[PATCH 12/27] score: Rework affine ready queue handling
Sat Nov 20 19:42:22 UTC 2021
On Mon, Nov 15, 2021 at 10:13 AM Sebastian Huber
> Rework the handling of the affine ready queue for the EDF SMP scheduler.
> Do the queue handling in the node insert, move, and extract operations.
> Remove the queue handling from _Scheduler_EDF_SMP_Allocate_processor().
> Update #4531.
>  cpukit/include/rtems/score/scheduleredfsmp.h |  13 ++-
>  cpukit/score/src/scheduleredfsmp.c           | 106 ++++++++++++-------
>  2 files changed, 77 insertions(+), 42 deletions(-)
> diff --git a/cpukit/include/rtems/score/scheduleredfsmp.h b/cpukit/include/rtems/score/scheduleredfsmp.h
> index 85e438e81d..e749b3d419 100644
> --- a/cpukit/include/rtems/score/scheduleredfsmp.h
> +++ b/cpukit/include/rtems/score/scheduleredfsmp.h
> @@ -79,9 +79,18 @@ typedef struct {
>    RBTree_Control Queue;
> -   * @brief The scheduled thread of the corresponding processor.
> +   * @brief If this member is not NULL, then it references the scheduled thread
> +   *   affine only to the corresponding processor, otherwise the processor is
> +   *   allocated to a thread which may execute on any of the processors owned
> +   *   by the scheduler.
> -  Scheduler_EDF_SMP_Node *scheduled;
> +  Scheduler_EDF_SMP_Node *affine_scheduled;
> +   * @brief This member referneces the thread allocated to the corresponding
typo: references
> +   *   processor.
> +  Scheduler_EDF_SMP_Node *allocated;
>  } Scheduler_EDF_SMP_Ready_queue;
>  typedef struct {
> diff --git a/cpukit/score/src/scheduleredfsmp.c b/cpukit/score/src/scheduleredfsmp.c
> index a915dbe511..7da777e87a 100644
> --- a/cpukit/score/src/scheduleredfsmp.c
> +++ b/cpukit/score/src/scheduleredfsmp.c
> @@ -196,21 +196,21 @@ static inline Scheduler_Node *_Scheduler_EDF_SMP_Get_highest_ready(
>    return &highest_ready->Base.Base;
> -static inline void _Scheduler_EDF_SMP_Set_scheduled(
> +static inline void _Scheduler_EDF_SMP_Set_allocated(
>    Scheduler_EDF_SMP_Context *self,
> -  Scheduler_EDF_SMP_Node    *scheduled,
> +  Scheduler_EDF_SMP_Node    *allocated,
>    const Per_CPU_Control     *cpu
> -  self->Ready[ _Per_CPU_Get_index( cpu ) + 1 ].scheduled = scheduled;
> +  self->Ready[ _Per_CPU_Get_index( cpu ) + 1 ].allocated = allocated;
> -static inline Scheduler_EDF_SMP_Node *_Scheduler_EDF_SMP_Get_scheduled(
> +static inline Scheduler_EDF_SMP_Node *_Scheduler_EDF_SMP_Get_allocated(
>    const Scheduler_EDF_SMP_Context *self,
>    uint8_t                          rqi
> -  return self->Ready[ rqi ].scheduled;
> +  return self->Ready[ rqi ].allocated;
>  static inline Scheduler_Node *_Scheduler_EDF_SMP_Get_lowest_scheduled(
> @@ -226,20 +226,62 @@ static inline Scheduler_Node *_Scheduler_EDF_SMP_Get_lowest_scheduled(
>    if ( rqi != 0 ) {
>      Scheduler_EDF_SMP_Context *self;
> -    Scheduler_EDF_SMP_Node    *node;
>      self = _Scheduler_EDF_SMP_Get_self( context );
> -    node = _Scheduler_EDF_SMP_Get_scheduled( self, rqi );
> +    affine_scheduled = self->Ready[ rqi ].affine_scheduled;
