[PATCH 21/27] timecounter: Lock the timecounter list
Moyano, Gabriel gabriel.moyano at dlr.de
Wed Nov 17 07:50:33 UTC 2021
Timecounter registration is dynamic, i.e., there is no requirement that
timecounters must be registered during single-threaded boot.  Loadable
drivers may in principle register timecounters (which can be switched to
automatically).  Timecounters cannot be unregistered, though this could
be implemented.
Registered timecounters belong to a global linked list.  Add a mutex to
synchronize insertions and the traversals done by (mpsafe) sysctl
handlers.  No functional change intended.
Reviewed by:	imp, kib
MFC after:	2 weeks
Sponsored by:	The FreeBSD Foundation
Differential Revision:	https://reviews.freebsd.org/D32511
 cpukit/score/src/kern_tc.c | 40 ++++++++++++++++++++++++++++----------
 1 file changed, 30 insertions(+), 10 deletions(-)
diff --git a/cpukit/score/src/kern_tc.c b/cpukit/score/src/kern_tc.c
index 2b131bb423..a2bf056e3a 100644
--- a/cpukit/score/src/kern_tc.c
+++ b/cpukit/score/src/kern_tc.c
@@ -182,6 +182,10 @@ static struct timehands *volatile timehands = &ths[0];
 struct timecounter *timecounter = &dummy_timecounter;
 static struct timecounter *timecounters = &dummy_timecounter;
+/* Mutex to protect the timecounter list. */
+static struct mtx tc_lock;
+MTX_SYSINIT(tc_lock, &tc_lock, "tc", MTX_DEF);
 int tc_min_ticktock_freq = 1;
 #else /* __rtems__ */
@@ -1356,8 +1360,6 @@ tc_init(struct timecounter *tc)
 		    tc->tc_quality);
-	tc->tc_next = timecounters;
-	timecounters = tc;
 	 * Set up sysctl tree for this counter.
@@ -1379,6 +1381,11 @@ tc_init(struct timecounter *tc)
 	SYSCTL_ADD_INT(NULL, SYSCTL_CHILDREN(tc_root), OID_AUTO,
 	    "quality", CTLFLAG_RD, &(tc->tc_quality), 0,
 	    "goodness of time counter");
+	mtx_lock(&tc_lock);
+	tc->tc_next = timecounters;
+	timecounters = tc;
 	 * Do not automatically switch if the current tc was specifically
 	 * chosen.  Never automatically use a timecounter with negative quality.
@@ -1386,22 +1393,24 @@ tc_init(struct timecounter *tc)
 	 * worse since this timecounter may not be monotonic.
 	if (tc_chosen)
-		return;
+		goto unlock;
 	if (tc->tc_quality < 0)
-		return;
+		goto unlock;
 	if (tc_from_tunable[0] != '\0' &&
 	    strcmp(tc->tc_name, tc_from_tunable) == 0) {
 		tc_chosen = 1;
 		tc_from_tunable[0] = '\0';
 	} else {
 		if (tc->tc_quality < timecounter->tc_quality)
-			return;
+			goto unlock;
 		if (tc->tc_quality == timecounter->tc_quality &&
 		    tc->tc_frequency < timecounter->tc_frequency)
-			return;
+			goto unlock;
 	(void)tc->tc_get_timecount(tc);
 	timecounter = tc;
+unlock:
+	mtx_unlock(&tc_lock);
 		return;
@@ -1705,16 +1714,22 @@ sysctl_kern_timecounter_hardware(SYSCTL_HANDLER_ARGS)
 	struct timecounter *newtc, *tc;
 	int error;
 	tc = timecounter;
 	strlcpy(newname, tc->tc_name, sizeof(newname));
 	error = sysctl_handle_string(oidp, &newname[0], sizeof(newname), req);
 	if (error != 0 || req->newptr == NULL)
 		return (error);
 	/* Record that the tc in use now was specifically chosen. */
 	tc_chosen = 1;
-	if (strcmp(newname, tc->tc_name) == 0)
+	if (strcmp(newname, tc->tc_name) == 0) {
 		return (0);
 	for (newtc = timecounters; newtc != NULL; newtc = newtc->tc_next) {
 		if (strcmp(newname, newtc->tc_name) != 0)
 			continue;
@@ -1732,11 +1747,11 @@ sysctl_kern_timecounter_hardware(SYSCTL_HANDLER_ARGS)
 		 * use any locking and that it can be called in hard interrupt
 		 * context via 'tc_windup()'.
-		return (0);
+		break;
-	return (EINVAL);
+	return (newtc != NULL ? 0 : EINVAL);
 SYSCTL_PROC(_kern_timecounter, OID_AUTO, hardware,
     CTLTYPE_STRING | CTLFLAG_RWTUN | CTLFLAG_NOFETCH | CTLFLAG_MPSAFE, 0, 0,
     sysctl_kern_timecounter_hardware, "A",
@@ -1750,12 +1765,17 @@ sysctl_kern_timecounter_choice(SYSCTL_HANDLER_ARGS)
 	struct timecounter *tc;
 	int error;
+	error = sysctl_wire_old_buffer(req, 0);
+	if (error != 0)
+		return (error);
 	sbuf_new_for_sysctl(&sb, NULL, 0, req);
 	for (tc = timecounters; tc != NULL; tc = tc->tc_next) {
 		if (tc != timecounters)
 			sbuf_putc(&sb, ' ');
 		sbuf_printf(&sb, "%s(%d)", tc->tc_name, tc->tc_quality);
 	error = sbuf_finish(&sb);
 	sbuf_delete(&sb);
 	return (error);
2.17.1
