[PATCH 27/27] score: Add _Timecounter_Set_NTP_update_second()
Moyano, Gabriel
gabriel.moyano at dlr.de
Wed Nov 17 07:50:39 UTC 2021
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
Allow the installation of an NTP update second handler which may be used by an
NTP service.
Update #4549.
cpukit/include/rtems/score/timecounter.h | 24 +++++++++++++++++++++++-
cpukit/score/src/kern_tc.c | 23 +++++++++++++++++++++--
2 files changed, 44 insertions(+), 3 deletions(-)
diff --git a/cpukit/include/rtems/score/timecounter.h b/cpukit/include/rtems/score/timecounter.h
index b71ccd3948..64429eae7b 100644
--- a/cpukit/include/rtems/score/timecounter.h
+++ b/cpukit/include/rtems/score/timecounter.h
@@ -7,7 +7,7 @@
- * Copyright (c) 2015 embedded brains GmbH. All rights reserved.
+ * Copyright (c) 2015, 2021 embedded brains GmbH. All rights reserved.
* embedded brains GmbH
* Dornierstr. 4
@@ -247,6 +247,28 @@ extern volatile int32_t _Timecounter_Time_uptime;
extern struct timecounter *_Timecounter;
+ * @brief Handler doing the NTP update second processing shall have this type.
+ * @param[in, out] adjustment is the NTP time adjustment.
+ * @param[in, out] newsec is the number of seconds since Unix epoch.
+typedef void ( *Timecounter_NTP_update_second )(
+ int64_t *adjustment,
+ time_t *newsec
+ * @brief Sets the NTP update second handler.
+ * @param handler is the new NTP update second handler used to carry out the
+ * NTP update second processing.
+void _Timecounter_Set_NTP_update_second(
+ Timecounter_NTP_update_second handler
#ifdef __cplusplus
diff --git a/cpukit/score/src/kern_tc.c b/cpukit/score/src/kern_tc.c
index 1161463a0e..56ec4751ce 100644
--- a/cpukit/score/src/kern_tc.c
+++ b/cpukit/score/src/kern_tc.c
@@ -80,8 +80,6 @@ ISR_LOCK_DEFINE(, _Timecounter_Lock, "Timecounter")
#define hz rtems_clock_get_ticks_per_second()
#define printf(...)
#define log(...)
-/* FIXME: https://devel.rtems.org/ticket/2348 */
-#define ntp_update_second(a, b) do { (void) a; (void) b; } while (0)
static inline void
atomic_thread_fence_acq(void)
@@ -117,6 +115,17 @@ atomic_load_ptr(void *ptr)
return ((void *)_Atomic_Load_uintptr(ptr, ATOMIC_ORDER_RELAXED));
+static Timecounter_NTP_update_second _Timecounter_NTP_update_second;
+void
+_Timecounter_Set_NTP_update_second(Timecounter_NTP_update_second handler)
+ _Timecounter_NTP_update_second = handler;
+#define ntp_update_second(a, b) (*ntp_update_second_handler)(a, b)
#endif /* __rtems__ */
@@ -1605,6 +1614,9 @@ _Timecounter_Windup(struct bintime *new_boottimebin,
#endif
int i;
time_t t;
+#ifdef __rtems__
+ Timecounter_NTP_update_second ntp_update_second_handler;
+#endif
* Make the next timehands a copy of the current one, but do
@@ -1680,6 +1692,10 @@ _Timecounter_Windup(struct bintime *new_boottimebin,
bt = th->th_offset;
bintime_add(&bt, &th->th_boottime);
+#ifdef __rtems__
+ ntp_update_second_handler = _Timecounter_NTP_update_second;
+ if (ntp_update_second_handler != NULL) {
+#endif /* __rtems__ */
i = bt.sec - tho->th_microtime.tv_sec;
if (i > 0) {
if (i > LARGE_STEP)
@@ -1695,6 +1711,9 @@ _Timecounter_Windup(struct bintime *new_boottimebin,
recalculate_scaling_factor_and_large_delta(th);
+#ifdef __rtems__
/* Update the UTC timestamps used by the get*() functions. */
th->th_bintime = bt;
2.17.1