> -    if ( node->ready_queue_index > 0 ) {
> -      _Assert( node->ready_queue_index == rqi );
> -      return &node->Base.Base;
> +    if ( affine_scheduled != NULL ) {
> +      _Assert( affine_scheduled->ready_queue_index == rqi );
> +      return &affine_scheduled->Base.Base;
>    return _Scheduler_SMP_Get_lowest_scheduled( context, filter_base );
> +static inline void _Scheduler_EDF_SMP_Insert_scheduled(
> +  Scheduler_Context *context,
> +  Scheduler_Node    *node_base,
> +  Priority_Control   priority_to_insert
> +  Scheduler_EDF_SMP_Context     *self;
> +  Scheduler_EDF_SMP_Node        *node;
> +  uint8_t                        rqi;
> +  Scheduler_EDF_SMP_Ready_queue *ready_queue;
> +  self = _Scheduler_EDF_SMP_Get_self( context );
> +  node = _Scheduler_EDF_SMP_Node_downcast( node_base );
> +  rqi = node->ready_queue_index;
> +  ready_queue = &self->Ready[ rqi ];
> +  _Scheduler_SMP_Insert_scheduled( context, node_base, priority_to_insert );
> +  if ( rqi != 0 ) {
> +    ready_queue->affine_scheduled = node;
> +    if ( !_RBTree_Is_empty( &ready_queue->Queue ) ) {
> +      _Chain_Extract_unprotected( &ready_queue->Node );
> +static inline void _Scheduler_EDF_SMP_Activate_ready_queue_if_necessary(
> +  Scheduler_EDF_SMP_Context     *self,
> +  uint8_t                        rqi,
> +  if (
> +    rqi != 0 &&
> +    _RBTree_Is_empty( &ready_queue->Queue ) &&
> +    ready_queue->affine_scheduled == NULL
> +    _Chain_Append_unprotected( &self->Affine_queues, &ready_queue->Node );
>  static inline void _Scheduler_EDF_SMP_Insert_ready(
> @@ -265,6 +307,7 @@ static inline void _Scheduler_EDF_SMP_Insert_ready(
>    node->generation = generation;
>    self->generations[ generation_index ] = generation + increment;
> +  _Scheduler_EDF_SMP_Activate_ready_queue_if_necessary( self, rqi, ready_queue );
>    _RBTree_Initialize_node( &node->Base.Base.Node.RBTree );
>    _RBTree_Insert_inline(
>      &ready_queue->Queue,
> @@ -272,16 +315,6 @@ static inline void _Scheduler_EDF_SMP_Insert_ready(
>      &insert_priority,
>      _Scheduler_EDF_SMP_Priority_less_equal
> -  if ( rqi != 0 && _Chain_Is_node_off_chain( &ready_queue->Node ) ) {
> -    scheduled = _Scheduler_EDF_SMP_Get_scheduled( self, rqi );
> -    if ( scheduled->ready_queue_index == 0 ) {
> -      _Chain_Append_unprotected( &self->Affine_queues, &ready_queue->Node );
>  static inline void _Scheduler_EDF_SMP_Extract_from_scheduled(
> @@ -305,6 +338,8 @@ static inline void _Scheduler_EDF_SMP_Extract_from_scheduled(
>    if ( rqi != 0 && !_RBTree_Is_empty( &ready_queue->Queue ) ) {
> +  ready_queue->affine_scheduled = NULL;
>  static inline void _Scheduler_EDF_SMP_Extract_from_ready(
> @@ -328,10 +363,9 @@ static inline void _Scheduler_EDF_SMP_Extract_from_ready(
>    if (
>      rqi != 0
>        && _RBTree_Is_empty( &ready_queue->Queue )
> -      && !_Chain_Is_node_off_chain( &ready_queue->Node )
> +      && ready_queue->affine_scheduled == NULL
> -    _Chain_Set_off_chain( &ready_queue->Node );
