[PATCH 27/27] score: Restrict affinity for EDF SMP scheduler
Gedare Bloom
gedare at rtems.org
Sun Nov 21 00:42:39 UTC 2021
ok other than my comments. nothing looked major.
On Mon, Nov 15, 2021 at 10:14 AM Sebastian Huber
> The SMP EDF scheduler supports a one-to-one and one-to-all thread to
> processor affinity. It accepted affinity sets which are a proper
> subset of the online processor containing at least two processors owned by
> the scheduler. In this case it used a one-to-one thread to processor
> affinity. This leads to undefined behaviour if a processor is removed
> since the higher level check in rtems_scheduler_remove_processor() does
> not account for this implementation detail.
> Restrict the affinity set accepted by the SMP EDF scheduler to
> 1. all online processors, or
> 2. exactly one processor owned by the scheduler.
> Close #4545.
> cpukit/score/src/scheduleredfsmp.c | 30 ++++++++++++++++++++++++------
> 1 file changed, 24 insertions(+), 6 deletions(-)
> diff --git a/cpukit/score/src/scheduleredfsmp.c b/cpukit/score/src/scheduleredfsmp.c
> index 93c3c126f7..96b530e912 100644
> --- a/cpukit/score/src/scheduleredfsmp.c
> +++ b/cpukit/score/src/scheduleredfsmp.c
> @@ -885,20 +885,38 @@ Status_Control _Scheduler_EDF_SMP_Set_affinity(
> Scheduler_Context *context;
> Scheduler_EDF_SMP_Node *node;
> - Processor_mask local_affinity;
> uint8_t rqi;
> context = _Scheduler_Get_context( scheduler );
> - _Processor_mask_And( &local_affinity, &context->Processors, affinity );
> - if ( _Processor_mask_Is_zero( &local_affinity ) ) {
> - return STATUS_INVALID_NUMBER;
> + * We support a thread to processor affinity to all online processors and an
> + * affinity to exactly one processor owned by the scheduler. This
> + * restriction is necessary to avoid issues if processors are added or
> + * removed to or from the scheduler.
> if ( _Processor_mask_Is_equal( affinity, &_SMP_Online_processors ) ) {
> rqi = 0;
> } else {
> - rqi = _Processor_mask_Find_last_set( &local_affinity );
> + Processor_mask local_affinity;
> + Processor_mask only_last_affinity;
> + uint32_t last;
> + _Processor_mask_And( &local_affinity, &context->Processors, affinity );
> + if ( _Processor_mask_Is_zero( &local_affinity ) ) {
> + return STATUS_INVALID_NUMBER;
> + last = _Processor_mask_Find_last_set( &local_affinity );
> + _Processor_mask_From_index( &only_last_affinity, last - 1 );
> + if ( !_Processor_mask_Is_equal( &local_affinity, &only_last_affinity ) ) {
> + rqi = last;
> node = _Scheduler_EDF_SMP_Node_downcast( node_base );
> 2.26.2
> devel mailing list
> devel at rtems.org
