mips gdb/sim build failure on Darwin
Sat Nov 20 23:10:44 UTC 2021
Hi
This looks like we need to bump the hash, submit a patch, or change to
building with -Wno-error
(https://lists.rtems.org/pipermail/build/2021-November/030047.html).
Any ideas?
FYI Chris.. this one may be on you to see if a hash bump fixes it.
/usr/bin/cc -O2 -pipe -fbracket-depth=1024
-I/opt/work/builds/tools/rtems-source-builder.git/rtems/build/tmp/sb-501/6/rtems-v850/opt/work/builds/tools/6/include
-DHAVE_CONFIG_H  -DWITH_DEFAULT_ALIGNMENT=NONSTRICT_ALIGNMENT
-DWITH_TARGET_WORD_BITSIZE=32 -DWITH_TARGET_WORD_MSB=31
-DWITH_TARGET_BYTE_ORDER=BFD_ENDIAN_LITTLE   -DDEFAULT_INLINE=0
-DWITH_RESERVED_BITS=1  -Wall -Wdeclaration-after-statement
-Wpointer-arith -Wpointer-sign -Wno-unused -Wunused-value
-Wunused-function -Wno-switch -Wno-char-subscripts
-Wmissing-prototypes -Wdeclaration-after-statement -Wempty-body
-Wmissing-parameter-type -Wold-style-declaration
-Wold-style-definition -Wformat-nonliteral   -DDEBUG
-I../../../sourceware-mirror-binutils-gdb-7ab567f/sim/v850/../../newlib/libc/sys/sysnecv850
  -I. -I../../../sourceware-mirror-binutils-gdb-7ab567f/sim/v850
-I../common -I../../../sourceware-mirror-binutils-gdb-7ab567f/sim/v850/../common
-I../../include
-I../../../sourceware-mirror-binutils-gdb-7ab567f/sim/v85!
 0/../../include -I../../bfd
-I../../../sourceware-mirror-binutils-gdb-7ab567f/sim/v850/../../bfd
-I../../opcodes
-I../../../sourceware-mirror-binutils-gdb-7ab567f/sim/v850/../../opcodes
 -g -O2 -c -o interp.o -MT interp.o -MMD -MP -MF .deps/interp.Tpo
../../../sourceware-mirror-binutils-gdb-7ab567f/sim/v850/interp.c
../../../sourceware-mirror-binutils-gdb-7ab567f/sim/v850/simops.c:1651:6:
error: implicit declaration of function 'free' is invalid in C99
[-Werror,-Wimplicit-function-declaration]
            free (path);
../../../sourceware-mirror-binutils-gdb-7ab567f/sim/v850/simops.c:1667:6:
            free (path);
../../../sourceware-mirror-binutils-gdb-7ab567f/sim/v850/simops.c:1713:6:
