[PATCH 5/5] libc: Optimize malloc() initialization
Sebastian Huber
Mon Nov 29 10:29:26 UTC 2021
The BSPs provide memory for the separate C Program Heap initialization
via _Memory_Get(). Most BSPs provide exactly one memory area. Only two
BSPs provide more than one memory area (arm/altera-cyclone-v and
bsps/powerpc/mpc55xxevb). Only if more than one memory area is
provided, there is a need to use _Heap_Extend(). Provide two
implementations to initialize the separate C Program Heap and let the
BSP select one of the implementations based on the number of provided
memory areas. This gets rid of a dependency on _Heap_Extend(). It
also avoids dead code sections for most BSPs.
Change licence to BSD-2-Clause according to file history.
Update #3053.
bsps/shared/start/mallocinitmany.c | 49 +++++++++
bsps/shared/start/mallocinitone.c | 49 +++++++++
cpukit/include/rtems/malloc.h | 6 +-
cpukit/include/rtems/mallocinitmany.h | 100 ++++++++++++++++++
cpukit/include/rtems/mallocinitone.h | 90 ++++++++++++++++
cpukit/libcsupport/src/malloc_initialize.c | 81 --------------
cpukit/libcsupport/src/mallocheap.c | 2 +-
.../altera-cyclone-v/bspalteracyclonev.yml | 1 +
spec/build/bsps/i386/pc386/obj.yml | 1 +
spec/build/bsps/objmem.yml | 1 +
spec/build/bsps/powerpc/mpc55xxevb/obj.yml | 1 +
spec/build/bsps/powerpc/objmem.yml | 1 +
spec/build/bsps/powerpc/tqm8xx/obj.yml | 1 +
spec/build/bsps/sparc/objmem.yml | 1 +
spec/build/cpukit/librtemscpu.yml | 1 -
testsuites/libtests/malloc04/init.c | 37 ++++---
16 files changed, 319 insertions(+), 103 deletions(-)
create mode 100644 bsps/shared/start/mallocinitmany.c
create mode 100644 bsps/shared/start/mallocinitone.c
create mode 100644 cpukit/include/rtems/mallocinitmany.h
create mode 100644 cpukit/include/rtems/mallocinitone.h
delete mode 100644 cpukit/libcsupport/src/malloc_initialize.c
diff --git a/bsps/shared/start/mallocinitmany.c b/bsps/shared/start/mallocinitmany.c
new file mode 100644
index 0000000000..afe4ad5fdb
--- /dev/null
+++ b/bsps/shared/start/mallocinitmany.c
@@ -0,0 +1,49 @@
+ * @file
+ * @ingroup MallocSupport
+ * @brief This source file contains the _Workspace_Malloc_initialize_separate()
+ * implementation which supports more than one memory area.
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/mallocinitmany.h>
+#include <rtems/score/wkspacedata.h>
+static Heap_Control _Malloc_Heap;
+Heap_Control *_Workspace_Malloc_initialize_separate( void )
+ return _Malloc_Initialize_for_many_areas( &_Malloc_Heap );
diff --git a/bsps/shared/start/mallocinitone.c b/bsps/shared/start/mallocinitone.c
index 0000000000..249f0b8e02
--- /dev/null
+++ b/bsps/shared/start/mallocinitone.c
@@ -0,0 +1,49 @@
+ * @file
+ * implementation which supports exactly one memory area.
+ * are met:
+#endif
+#include <rtems/mallocinitone.h>
+ return _Malloc_Initialize_for_one_area( &_Malloc_Heap );
diff --git a/cpukit/include/rtems/malloc.h b/cpukit/include/rtems/malloc.h
index eba538e223..c0d15fbf72 100644
--- a/cpukit/include/rtems/malloc.h
+++ b/cpukit/include/rtems/malloc.h
@@ -19,7 +19,6 @@
#include <rtems/bspIo.h>
#include <rtems/libcsupport.h> /* for malloc_walk() */
-#include <rtems/score/memory.h>
#include <stdint.h>
@@ -43,10 +42,7 @@ extern "C" {
extern Heap_Control *RTEMS_Malloc_Heap;
-Heap_Control *RTEMS_Malloc_Initialize(
- const Memory_Information *mem,
- Heap_Initialization_or_extend_handler extend
+void _Malloc_Initialize( void );
void rtems_heap_set_sbrk_amount( ptrdiff_t sbrk_amount );
diff --git a/cpukit/include/rtems/mallocinitmany.h b/cpukit/include/rtems/mallocinitmany.h
index 0000000000..ffd8439fbb
--- /dev/null
+++ b/cpukit/include/rtems/mallocinitmany.h
@@ -0,0 +1,100 @@
+ * @file
+ * @brief This header file provides the implementation of
+ * _Malloc_Initialize_for_many_areas().
+ * Copyright (C) 2012, 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#ifndef _RTEMS_MALLOCINITMANY_H
+#define _RTEMS_MALLOCINITMANY_H
+#include <rtems/malloc.h>
+#include <rtems/score/heapimpl.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @brief Initializes the separate C Program Heap with support for more than
+ * one memory area.
+ * This implementation should be used by BSPs which provide more than one
+ * memory area via _Memory_Get() to implement
+ * _Workspace_Malloc_initialize_separate().
+RTEMS_INLINE_ROUTINE Heap_Control *_Malloc_Initialize_for_many_areas(
+ Heap_Control *heap
+ const Memory_Information *mem;
+ Heap_Initialization_or_extend_handler init_or_extend;
+ uintptr_t page_size;
+ size_t i;
+ mem = _Memory_Get();
+ RTEMS_Malloc_Heap = heap;
+ init_or_extend = _Heap_Initialize;
+ page_size = CPU_HEAP_ALIGNMENT;
+ for (i = 0; i < _Memory_Get_count( mem ); ++i) {
+ Memory_Area *area;
+ uintptr_t space_available;
+ area = _Memory_Get_area( mem, i );
+ space_available = ( *init_or_extend )(
+ heap,
+ _Memory_Get_free_begin( area ),
+ _Memory_Get_free_size( area ),
+ page_size
+ if ( space_available > 0 ) {
+ _Memory_Consume( area, _Memory_Get_free_size( area ) );
+ init_or_extend = _Heap_Extend;
+ if ( init_or_extend == _Heap_Initialize ) {
+ _Internal_error( INTERNAL_ERROR_NO_MEMORY_FOR_HEAP );
+ return heap;
+#ifdef __cplusplus
+#endif
+#endif /* _RTEMS_MALLOCINITMANY_H */
diff --git a/cpukit/include/rtems/mallocinitone.h b/cpukit/include/rtems/mallocinitone.h
index 0000000000..eaa0d8eb3e
--- /dev/null
+++ b/cpukit/include/rtems/mallocinitone.h
@@ -0,0 +1,90 @@
+ * @file
+ * _Malloc_Initialize_for_one_area().
+ * are met:
+#ifndef _RTEMS_MALLOCINITONE_H
+#define _RTEMS_MALLOCINITONE_H
+#include <rtems/score/assert.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @brief Initializes the separate C Program Heap with support for exactly one
+ * memory area.
+ * This implementation should be used by BSPs which provide exactly one memory
+ * area via _Memory_Get() to implement _Workspace_Malloc_initialize_separate().
+RTEMS_INLINE_ROUTINE Heap_Control *_Malloc_Initialize_for_one_area(
+ _Assert( _Memory_Get_count( mem ) == 1 );
+ area = _Memory_Get_area( mem, 0 );
+ space_available = _Heap_Initialize(
+ heap,
+ CPU_HEAP_ALIGNMENT
+ } else {
+ return heap;
+#ifdef __cplusplus
+#endif
+#endif /* _RTEMS_MALLOCINITONE_H */
diff --git a/cpukit/libcsupport/src/malloc_initialize.c b/cpukit/libcsupport/src/malloc_initialize.c
deleted file mode 100644
index fb0999df01..0000000000
--- a/cpukit/libcsupport/src/malloc_initialize.c
+++ /dev/null
@@ -1,81 +0,0 @@
- * @file
- * @brief RTEMS_Malloc_Initialize() implementation.
