[PATCH] rtems: Use RTEMS_WHO_AM_I for rtems_task_ident()
Joel Sherrill
joel at rtems.org
Thu Nov 18 18:42:46 UTC 2021
This should be OK to push. Plus the minor patch to the documentation.
--joel
On Thu, Nov 18, 2021 at 9:55 AM Sebastian Huber
> cpukit/include/rtems/rtems/tasks.h | 3 ++-
> cpukit/rtems/src/taskident.c | 3 ++-
> testsuites/libtests/malloctest/task1.c | 2 +-
> testsuites/libtests/stackchk/task1.c | 2 +-
> testsuites/mptests/mp01/task1.c | 2 +-
> testsuites/mptests/mp03/task1.c | 2 +-
> testsuites/mptests/mp04/task1.c | 2 +-
> testsuites/samples/base_mp/apptask.c | 2 +-
> testsuites/samples/base_sp/apptask.c | 2 +-
> testsuites/samples/ticker/tasks.c | 2 +-
> testsuites/smptests/smp08/tasks.c | 2 +-
> testsuites/smptests/smpaffinity01/init.c | 2 +-
> testsuites/sptests/sp19/first.c | 2 +-
> testsuites/sptests/sp19/fptask.c | 2 +-
> testsuites/sptests/sp19/task1.c | 2 +-
> testsuites/sptests/sp24/task1.c | 2 +-
> testsuites/sptests/sp30/task1.c | 2 +-
> testsuites/sptests/sp42/init.c | 2 +-
> testsuites/sptests/sp76/init.c | 2 +-
> testsuites/sptests/spcbssched01/task1.c | 2 +-
> testsuites/sptests/spedfsched01/task1.c | 2 +-
> testsuites/sptests/spsimplesched01/init.c | 2 +-
> testsuites/sptests/spsimplesched02/init.c | 2 +-
> testsuites/sptests/sptask_err04/task1.c | 4 ++--
> 24 files changed, 27 insertions(+), 25 deletions(-)
> diff --git a/cpukit/include/rtems/rtems/tasks.h b/cpukit/include/rtems/rtems/tasks.h
> index 8c6e8a3bca..0392586759 100644
> --- a/cpukit/include/rtems/rtems/tasks.h
> +++ b/cpukit/include/rtems/rtems/tasks.h
> @@ -1267,7 +1267,8 @@ rtems_status_code rtems_task_construct(
> * This directive obtains a task identifier associated with the task name
> * specified in ``name``.
> - * A task may obtain its own identifier by specifying #RTEMS_SELF for the name.
> + * A task may obtain its own identifier by specifying #RTEMS_WHO_AM_I for the
> + * name.
> * The node to search is specified in ``node``. It shall be
> diff --git a/cpukit/rtems/src/taskident.c b/cpukit/rtems/src/taskident.c
> index 74a0a53982..89c2c7ce7e 100644
> --- a/cpukit/rtems/src/taskident.c
> +++ b/cpukit/rtems/src/taskident.c
> @@ -40,6 +40,7 @@
> #endif
> #include <rtems/rtems/tasksimpl.h>
> +#include <rtems/rtems/object.h>
> #include <rtems/rtems/objectimpl.h>
> #include <rtems/score/percpu.h>
> @@ -53,7 +54,7 @@ rtems_status_code rtems_task_ident(
> return RTEMS_INVALID_ADDRESS;
> - if ( name == OBJECTS_ID_OF_SELF ) {
> + if ( name == RTEMS_WHO_AM_I ) {
> *id = _Thread_Get_executing()->Object.id;
> return RTEMS_SUCCESSFUL;
> diff --git a/testsuites/libtests/malloctest/task1.c b/testsuites/libtests/malloctest/task1.c
> index 753a74e77a..4f0309af5a 100644
> --- a/testsuites/libtests/malloctest/task1.c
