[PATCH] rtems: Use identifier instead of designator
Thu Nov 18 19:01:46 UTC 2021
OK but do these terms need to be defined somewhere in the RTEMS
documentation set?
--joel
On Thu, Nov 18, 2021 at 12:58 PM Sebastian Huber
> The term identifier is better aligned with the C11 standard wording.
>  cpukit/include/rtems/rtems/intr.h | 24 ++++++++++++------------
>  1 file changed, 12 insertions(+), 12 deletions(-)
> diff --git a/cpukit/include/rtems/rtems/intr.h b/cpukit/include/rtems/rtems/intr.h
> index d0aaed5f30..2c88d1265d 100644
> --- a/cpukit/include/rtems/rtems/intr.h
> +++ b/cpukit/include/rtems/rtems/intr.h
> @@ -810,13 +810,13 @@ rtems_status_code rtems_interrupt_catch(
>   * @param _specifier is the storage-class specifier for the ISR lock to
>   *   declare, for example ``extern`` or ``static``.
> - * @param _designator is the ISR lock object designator.
> + * @param _identifier is the ISR lock object identifier.
>   * @par Notes
>   * Do not add a ";" after this macro.
> -#define RTEMS_INTERRUPT_LOCK_DECLARE( _specifier, _designator ) \
> -  ISR_LOCK_DECLARE( _specifier, _designator )
> +#define RTEMS_INTERRUPT_LOCK_DECLARE( _specifier, _identifier ) \
> +  ISR_LOCK_DECLARE( _specifier, _identifier )
>  /* Generated from spec:/rtems/intr/if/lock-define */
> @@ -828,7 +828,7 @@ rtems_status_code rtems_interrupt_catch(
>   * @param _name is the ISR lock name.  It shall be a string.  The name is only
>   *   used where the system was built with profiling support enabled.
> @@ -842,8 +842,8 @@ rtems_status_code rtems_interrupt_catch(
>   * RTEMS_INTERRUPT_LOCK_INITIALIZER().
>   * @endparblock
> -#define RTEMS_INTERRUPT_LOCK_DEFINE( _specifier, _designator, _name ) \
> -  ISR_LOCK_DEFINE( _specifier, _designator, _name )
> +#define RTEMS_INTERRUPT_LOCK_DEFINE( _specifier, _identifier, _name ) \
> +  ISR_LOCK_DEFINE( _specifier, _identifier, _name )
>  /* Generated from spec:/rtems/intr/if/lock-initializer */
> @@ -869,13 +869,13 @@ rtems_status_code rtems_interrupt_catch(
>   * @brief Defines an ISR lock member.
> - * @param _designator is the ISR lock member designator.
> + * @param _identifier is the ISR lock member identifier.
>   * @par Notes
> -#define RTEMS_INTERRUPT_LOCK_MEMBER( _designator ) \
> -  ISR_LOCK_MEMBER( _designator )
> +#define RTEMS_INTERRUPT_LOCK_MEMBER( _identifier ) \
> +  ISR_LOCK_MEMBER( _identifier )
>  /* Generated from spec:/rtems/intr/if/lock-reference */
> @@ -884,15 +884,15 @@ rtems_status_code rtems_interrupt_catch(
>   * @brief Defines an ISR lock object reference.
> - * @param _designator is the ISR lock reference designator.
> + * @param _identifier is the ISR lock reference identifier.
>   * @param _target is the target object to reference.
>   * @par Notes
> -#define RTEMS_INTERRUPT_LOCK_REFERENCE( _designator, _target ) \
> -  ISR_LOCK_REFERENCE( _designator, _target )
> +#define RTEMS_INTERRUPT_LOCK_REFERENCE( _identifier, _target ) \
> +  ISR_LOCK_REFERENCE( _identifier, _target )
>  /* Generated from spec:/rtems/intr/if/raise */
> 2.31.1
> devel mailing list
> devel at rtems.org