- * COPYRIGHT (c) 1989-2012.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems/malloc.h>
-#include <rtems/score/wkspace.h>
-#include "malloc_p.h"
-#ifdef RTEMS_NEWLIB
-static Heap_Control _Malloc_Heap;
- Heap_Control *heap;
- Heap_Initialization_or_extend_handler init_or_extend;
- uintptr_t page_size;
- size_t i;
- heap = &_Malloc_Heap;
- RTEMS_Malloc_Heap = heap;
- init_or_extend = _Heap_Initialize;
- page_size = CPU_HEAP_ALIGNMENT;
- for (i = 0; i < _Memory_Get_count( mem ); ++i) {
- Memory_Area *area;
- uintptr_t space_available;
- area = _Memory_Get_area( mem, i );
- space_available = ( *init_or_extend )(
- heap,
- _Memory_Get_free_begin( area ),
- _Memory_Get_free_size( area ),
- page_size
- if ( space_available > 0 ) {
- _Memory_Consume( area, _Memory_Get_free_size( area ) );
- init_or_extend = extend;
- if ( init_or_extend == _Heap_Initialize ) {
- _Internal_error( INTERNAL_ERROR_NO_MEMORY_FOR_HEAP );
- return heap;
-#else
- /* FIXME: Dummy function */
- return NULL;
-#endif
-Heap_Control *_Workspace_Malloc_initialize_separate( void )
- return RTEMS_Malloc_Initialize( _Memory_Get(), _Heap_Extend );
diff --git a/cpukit/libcsupport/src/mallocheap.c b/cpukit/libcsupport/src/mallocheap.c
index 006362f209..ec14e73763 100644
--- a/cpukit/libcsupport/src/mallocheap.c
+++ b/cpukit/libcsupport/src/mallocheap.c
@@ -44,7 +44,7 @@
-static void _Malloc_Initialize( void )
RTEMS_Malloc_Heap = ( *_Workspace_Malloc_initializer )();
diff --git a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
index 7fe74074f2..fdaa7f7455 100644
--- a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
+++ b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
@@ -139,6 +139,7 @@ source:
- bsps/shared/irq/irq-default-handler.c
- bsps/shared/start/bsp-fdt.c
- bsps/shared/start/gettargethash-default.c
+- bsps/shared/start/mallocinitmany.c
- bsps/shared/start/sbrk.c
- bsps/shared/start/stackalloc.c
- bsps/shared/start/wkspaceinitmany.c
diff --git a/spec/build/bsps/i386/pc386/obj.yml b/spec/build/bsps/i386/pc386/obj.yml
index 692e2df1cc..308dbe5ea9 100644
--- a/spec/build/bsps/i386/pc386/obj.yml
+++ b/spec/build/bsps/i386/pc386/obj.yml
@@ -80,6 +80,7 @@ source:
- bsps/shared/start/bspfatal-default.c
+- bsps/shared/start/mallocinitone.c
- bsps/shared/start/wkspaceinitone.c
type: build
diff --git a/spec/build/bsps/objmem.yml b/spec/build/bsps/objmem.yml
index 6c72bc3f65..ff6a0937f1 100644
--- a/spec/build/bsps/objmem.yml
+++ b/spec/build/bsps/objmem.yml
@@ -11,5 +11,6 @@ install: []
links: []
source:
- bsps/shared/start/bspgetworkarea-default.c
type: build
diff --git a/spec/build/bsps/powerpc/mpc55xxevb/obj.yml b/spec/build/bsps/powerpc/mpc55xxevb/obj.yml
index 0eadb0e28d..bb2bb1b8be 100644
--- a/spec/build/bsps/powerpc/mpc55xxevb/obj.yml
