[PATCH] c-user: Use rubric for configuration options
Tue Nov 16 07:27:44 UTC 2021
Use a rubric instead of a definition list for the application
configuration options similar to the directive documentation pages.  For
direcives and application configuration options use the same rubric
order.
Generalize value constraints to constraints.
This patch does not change hand written content.
The generated PDF can be reviewed here:
https://ftp.rtems.org/pub/rtems/people/sebh/c-user.pdf
 c-user/config/bdbuf.rst             |  457 +++++------
 c-user/config/bsp-related.rst       |  304 ++++----
 c-user/config/classic-api.rst       |  676 ++++++++--------
 c-user/config/classic-init-task.rst |  355 +++++----
 c-user/config/device-driver.rst     |  792 ++++++++++---------
 c-user/config/event-record.rst      |  160 ++--
 c-user/config/filesystem.rst        |  844 ++++++++++----------
 c-user/config/general.rst           | 1103 +++++++++++++++------------
 c-user/config/idle-task.rst         |  147 ++--
 c-user/config/mpci.rst              |  315 ++++----
 c-user/config/posix-api.rst         |  539 +++++++------
 c-user/config/posix-init-thread.rst |  115 +--
 c-user/config/scheduler-general.rst |  669 ++++++++--------
 c-user/config/task-stack-alloc.rst  |  244 +++---
 14 files changed, 3691 insertions(+), 3029 deletions(-)
diff --git a/c-user/config/bdbuf.rst b/c-user/config/bdbuf.rst
index c5381e1..d36c2bd 100644
--- a/c-user/config/bdbuf.rst
+++ b/c-user/config/bdbuf.rst
@@ -35,24 +35,29 @@ This section describes configuration options related to the Block Device Cache
 CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
-CONSTANT:
-    ``CONFIGURE_APPLICATION_NEEDS_LIBBLOCK``
+.. rubric:: CONSTANT:
-OPTION TYPE:
-    This configuration option is a boolean feature define.
+``CONFIGURE_APPLICATION_NEEDS_LIBBLOCK``
-DEFAULT CONFIGURATION:
-    If this configuration option is undefined, then the described feature is not
-    enabled.
+.. rubric:: OPTION TYPE:
-DESCRIPTION:
-    In case this configuration option is defined, then the Block Device Cache is
-    initialized during system initialization.
+This configuration option is a boolean feature define.
-NOTES:
-    Each option of the Block Device Cache (bdbuf) configuration can be explicitly
-    set by the user with the configuration options below.  The Block Device Cache
-    is used for example by the RFS and DOSFS filesystems.
+.. rubric:: DEFAULT CONFIGURATION:
+If this configuration option is undefined, then the described feature is not
+enabled.
+.. rubric:: DESCRIPTION:
+In case this configuration option is defined, then the Block Device Cache is
+initialized during system initialization.
+.. rubric:: NOTES:
+Each option of the Block Device Cache (bdbuf) configuration can be explicitly
+set by the user with the configuration options below.  The Block Device Cache
+is used for example by the RFS and DOSFS filesystems.
 .. Generated from spec:/acfg/if/bdbuf-buffer-max-size
@@ -63,30 +68,31 @@ NOTES:
 CONFIGURE_BDBUF_BUFFER_MAX_SIZE
-CONSTANT:
-    ``CONFIGURE_BDBUF_BUFFER_MAX_SIZE``
+``CONFIGURE_BDBUF_BUFFER_MAX_SIZE``
-OPTION TYPE:
-    This configuration option is an integer define.
+This configuration option is an integer define.
-DEFAULT VALUE:
-    The default value is 4096.
+.. rubric:: DEFAULT VALUE:
-VALUE CONSTRAINTS:
-    The value of this configuration option shall satisfy all of the following
-    constraints:
+The default value is 4096.
-    * It shall be greater than or equal to zero.
-    * It shall be an integral multiple of
-      :ref:`CONFIGURE_BDBUF_BUFFER_MIN_SIZE`.
+The value of this configuration option defines the maximum size of a buffer
+in bytes.
-DESCRIPTION:
-    The value of this configuration option defines the maximum size of a buffer
-    in bytes.
+.. rubric:: CONSTRAINTS:
-NOTES:
-    None.
+The following constraints apply to this configuration option:
+* The value of the configuration option shall be greater than or equal to zero.
+* The value of the configuration option shall be an integral multiple of
+  :ref:`CONFIGURE_BDBUF_BUFFER_MIN_SIZE`.
 .. Generated from spec:/acfg/if/bdbuf-buffer-min-size
@@ -97,30 +103,31 @@ NOTES:
-CONSTANT:
-    ``CONFIGURE_BDBUF_BUFFER_MIN_SIZE``
+``CONFIGURE_BDBUF_BUFFER_MIN_SIZE``
-OPTION TYPE:
-DEFAULT VALUE:
-    The default value is 512.