> +++ b/testsuites/libtests/malloctest/task1.c
> @@ -34,7 +34,7 @@ rtems_task Task_1_through_5(
> unsigned char *mem_ptr;
> int mem_amt;
> - status = rtems_task_ident( RTEMS_SELF, RTEMS_SEARCH_ALL_NODES, &tid );
> + status = rtems_task_ident( RTEMS_WHO_AM_I, RTEMS_SEARCH_ALL_NODES, &tid );
> directive_failed( status, "rtems_task_ident" );
> while (TRUE)
> diff --git a/testsuites/libtests/stackchk/task1.c b/testsuites/libtests/stackchk/task1.c
> index 7a9f488ff0..4e08d20819 100644
> --- a/testsuites/libtests/stackchk/task1.c
> +++ b/testsuites/libtests/stackchk/task1.c
> @@ -25,7 +25,7 @@ rtems_task Task_1_through_3(
> rtems_time_of_day time;
> rtems_status_code status;
> while( FOREVER ) {
> diff --git a/testsuites/mptests/mp01/task1.c b/testsuites/mptests/mp01/task1.c
> index 50821e1b49..18682130aa 100644
> --- a/testsuites/mptests/mp01/task1.c
> +++ b/testsuites/mptests/mp01/task1.c
> @@ -35,7 +35,7 @@ rtems_task Test_task(
> rtems_id tid;
> status = rtems_clock_get_tod( &time );
> diff --git a/testsuites/mptests/mp03/task1.c b/testsuites/mptests/mp03/task1.c
> index 48682e032c..9b0c1b2459 100644
> --- a/testsuites/mptests/mp03/task1.c
> +++ b/testsuites/mptests/mp03/task1.c
> @@ -94,7 +94,7 @@ rtems_task Test_task(
> rtems_id tid;
> puts( "Getting TID of remote task" );
> diff --git a/testsuites/mptests/mp04/task1.c b/testsuites/mptests/mp04/task1.c
> index 878effd237..6e350d8527 100644
> --- a/testsuites/mptests/mp04/task1.c
> +++ b/testsuites/mptests/mp04/task1.c
> @@ -33,7 +33,7 @@ rtems_task Test_task(
> rtems_task_priority previous_priority;
> rtems_task_priority previous_priority_1;
> diff --git a/testsuites/samples/base_mp/apptask.c b/testsuites/samples/base_mp/apptask.c
> index e54e08afe8..063328ed42 100644
> --- a/testsuites/samples/base_mp/apptask.c
> +++ b/testsuites/samples/base_mp/apptask.c
> @@ -32,7 +32,7 @@ rtems_task Application_task(
> rtems_id tid;
> - rtems_task_ident( RTEMS_SELF, RTEMS_SEARCH_ALL_NODES, &tid );
> + rtems_task_ident( RTEMS_WHO_AM_I, RTEMS_SEARCH_ALL_NODES, &tid );
> (void) status;
> printf( "This task was invoked with the node argument (%" PRIdrtems_task_argument ")\n", node );
> printf( "This task has the id of 0x%" PRIxrtems_id "\n", tid );
> diff --git a/testsuites/samples/base_sp/apptask.c b/testsuites/samples/base_sp/apptask.c
> index f450f71467..02df777bea 100644
> --- a/testsuites/samples/base_sp/apptask.c
> +++ b/testsuites/samples/base_sp/apptask.c
> @@ -34,7 +34,7 @@ rtems_task Application_task(
> unsigned int a = (unsigned int) argument;
> directive_failed( status, "ident" );
> printf(
> diff --git a/testsuites/samples/ticker/tasks.c b/testsuites/samples/ticker/tasks.c
> index 12e806884d..7ff6eb7319 100644
> --- a/testsuites/samples/ticker/tasks.c
