[PATCH v1 2/3] Add pinning to priority SMP scheduler
Sebastian Huber
Wed Nov 17 16:08:21 UTC 2021
On 17/11/2021 16:33, Ryan Long wrote:
> cpukit/include/rtems/score/scheduler.h | 36 ++++++++
> .../rtems/score/schedulerpriorityaffinitysmp.h | 4 +-
> cpukit/score/src/schedulerpinusingaffinity.c | 98 ++++++++++++++++++++++
> spec/build/cpukit/objsmp.yml | 1 +
> 4 files changed, 137 insertions(+), 2 deletions(-)
> create mode 100644 cpukit/score/src/schedulerpinusingaffinity.c
> diff --git a/cpukit/include/rtems/score/scheduler.h b/cpukit/include/rtems/score/scheduler.h
> index df9477f..da71c61 100644
> --- a/cpukit/include/rtems/score/scheduler.h
> +++ b/cpukit/include/rtems/score/scheduler.h
> @@ -436,6 +436,42 @@ Priority_Control _Scheduler_default_Unmap_priority(
> Scheduler_Node *node,
> struct Per_CPU_Control *cpu
> + * @brief Pins a thread to a core using affinity
> + * This default implementation for the thread pin or unpin operations should
> + * be used by uniprocessor schedulers if SMP support is enabled.
> + * @param scheduler This parameter is unused.
> + * @param the_thread This parameter is unused.
> + * @param node This parameter is unused.
> + * @param cpu This parameter is unused.
> + void _Scheduler_pin_using_affinity(
> + const Scheduler_Control *scheduler,
> + Thread_Control *the_thread,
> + Scheduler_Node *node,
> + struct Per_CPU_Control *cpu
> + * @brief Unpinds a thread to a core using affinity.
> + void _Scheduler_unpin_using_affinity(
> #endif
The documentation comments above make no sense to me.
> diff --git a/cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h b/cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h
> index 1b660fa..26a4562 100644
> --- a/cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h
> +++ b/cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h
> @@ -65,8 +65,8 @@ extern "C" {
> _Scheduler_priority_affinity_SMP_Ask_for_help, \
> _Scheduler_priority_affinity_SMP_Reconsider_help_request, \
> _Scheduler_priority_affinity_SMP_Withdraw_node, \
> - _Scheduler_default_Pin_or_unpin_not_supported, \
> + _Scheduler_pin_using_affinity, \
> + _Scheduler_unpin_using_affinity, \
> _Scheduler_priority_affinity_SMP_Add_processor, \
> _Scheduler_priority_affinity_SMP_Remove_processor, \
> _Scheduler_priority_affinity_SMP_Node_initialize, \
> diff --git a/cpukit/score/src/schedulerpinusingaffinity.c b/cpukit/score/src/schedulerpinusingaffinity.c
> new file mode 100644
> index 0000000..f9597d2
> --- /dev/null
> +++ b/cpukit/score/src/schedulerpinusingaffinity.c
> @@ -0,0 +1,98 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup RTEMSScoreScheduler
> + * @brief Pins/unpins a thread to a core using affinity.
> + * Copyright (C) 2021 OAR Corporation
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <assert.h>
> +#include <rtems/score/scheduler.h>
> +#include <rtems/score/percpu.h>
> +#include <rtems/score/schedulerimpl.h>
> +void _Scheduler_pin_using_affinity(
> + const Scheduler_Control* scheduler,
> + Thread_Control* the_thread,
> + Scheduler_Node* node,
> + struct Per_CPU_Control* cpu
> +#if defined( RTEMS_SMP )
> + cpu_set_t cpuset;
> + int cpu_num;
> + Processor_mask affinity;
> + Processor_mask_Copy_status status;
> + Status_Control status2;
> + cpu_num = _Per_CPU_Get_index( cpu );
> + CPU_ZERO( &cpuset );
> + CPU_SET( cpu_num, &cpuset );
> + status = _Processor_mask_From_cpu_set_t( &affinity, sizeof( cpuset ), &cpuset );
> + assert( status == PROCESSOR_MASK_COPY_LOSSLESS );
> + status2 = ( *scheduler->Operations.set_affinity )(
> + scheduler,
> + the_thread,
> + node,
> + &affinity
> + assert( status2 == STATUS_SUCCESSFUL );
> +#endif
> +void _Scheduler_unpin_using_affinity(
> + const Processor_mask* processor_set;
> + Status_Control status;
> + processor_set = _Scheduler_Get_processors( scheduler );
> + status = ( *scheduler->Operations.set_affinity )(
> + scheduler,
> + the_thread,
> + node,
> + processor_set
> + assert( status == STATUS_SUCCESSFUL );
> +#endif
> diff --git a/spec/build/cpukit/objsmp.yml b/spec/build/cpukit/objsmp.yml
> index 1a55708..3aca79b 100644
> --- a/spec/build/cpukit/objsmp.yml
> +++ b/spec/build/cpukit/objsmp.yml
> @@ -15,6 +15,7 @@ source:
> - cpukit/score/src/profilingsmplock.c
> - cpukit/score/src/schedulerdefaultpinunpin.c
> - cpukit/score/src/schedulerdefaultpinunpindonothing.c
> +- cpukit/score/src/schedulerpinusingaffinity.c
> - cpukit/score/src/schedulerdefaultsetaffinity.c
> - cpukit/score/src/scheduleredfsmp.c
> - cpukit/score/src/schedulerpriorityaffinitysmp.c
This implementation is broken. There are reasons why we have the thread
pinning in addition to the thread to processor affinity. The thread
pinning is an operation specific temporary modification of a thread. It
is used in a nested way:
pin()
op()
unpin()
It is also very crucial that the thread pinning works strictly and
independent of the thread affinity, otherwise I wish you happy debugging
sessions with the Epoch Based Reclamation code in libbsd.
See the EDF SMP scheduler for an example.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