> @@ -342,7 +376,7 @@ static inline void _Scheduler_EDF_SMP_Move_from_scheduled_to_ready(
>    Priority_Control insert_priority;
> -  _Scheduler_SMP_Extract_from_scheduled( context, scheduled_to_ready );
> +  _Scheduler_EDF_SMP_Extract_from_scheduled( context, scheduled_to_ready );
>    insert_priority = _Scheduler_SMP_Node_priority( scheduled_to_ready );
>      context,
> @@ -361,7 +395,7 @@ static inline void _Scheduler_EDF_SMP_Move_from_ready_to_scheduled(
>    _Scheduler_EDF_SMP_Extract_from_ready( context, ready_to_scheduled );
>    insert_priority = _Scheduler_SMP_Node_priority( ready_to_scheduled );
>    insert_priority = SCHEDULER_PRIORITY_APPEND( insert_priority );
> -  _Scheduler_SMP_Insert_scheduled(
> +  _Scheduler_EDF_SMP_Insert_scheduled(
>      context,
>      ready_to_scheduled,
>      insert_priority
> @@ -385,24 +419,16 @@ static inline void _Scheduler_EDF_SMP_Allocate_processor(
>    rqi = scheduled->ready_queue_index;
>    if ( rqi != 0 ) {
> -    Scheduler_EDF_SMP_Ready_queue *ready_queue;
> -    Per_CPU_Control               *desired_cpu;
> -    ready_queue = &self->Ready[ rqi ];
> -    if ( !_Chain_Is_node_off_chain( &ready_queue->Node ) ) {
> -      _Chain_Extract_unprotected( &ready_queue->Node );
> +    Per_CPU_Control *desired_cpu;
>      desired_cpu = _Per_CPU_Get_by_index( rqi - 1 );
>      if ( victim_cpu != desired_cpu ) {
> +      node = _Scheduler_EDF_SMP_Get_allocated( self, rqi );
>        _Assert( node->ready_queue_index == 0 );
> -      _Scheduler_EDF_SMP_Set_scheduled( self, node, victim_cpu );
> +      _Scheduler_EDF_SMP_Set_allocated( self, node, victim_cpu );
>        _Scheduler_SMP_Allocate_processor_exact(
>          context,
>          &node->Base.Base,
> @@ -413,7 +439,7 @@ static inline void _Scheduler_EDF_SMP_Allocate_processor(
> -  _Scheduler_EDF_SMP_Set_scheduled( self, scheduled, victim_cpu );
> +  _Scheduler_EDF_SMP_Set_allocated( self, scheduled, victim_cpu );
>      context,
>      &scheduled->Base.Base,
> @@ -454,7 +480,7 @@ static inline bool _Scheduler_EDF_SMP_Enqueue(
>      insert_priority,
>      _Scheduler_SMP_Priority_less_equal,
>      _Scheduler_EDF_SMP_Insert_ready,
> -    _Scheduler_SMP_Insert_scheduled,
> +    _Scheduler_EDF_SMP_Insert_scheduled,
>      _Scheduler_EDF_SMP_Move_from_scheduled_to_ready,
>      _Scheduler_EDF_SMP_Get_lowest_scheduled,
> @@ -475,7 +501,7 @@ static inline void _Scheduler_EDF_SMP_Enqueue_scheduled(
>      _Scheduler_EDF_SMP_Extract_from_ready,
>      _Scheduler_EDF_SMP_Get_highest_ready,
>      _Scheduler_EDF_SMP_Move_from_ready_to_scheduled,
> @@ -510,7 +536,7 @@ static inline bool _Scheduler_EDF_SMP_Do_ask_for_help(
>      node,
> @@ -598,7 +624,7 @@ static inline void _Scheduler_EDF_SMP_Register_idle(
>    idle = _Scheduler_EDF_SMP_Node_downcast( idle_base );
> -  _Scheduler_EDF_SMP_Set_scheduled( self, idle, cpu );
> +  _Scheduler_EDF_SMP_Set_allocated( self, idle, cpu );
>  void _Scheduler_EDF_SMP_Add_processor(
> 2.26.2
> devel mailing list
> devel at rtems.org
