[PATCH 1/2] cpukit: Enable debug for SMP AArch64
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Nov 17 18:02:25 UTC 2021
Ensure when both RTEMS_DEBUG is specified and pointers are large that
enough space is allocated to accomodate the Per_CPU_Control structure.
This changes the calculation to be more compositional instead of trying
to list out every permutation of options possible.
cpukit/include/rtems/score/percpu.h | 31 ++++++++++++++++++++---------
1 file changed, 22 insertions(+), 9 deletions(-)
diff --git a/cpukit/include/rtems/score/percpu.h b/cpukit/include/rtems/score/percpu.h
index 6081653a86..0794f15f69 100644
--- a/cpukit/include/rtems/score/percpu.h
+++ b/cpukit/include/rtems/score/percpu.h
@@ -38,18 +38,31 @@
extern "C" {
#endif
-#if defined(RTEMS_SMP)
- #if defined(RTEMS_PROFILING)
- #define PER_CPU_CONTROL_SIZE_APPROX \
- ( 512 + CPU_PER_CPU_CONTROL_SIZE + CPU_INTERRUPT_FRAME_SIZE )
- #elif defined(RTEMS_DEBUG) || CPU_SIZEOF_POINTER > 4
- ( 256 + CPU_PER_CPU_CONTROL_SIZE + CPU_INTERRUPT_FRAME_SIZE )
+#if defined( RTEMS_SMP )
+ #if defined( RTEMS_PROFILING )
+ #define PER_CPU_CONTROL_SIZE_PROFILING 332
+ #else
+ #define PER_CPU_CONTROL_SIZE_PROFILING 0
+ #endif
+ #if defined( RTEMS_DEBUG )
+ #define PER_CPU_CONTROL_SIZE_DEBUG 76
#else
- ( 180 + CPU_PER_CPU_CONTROL_SIZE + CPU_INTERRUPT_FRAME_SIZE )
+ #define PER_CPU_CONTROL_SIZE_DEBUG 0
#endif
+ #if CPU_SIZEOF_POINTER > 4
+ #define PER_CPU_CONTROL_SIZE_BIG_POINTER 76
+ #else
+ #define PER_CPU_CONTROL_SIZE_BIG_POINTER 0
+ #endif
+ #define PER_CPU_CONTROL_SIZE_BASE 180
+ #define PER_CPU_CONTROL_SIZE_APPROX \
+ ( PER_CPU_CONTROL_SIZE_BASE + CPU_PER_CPU_CONTROL_SIZE + \
+ CPU_INTERRUPT_FRAME_SIZE + PER_CPU_CONTROL_SIZE_PROFILING + \
+ PER_CPU_CONTROL_SIZE_DEBUG + PER_CPU_CONTROL_SIZE_BIG_POINTER )
* This ensures that on SMP configurations the individual per-CPU controls
* are on different cache lines to prevent false sharing. This define can be
2.30.2