-VALUE CONSTRAINTS:
-    constraints:
+The default value is 512.
-    * It shall be less than or equal to `UINT32_MAX
-      <https://en.cppreference.com/w/c/types/integer>`_.
+The value of this configuration option defines the minimum size of a buffer
+in bytes.
-DESCRIPTION:
-    The value of this configuration option defines the minimum size of a buffer
-    in bytes.
-NOTES:
-    None.
+* The value of the configuration option shall be less than or equal to
+  `UINT32_MAX <https://en.cppreference.com/w/c/types/integer>`_.
 .. Generated from spec:/acfg/if/bdbuf-cache-memory-size
@@ -131,30 +138,31 @@ NOTES:
 CONFIGURE_BDBUF_CACHE_MEMORY_SIZE
-CONSTANT:
-    ``CONFIGURE_BDBUF_CACHE_MEMORY_SIZE``
+``CONFIGURE_BDBUF_CACHE_MEMORY_SIZE``
-OPTION TYPE:
-DEFAULT VALUE:
-    The default value is 32768.
-VALUE CONSTRAINTS:
-    constraints:
+The default value is 32768.
-    * It shall be less than or equal to `SIZE_MAX
-      <https://en.cppreference.com/w/c/types/limits>`_.
-DESCRIPTION:
-    The value of this configuration option defines the size of the cache memory
-    in bytes.
+The value of this configuration option defines the size of the cache memory
+in bytes.
-NOTES:
-    None.
+  `SIZE_MAX <https://en.cppreference.com/w/c/types/limits>`_.
 .. Generated from spec:/acfg/if/bdbuf-max-read-ahead-blocks
@@ -165,32 +173,37 @@ NOTES:
 CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS
-CONSTANT:
-    ``CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS``
+``CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS``
-OPTION TYPE:
+The default value is 0.
-DEFAULT VALUE:
-    The default value is 0.
-VALUE CONSTRAINTS:
-    constraints:
+The value of this configuration option defines the maximum blocks per
+read-ahead request.
+.. rubric:: NOTES:
+A value of 0 disables the read-ahead task (default).  The read-ahead task
+will issue speculative read transfers if a sequential access pattern is
+detected.  This can improve the performance on some systems.
-DESCRIPTION:
-    The value of this configuration option defines the maximum blocks per
-    read-ahead request.
-NOTES:
-    A value of 0 disables the read-ahead task (default).  The read-ahead task
-    will issue speculative read transfers if a sequential access pattern is
-    detected.  This can improve the performance on some systems.
 .. Generated from spec:/acfg/if/bdbuf-max-write-blocks
@@ -201,30 +214,31 @@ NOTES:
 CONFIGURE_BDBUF_MAX_WRITE_BLOCKS
-CONSTANT:
-    ``CONFIGURE_BDBUF_MAX_WRITE_BLOCKS``
+``CONFIGURE_BDBUF_MAX_WRITE_BLOCKS``
-OPTION TYPE:
-DEFAULT VALUE:
-    The default value is 16.
-VALUE CONSTRAINTS:
-    constraints:
+The default value is 16.
+The value of this configuration option defines the maximum blocks per write
+request.
-DESCRIPTION:
-    The value of this configuration option defines the maximum blocks per write
-    request.
-NOTES:
-    None.
 .. Generated from spec:/acfg/if/bdbuf-read-ahead-task-priority
@@ -235,25 +249,27 @@ NOTES:
 CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY
-CONSTANT:
-    ``CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY``
+``CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY``
-OPTION TYPE:
-DEFAULT VALUE:
-    The default value is 15.
-VALUE CONSTRAINTS:
-    The value of this configuration option shall be a valid Classic API task
-    priority.  The set of valid task priorities depends on the scheduler
-    configuration.
-DESCRIPTION:
-    The value of this configuration option defines the read-ahead task priority.
+The default value is 15.
-NOTES:
-    None.
+The value of this configuration option defines the read-ahead task priority.
+The value of the configuration option shall be a valid Classic API task
+priority.  The set of valid task priorities depends on the scheduler
+configuration.
 .. Generated from spec:/acfg/if/bdbuf-task-stack-size
@@ -264,36 +280,38 @@ NOTES:
 CONFIGURE_BDBUF_TASK_STACK_SIZE
-CONSTANT:
-    ``CONFIGURE_BDBUF_TASK_STACK_SIZE``
+``CONFIGURE_BDBUF_TASK_STACK_SIZE``
-OPTION TYPE:
+The default value is :c:macro:`RTEMS_MINIMUM_STACK_SIZE`.