+++ b/spec/build/bsps/powerpc/mpc55xxevb/obj.yml
@@ -94,6 +94,7 @@ source:
type: build
diff --git a/spec/build/bsps/powerpc/objmem.yml b/spec/build/bsps/powerpc/objmem.yml
index 1fbb8b4fb0..3ef079ee72 100644
--- a/spec/build/bsps/powerpc/objmem.yml
+++ b/spec/build/bsps/powerpc/objmem.yml
links: []
source:
- bsps/powerpc/shared/start/bspgetworkarea.c
type: build
diff --git a/spec/build/bsps/powerpc/tqm8xx/obj.yml b/spec/build/bsps/powerpc/tqm8xx/obj.yml
index 7aec916350..360e99c864 100644
--- a/spec/build/bsps/powerpc/tqm8xx/obj.yml
+++ b/spec/build/bsps/powerpc/tqm8xx/obj.yml
@@ -46,6 +46,7 @@ source:
- bsps/shared/start/bspreset-empty.c
type: build
diff --git a/spec/build/bsps/sparc/objmem.yml b/spec/build/bsps/sparc/objmem.yml
index d4ded7b226..071a7473b4 100644
--- a/spec/build/bsps/sparc/objmem.yml
+++ b/spec/build/bsps/sparc/objmem.yml
@@ -10,6 +10,7 @@ includes: []
install: []
links: []
source:
- bsps/sparc/shared/start/bspgetworkarea.c
type: build
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index b6b3a09c2b..319ea26e4d 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -675,7 +675,6 @@ source:
- cpukit/libcsupport/src/malloc.c
- cpukit/libcsupport/src/malloc_deferred.c
- cpukit/libcsupport/src/malloc_dirtier.c
-- cpukit/libcsupport/src/malloc_initialize.c
- cpukit/libcsupport/src/malloc_walk.c
- cpukit/libcsupport/src/mallocdirtydefault.c
- cpukit/libcsupport/src/mallocextenddefault.c
diff --git a/testsuites/libtests/malloc04/init.c b/testsuites/libtests/malloc04/init.c
index 51d318850b..8f05c63a79 100644
--- a/testsuites/libtests/malloc04/init.c
+++ b/testsuites/libtests/malloc04/init.c
@@ -78,16 +78,23 @@ rtems_task Init(
Heap_Control *real_heap;
- Memory_Area area;
- Memory_Information mem = {
- .count = 1,
- .areas = &area
+ size_t i;
void *p;
TEST_BEGIN();
+ for ( i = 0; i < _Memory_Get_count( mem ); ++i ) {
+ _Memory_Initialize( area, NULL, NULL );
/* Safe information on real heap */
real_heap = malloc_get_heap_pointer();
malloc_set_heap_pointer( &TempHeap );
@@ -98,8 +105,8 @@ rtems_task Init(
sbrk_count = 0;
offset = 256;
- _Memory_Initialize_by_size( &area, &Malloc_Heap[ 0 ], offset );
- RTEMS_Malloc_Initialize( &mem, NULL );
+ _Memory_Initialize_by_size( area, &Malloc_Heap[ 0 ], offset );
+ _Malloc_Initialize();
errno = 0;
p = malloc( 256 );
@@ -113,8 +120,8 @@ rtems_task Init(
sbrk_count = 0;
offset = 256;
p = malloc(1);
rtems_test_assert( p != NULL );
@@ -128,8 +135,8 @@ rtems_task Init(
sbrk_count = 0;
offset = 256;
errno = 0;
p = malloc( sizeof( Malloc_Heap ) );
@@ -141,8 +148,8 @@ rtems_task Init(
sbrk_count = 0;
offset = 256;
p = malloc( 128 );
@@ -156,8 +163,8 @@ rtems_task Init(
sbrk_count = -1;
offset = 256;
errno = 0;
p = malloc( 256 );
2.31.1
