[PATCH v1 1/3] priorityaffinitysmp: Update block state check
Sebastian Huber
Wed Nov 17 16:13:12 UTC 2021
On 17/11/2021 16:33, Ryan Long wrote:
> The thread's blocked status is recorded in the thread's scheduler state,
> not directly in the thread state. This prevents blocking from being
> nested which violates asserts and eventually causes a crash.
> cpukit/score/src/schedulerpriorityaffinitysmp.c | 8 ++++----
> 1 file changed, 4 insertions(+), 4 deletions(-)
> diff --git a/cpukit/score/src/schedulerpriorityaffinitysmp.c b/cpukit/score/src/schedulerpriorityaffinitysmp.c
> index 10f6808..2bad6ff 100644
> --- a/cpukit/score/src/schedulerpriorityaffinitysmp.c
> +++ b/cpukit/score/src/schedulerpriorityaffinitysmp.c
> @@ -550,7 +550,7 @@ Status_Control _Scheduler_priority_affinity_SMP_Set_affinity(
> Scheduler_Context *context;
> Scheduler_priority_affinity_SMP_Node *node;
> - States_Control current_state;
> + Thread_Scheduler_state current_state;
> Processor_mask my_affinity;
> context = _Scheduler_Get_context( scheduler );
> @@ -569,15 +569,15 @@ Status_Control _Scheduler_priority_affinity_SMP_Set_affinity(
> if ( _Processor_mask_Is_equal( &node->Affinity, affinity ) )
> return STATUS_SUCCESSFUL;
> - current_state = thread->current_state;
> + current_state = thread->Scheduler.state;
> - if ( _States_Is_ready( current_state ) ) {
> + if ( current_state == THREAD_SCHEDULER_READY ) {
> _Scheduler_priority_affinity_SMP_Block( scheduler, thread, &node->Base.Base.Base );
> _Processor_mask_Assign( &node->Affinity, affinity );
> * FIXME: Do not ignore threads in need for help.
This change may fix this particular issue, however, looking at this code
fragment, there are probably more issues. Firstly, the
thread->Scheduler.state access needs to be protected by the thread
scheduler lock. Secondly, this code should probably use the scheduler
SMP node state.
I would rewrite it to use _Scheduler_SMP_Set_affinity().
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
