSION
- #undef BSP_INTERRUPT_STACK_SIZE
- #undef CONFIGURE_BSP_PREREQUISITE_DRIVERS
- #undef CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
-#else
- #include <bsp.h>
+#if defined(CONFIGURE_INIT) && !defined(CONFIGURE_DISABLE_BSP_SETTINGS)
+#include <bsp.h>
#endif
-#endif /* CONFIGURE_INIT */
#endif /* _RTEMS_CONFDEFS_BSP_H */
diff --git a/cpukit/include/rtems/confdefs/extensions.h b/cpukit/include/rtems/confdefs/extensions.h
index 6492407934..118ad29484 100644
--- a/cpukit/include/rtems/confdefs/extensions.h
+++ b/cpukit/include/rtems/confdefs/extensions.h
@@ -146,7 +146,8 @@ extern "C" {
#ifdef CONFIGURE_INITIAL_EXTENSIONS
CONFIGURE_INITIAL_EXTENSIONS,
#endif
- #ifdef BSP_INITIAL_EXTENSION
+ #if !defined(CONFIGURE_DISABLE_BSP_SETTINGS) && \
+ defined(BSP_INITIAL_EXTENSION)
#endif
diff --git a/cpukit/include/rtems/confdefs/iodrivers.h b/cpukit/include/rtems/confdefs/iodrivers.h
index a7de77a8c3..8c102197eb 100644
--- a/cpukit/include/rtems/confdefs/iodrivers.h
+++ b/cpukit/include/rtems/confdefs/iodrivers.h
@@ -110,7 +110,8 @@ extern "C" {
rtems_driver_address_table
_IO_Driver_address_table[ CONFIGURE_MAXIMUM_DRIVERS ] = {
- #ifdef CONFIGURE_BSP_PREREQUISITE_DRIVERS
+ defined(CONFIGURE_BSP_PREREQUISITE_DRIVERS)
CONFIGURE_BSP_PREREQUISITE_DRIVERS,
#endif
#ifdef CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
diff --git a/cpukit/include/rtems/confdefs/malloc.h b/cpukit/include/rtems/confdefs/malloc.h
index d864a98270..a8dae6e739 100644
--- a/cpukit/include/rtems/confdefs/malloc.h
+++ b/cpukit/include/rtems/confdefs/malloc.h
@@ -45,8 +45,12 @@
#include <rtems/confdefs/bsp.h>
-#if defined(CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK) \
- || defined(CONFIGURE_MALLOC_DIRTY)
+#if !defined(CONFIGURE_DISABLE_BSP_SETTINGS) && \
+ defined(CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK)
+#define _CONFIGURE_HEAP_EXTEND_VIA_SBRK
+#endif
+#if defined(_CONFIGURE_HEAP_EXTEND_VIA_SBRK) || defined(CONFIGURE_MALLOC_DIRTY)
#include <rtems/malloc.h>
#endif
@@ -54,7 +58,7 @@
extern "C" {
#endif
-#ifdef CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
+#ifdef _CONFIGURE_HEAP_EXTEND_VIA_SBRK
const rtems_heap_extend_handler rtems_malloc_extend_handler =
rtems_heap_extend_via_sbrk;
#endif
diff --git a/cpukit/include/rtems/confdefs/percpu.h b/cpukit/include/rtems/confdefs/percpu.h
index 3bea8340cb..b91590bfd9 100644
--- a/cpukit/include/rtems/confdefs/percpu.h
+++ b/cpukit/include/rtems/confdefs/percpu.h
@@ -78,7 +78,8 @@ extern "C" {
/* Interrupt stack configuration */
#ifndef CONFIGURE_INTERRUPT_STACK_SIZE
- #ifdef BSP_INTERRUPT_STACK_SIZE
+ defined(BSP_INTERRUPT_STACK_SIZE)
#define CONFIGURE_INTERRUPT_STACK_SIZE BSP_INTERRUPT_STACK_SIZE
#else
#define CONFIGURE_INTERRUPT_STACK_SIZE CPU_STACK_MINIMUM_SIZE
@@ -121,7 +122,8 @@ RTEMS_DEFINE_GLOBAL_SYMBOL(
/* Idle thread configuration */
#ifndef CONFIGURE_IDLE_TASK_STACK_SIZE
- #ifdef BSP_IDLE_TASK_STACK_SIZE
+ defined(BSP_IDLE_TASK_STACK_SIZE)
#define CONFIGURE_IDLE_TASK_STACK_SIZE BSP_IDLE_TASK_STACK_SIZE
#else
#define CONFIGURE_IDLE_TASK_STACK_SIZE CONFIGURE_MINIMUM_TASK_STACK_SIZE
@@ -153,7 +155,8 @@ const size_t _Thread_Idle_stack_size = CONFIGURE_IDLE_TASK_STACK_SIZE;
#error "If you define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION, then you must define CONFIGURE_IDLE_TASK_BODY as well"
#endif
-#if !defined(CONFIGURE_IDLE_TASK_BODY) && defined(BSP_IDLE_TASK_BODY)
+#if !defined(CONFIGURE_IDLE_TASK_BODY) && \
+ !defined(CONFIGURE_DISABLE_BSP_SETTINGS) && defined(BSP_IDLE_TASK_BODY)
#define CONFIGURE_IDLE_TASK_BODY BSP_IDLE_TASK_BODY
#endif
2.26.2