> +++ b/testsuites/samples/ticker/tasks.c
> @@ -30,7 +30,7 @@ rtems_task Test_task(
> uint32_t task_index;
> directive_failed( status, "task ident" );
> task_index = task_number( tid );
> diff --git a/testsuites/smptests/smp08/tasks.c b/testsuites/smptests/smp08/tasks.c
> index 40a097d034..28271253b8 100644
> --- a/testsuites/smptests/smp08/tasks.c
> +++ b/testsuites/smptests/smp08/tasks.c
> @@ -28,7 +28,7 @@ rtems_task Test_task(
> p = rtems_object_get_name( RTEMS_SELF, 5, name );
> rtems_test_assert( p != NULL );
> rtems_test_assert( status == RTEMS_SUCCESSFUL );
> for ( ; ; ) {
> diff --git a/testsuites/smptests/smpaffinity01/init.c b/testsuites/smptests/smpaffinity01/init.c
> index 9ec687d816..e0065bfcb0 100644
> --- a/testsuites/smptests/smpaffinity01/init.c
> +++ b/testsuites/smptests/smpaffinity01/init.c
> @@ -213,7 +213,7 @@ static void Init(rtems_task_argument arg)
> TEST_BEGIN();
> /* Initialize thread id */
> - sc = rtems_task_ident( RTEMS_SELF, RTEMS_SEARCH_ALL_NODES, &Init_id );
> + sc = rtems_task_ident( RTEMS_WHO_AM_I, RTEMS_SEARCH_ALL_NODES, &Init_id );
> directive_failed( sc, "Identify Init Task" );
> Validate_setaffinity_errors();
> diff --git a/testsuites/sptests/sp19/first.c b/testsuites/sptests/sp19/first.c
> index 69ff29762f..00da9edd6e 100644
> --- a/testsuites/sptests/sp19/first.c
> +++ b/testsuites/sptests/sp19/first.c
> @@ -26,7 +26,7 @@ rtems_task First_FP_task(
> INTEGER_DECLARE;
> FP_DECLARE;
> diff --git a/testsuites/sptests/sp19/fptask.c b/testsuites/sptests/sp19/fptask.c
> index 5ffff37f7e..c91a163f47 100644
> --- a/testsuites/sptests/sp19/fptask.c
> +++ b/testsuites/sptests/sp19/fptask.c
> @@ -27,7 +27,7 @@ rtems_task FP_task(
> INTEGER_DECLARE;
> FP_DECLARE;
> directive_failed( status, "rtems_task_ident of self" );
> diff --git a/testsuites/sptests/sp19/task1.c b/testsuites/sptests/sp19/task1.c
> index 912ed26ac6..b5cbdcd181 100644
> --- a/testsuites/sptests/sp19/task1.c
> +++ b/testsuites/sptests/sp19/task1.c
> @@ -24,7 +24,7 @@ rtems_task Task_1(
> INTEGER_DECLARE;
> diff --git a/testsuites/sptests/sp24/task1.c b/testsuites/sptests/sp24/task1.c
> index 9a2de67f40..d6f51f6333 100644
> --- a/testsuites/sptests/sp24/task1.c
> +++ b/testsuites/sptests/sp24/task1.c
> @@ -30,7 +30,7 @@ rtems_task Task_1_through_3(
> while ( FOREVER ) {
> diff --git a/testsuites/sptests/sp30/task1.c b/testsuites/sptests/sp30/task1.c
> index da4b0d20e7..56aa6aa4ab 100644
> --- a/testsuites/sptests/sp30/task1.c
> +++ b/testsuites/sptests/sp30/task1.c
> while ( FOREVER ) {
> diff --git a/testsuites/sptests/sp42/init.c b/testsuites/sptests/sp42/init.c
> index 10e49275e5..0004694741 100644
> --- a/testsuites/sptests/sp42/init.c
> +++ b/testsuites/sptests/sp42/init.c
> @@ -74,7 +74,7 @@ static rtems_task Locker_task(
