[PATCH 2/5] score: Split wkspace.c
Mon Nov 29 10:29:23 UTC 2021
Splitting the file avoids unnecessary link-time dependencies.
 cpukit/score/src/wkspace.c         | 15 ---------
 cpukit/score/src/wkspaceallocate.c | 47 +++++++++++++++++++++++++++
 cpukit/score/src/wkspacefree.c     | 51 ++++++++++++++++++++++++++++++
 spec/build/cpukit/librtemscpu.yml  |  2 ++
 4 files changed, 100 insertions(+), 15 deletions(-)
 create mode 100644 cpukit/score/src/wkspaceallocate.c
 create mode 100644 cpukit/score/src/wkspacefree.c
diff --git a/cpukit/score/src/wkspace.c b/cpukit/score/src/wkspace.c
index e4ba753435..7930a1fdc1 100644
--- a/cpukit/score/src/wkspace.c
+++ b/cpukit/score/src/wkspace.c
@@ -13,7 +13,6 @@
  * Copyright (C) 2012, 2020 embedded brains GmbH (http://www.embedded-brains.de)
- * Copyright (C) 1989, 2008 On-Line Applications Research Corporation (OAR)
  * modification, are permitted provided that the following conditions
@@ -126,17 +125,3 @@ void _Workspace_Handler_initialization(
   _Heap_Protection_set_delayed_free_fraction( &_Workspace_Area, 1 );
-void *_Workspace_Allocate( size_t size )
-  return _Heap_Allocate( &_Workspace_Area, size );
-void _Workspace_Free( void *block )
-  bool ok;
-  ok = _Heap_Free( &_Workspace_Area, block );
-  _Assert( ok );
-  (void) ok;
diff --git a/cpukit/score/src/wkspaceallocate.c b/cpukit/score/src/wkspaceallocate.c
new file mode 100644
index 0000000000..40a4d35eb1
--- /dev/null
+++ b/cpukit/score/src/wkspaceallocate.c
@@ -0,0 +1,47 @@
+ * @file
+ * @ingroup RTEMSScoreWorkspace
+ * @brief This source file contains the implementation of
+ *   _Workspace_Allocate().
+ * Copyright (C) 1989, 2008 On-Line Applications Research Corporation (OAR)
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/wkspace.h>
+#include <rtems/score/heapimpl.h>
+void *_Workspace_Allocate( size_t size )
+  return _Heap_Allocate( &_Workspace_Area, size );
diff --git a/cpukit/score/src/wkspacefree.c b/cpukit/score/src/wkspacefree.c
index 0000000000..c09a9ee0c1
--- /dev/null
+++ b/cpukit/score/src/wkspacefree.c
@@ -0,0 +1,51 @@
+ * @file
+ * @brief This source file contains the implementation of _Workspace_Free().
+ * are met:
+#endif
+#include <rtems/score/assert.h>
+void _Workspace_Free( void *block )
+  bool ok;
+  ok = _Heap_Free( &_Workspace_Area, block );
+  _Assert( ok );
+  (void) ok;
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 111b6867ed..b6b3a09c2b 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -1599,7 +1599,9 @@ source:
 - cpukit/score/src/watchdogtick.c
 - cpukit/score/src/watchdogtickssinceboot.c
 - cpukit/score/src/watchdogtimeslicedefault.c
+- cpukit/score/src/wkspaceallocate.c
 - cpukit/score/src/wkspace.c
+- cpukit/score/src/wkspacefree.c
 - cpukit/score/src/wkspaceisunifieddefault.c
 - cpukit/score/src/wkspacemallocinitdefault.c
 - cpukit/score/src/wkspacemallocinitunified.c
2.31.1