-DEFAULT VALUE:
-    The default value is :c:macro:`RTEMS_MINIMUM_STACK_SIZE`.
-VALUE CONSTRAINTS:
-    constraints:
+The value of this configuration option defines the task stack size of the
+Block Device Cache tasks in bytes.
-      :ref:`CONFIGURE_MINIMUM_TASK_STACK_SIZE`.
-    * It shall be less than or equal to a BSP-specific and application-specific
-      value which depends on the size of the memory available to the
-      application.
-    * It shall be small enough so that the task stack space calculation carried
-      out by ``<rtems/confdefs.h>`` does not overflow an integer of type
-      `uintptr_t <https://en.cppreference.com/w/c/types/integer>`_.
+  :ref:`CONFIGURE_MINIMUM_TASK_STACK_SIZE`.
-DESCRIPTION:
-    The value of this configuration option defines the task stack size of the
-    Block Device Cache tasks in bytes.
+* The value of the configuration option shall be less than or equal to a
+  BSP-specific and application-specific value which depends on the size of the
+  memory available to the application.
-NOTES:
-    None.
+* The value of the configuration option shall be small enough so that the task
+  stack space calculation carried out by ``<rtems/confdefs.h>`` does not
+  overflow an integer of type `uintptr_t
+  <https://en.cppreference.com/w/c/types/integer>`_.
 .. Generated from spec:/acfg/if/bdbuf-swapout-block-hold
@@ -304,30 +322,31 @@ NOTES:
 CONFIGURE_SWAPOUT_BLOCK_HOLD
-CONSTANT:
-    ``CONFIGURE_SWAPOUT_BLOCK_HOLD``
-OPTION TYPE:
+``CONFIGURE_SWAPOUT_BLOCK_HOLD``
-DEFAULT VALUE:
-    The default value is 1000.
-VALUE CONSTRAINTS:
-    constraints:
+The default value is 1000.
-DESCRIPTION:
-    The value of this configuration option defines the swapout task maximum block
-    hold time in milliseconds.
-NOTES:
-    None.
+The value of this configuration option defines the swapout task maximum block
+hold time in milliseconds.
 .. Generated from spec:/acfg/if/bdbuf-swapout-swap-period
@@ -338,30 +357,31 @@ NOTES:
 CONFIGURE_SWAPOUT_SWAP_PERIOD
-CONSTANT:
-    ``CONFIGURE_SWAPOUT_SWAP_PERIOD``
+``CONFIGURE_SWAPOUT_SWAP_PERIOD``
-OPTION TYPE:
-DEFAULT VALUE:
-    The default value is 250.
+The default value is 250.
-VALUE CONSTRAINTS:
-    constraints:
+The value of this configuration option defines the swapout task swap period
+in milliseconds.
-DESCRIPTION:
-    The value of this configuration option defines the swapout task swap period
-    in milliseconds.
-NOTES:
-    None.
 .. Generated from spec:/acfg/if/bdbuf-swapout-task-priority
@@ -372,25 +392,27 @@ NOTES:
 CONFIGURE_SWAPOUT_TASK_PRIORITY
-CONSTANT:
-    ``CONFIGURE_SWAPOUT_TASK_PRIORITY``
+``CONFIGURE_SWAPOUT_TASK_PRIORITY``
-OPTION TYPE:
-DEFAULT VALUE:
-VALUE CONSTRAINTS:
-    configuration.
-DESCRIPTION:
-    The value of this configuration option defines the swapout task priority.
+The value of this configuration option defines the swapout task priority.
-NOTES:
-    None.
+configuration.
 .. Generated from spec:/acfg/if/bdbuf-swapout-worker-tasks
@@ -401,29 +423,30 @@ NOTES:
 CONFIGURE_SWAPOUT_WORKER_TASKS
-CONSTANT:
-    ``CONFIGURE_SWAPOUT_WORKER_TASKS``
+``CONFIGURE_SWAPOUT_WORKER_TASKS``
-OPTION TYPE:
-DEFAULT VALUE:
-VALUE CONSTRAINTS:
-    constraints:
+The value of this configuration option defines the swapout worker task count.
-DESCRIPTION:
-    The value of this configuration option defines the swapout worker task count.
-NOTES:
-    None.
 .. Generated from spec:/acfg/if/bdbuf-swapout-worker-taskp-riority
@@ -434,23 +457,25 @@ NOTES:
 CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY
-CONSTANT:
-    ``CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY``
+``CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY``
-OPTION TYPE:
-DEFAULT VALUE:
-VALUE CONSTRAINTS:
-    configuration.
+priority.
-DESCRIPTION:
-    priority.
-NOTES:
-    None.
+configuration.
[ the remaining patch was removed due to the mailing list size limit ]