> rtems_task_argument my_obtain_counter;
> rtems_test_assert( task_index == task_number( tid ) - 1 );
> diff --git a/testsuites/sptests/sp76/init.c b/testsuites/sptests/sp76/init.c
> index c7e451c32a..6315850b51 100644
> --- a/testsuites/sptests/sp76/init.c
> +++ b/testsuites/sptests/sp76/init.c
> @@ -49,7 +49,7 @@ static rtems_task Init(
> TEST_BEGIN();
> - status = rtems_task_ident( RTEMS_SELF, RTEMS_SEARCH_ALL_NODES, &id );
> + status = rtems_task_ident( RTEMS_WHO_AM_I, RTEMS_SEARCH_ALL_NODES, &id );
> /* to make sure it is equal to TA2 */
> diff --git a/testsuites/sptests/spcbssched01/task1.c b/testsuites/sptests/spcbssched01/task1.c
> index f5d180831f..1e51b80966 100644
> --- a/testsuites/sptests/spcbssched01/task1.c
> +++ b/testsuites/sptests/spcbssched01/task1.c
> @@ -31,7 +31,7 @@ rtems_task Task_1_through_3(
> rtems_interval ticks;
> ticks = RTEMS_MILLISECONDS_TO_TICKS( task_number( tid ) * 5 * 1000 );
> diff --git a/testsuites/sptests/spedfsched01/task1.c b/testsuites/sptests/spedfsched01/task1.c
> --- a/testsuites/sptests/spedfsched01/task1.c
> +++ b/testsuites/sptests/spedfsched01/task1.c
> diff --git a/testsuites/sptests/spsimplesched01/init.c b/testsuites/sptests/spsimplesched01/init.c
> index f2a06732d8..0bb05bf137 100644
> --- a/testsuites/sptests/spsimplesched01/init.c
> +++ b/testsuites/sptests/spsimplesched01/init.c
> @@ -34,7 +34,7 @@ rtems_task Test_task(
> diff --git a/testsuites/sptests/spsimplesched02/init.c b/testsuites/sptests/spsimplesched02/init.c
> index d19d3553d9..1366c93d7b 100644
> --- a/testsuites/sptests/spsimplesched02/init.c
> +++ b/testsuites/sptests/spsimplesched02/init.c
> @@ -38,7 +38,7 @@ rtems_task Test_task(
> rtems_id tid;
> directive_failed( status, "wake after" );
> for ( ; ; ) {
> diff --git a/testsuites/sptests/sptask_err04/task1.c b/testsuites/sptests/sptask_err04/task1.c
> index c1f59d81fb..ba93d67da7 100644
> --- a/testsuites/sptests/sptask_err04/task1.c
> +++ b/testsuites/sptests/sptask_err04/task1.c
> @@ -50,7 +50,7 @@ rtems_task Task_1(
> puts( "TA1 - rtems_task_delete - RTEMS_INVALID_ID" );
> /* NULL param */
> - status = rtems_task_ident( RTEMS_SELF, RTEMS_SEARCH_ALL_NODES, NULL );
> + status = rtems_task_ident( RTEMS_WHO_AM_I, RTEMS_SEARCH_ALL_NODES, NULL );
> fatal_directive_status(
> status,
> RTEMS_INVALID_ADDRESS,
> @@ -59,7 +59,7 @@ rtems_task Task_1(
> puts( "TA1 - rtems_task_ident - RTEMS_INVALID_ADDRESS" );
> /* OK */
> - status = rtems_task_ident( RTEMS_SELF, RTEMS_SEARCH_ALL_NODES, &self_id );
> + status = rtems_task_ident( RTEMS_WHO_AM_I, RTEMS_SEARCH_ALL_NODES, &self_id );
> if ( self_id != Task_id[ 1 ] ) {
> puts( "ERROR - rtems_task_ident - incorrect ID returned!" );
> 2.26.2
> devel mailing list
> devel at rtems.org
