[PATCH] rtems: Add bindings for languages other than C/C++
Sebastian Huber
Thu Nov 18 15:55:27 UTC 2021
Add bindings for languages other than C/C++ for
rtems_scheduler_get_processor() and
rtems_scheduler_get_processor_maximum().
cpukit/rtems/src/schedulergetprocessor.c | 54 +++++++++++++++++++++
cpukit/rtems/src/schedulergetprocessormax.c | 54 +++++++++++++++++++++
spec/build/cpukit/librtemscpu.yml | 2 +
3 files changed, 110 insertions(+)
create mode 100644 cpukit/rtems/src/schedulergetprocessor.c
create mode 100644 cpukit/rtems/src/schedulergetprocessormax.c
diff --git a/cpukit/rtems/src/schedulergetprocessor.c b/cpukit/rtems/src/schedulergetprocessor.c
new file mode 100644
index 0000000000..14fbce3c49
--- /dev/null
+++ b/cpukit/rtems/src/schedulergetprocessor.c
@@ -0,0 +1,54 @@
+ * @file
+ * @ingroup RTEMSImplClassic
+ * @brief This source file contains the implementation of
+ * rtems_scheduler_get_processor() as a binding for languages other than
+ * C/C++.
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/rtems/tasks.h>
+static uint32_t _RTEMS_Scheduler_get_processor( void )
+ return rtems_scheduler_get_processor();
+#undef rtems_scheduler_get_processor
+uint32_t rtems_scheduler_get_processor( void )
+ return _RTEMS_Scheduler_get_processor();
diff --git a/cpukit/rtems/src/schedulergetprocessormax.c b/cpukit/rtems/src/schedulergetprocessormax.c
index 0000000000..c14b5a4546
--- /dev/null
+++ b/cpukit/rtems/src/schedulergetprocessormax.c
@@ -0,0 +1,54 @@
+ * @file
+ * rtems_scheduler_get_processor_maximum() as a binding for languages other
+ * than C/C++.
+ * are met:
+#endif
+static uint32_t _RTEMS_Scheduler_get_processor_maximum( void )
+ return rtems_scheduler_get_processor_maximum();
+#undef rtems_scheduler_get_processor_maximum
+uint32_t rtems_scheduler_get_processor_maximum( void )
+ return _RTEMS_Scheduler_get_processor_maximum();
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 063917b410..9e57f346c2 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -1270,6 +1270,8 @@ source:
- cpukit/rtems/src/rtemstimer.c
- cpukit/rtems/src/scheduleraddprocessor.c
- cpukit/rtems/src/schedulergetmaxprio.c
+- cpukit/rtems/src/schedulergetprocessor.c
+- cpukit/rtems/src/schedulergetprocessormax.c
- cpukit/rtems/src/schedulergetprocessorset.c
- cpukit/rtems/src/schedulerident.c
- cpukit/rtems/src/scheduleridentbyprocessor.c
2.26.2
