RSB Failure
Ryan Long ral051 at oarcorp.com
Tue Nov 30 16:07:51 UTC 2021
I forgot to mention that I'm using Ubuntu21.04. It has the
ca-certificates package installed. Is there maybe another package that
it might need? This worked fine when I did a run with RTEMS 6.
On 11/30/2021 9:26 AM, Karel Gardas wrote:
> I think you are right about certs issue:
> download: no ssl context
> suggest the same probably. But, it looks like everything is fine on the
> server side:
> $ openssl s_client -connect git.rtems.org:443
> CONNECTED(00000003)
> depth=2 C = US, O = Internet Security Research Group, CN = ISRG Root X1
> verify return:1
> depth=1 C = US, O = Let's Encrypt, CN = R3
> verify return:1
> depth=0 CN = git.rtems.org
> verify return:1
> Certificate chain
>   0 s:CN = git.rtems.org
>     i:C = US, O = Let's Encrypt, CN = R3
>   1 s:C = US, O = Let's Encrypt, CN = R3
>     i:C = US, O = Internet Security Research Group, CN = ISRG Root X1
>   2 s:C = US, O = Internet Security Research Group, CN = ISRG Root X1
>     i:O = Digital Signature Trust Co., CN = DST Root CA X3
> Server certificate
> -----BEGIN CERTIFICATE-----
> MIIFHjCCBAagAwIBAgISA0PbLsmtHvaISDhLE5hsvRdCMA0GCSqGSIb3DQEBCwUA
> MDIxCzAJBgNVBAYTAlVTMRYwFAYDVQQKEw1MZXQncyBFbmNyeXB0MQswCQYDVQQD
> EwJSMzAeFw0yMTEwMjQxMjQ2NTVaFw0yMjAxMjIxMjQ2NTRaMBgxFjAUBgNVBAMT
> DWdpdC5ydGVtcy5vcmcwggEiMA0GCSqGSIb3DQEBAQUAA4IBDwAwggEKAoIBAQCp
> e+uIGW+YEHayckij6bxbigwqs+0dcvG7y+bGkgHAMbzKqyLvH0eowpHfLuxwU6PZ
> 4zsmi7Wt/nnzLFsT+G+goCa+4PoXv7e4HIyvRbRrQlcffBAoqjtR4NbjX2aPPBqa
> r5KPg1NoE713VwB1TQId9+l1hy+bZESMu9t/ereC8FqLihfXynHdRRRmLbu9Y6Pu
> TrQspRE1BzQCg5p3C4Pw94JSp//VDeH4njDdksRnrrgBGQ5aT/5pv9N/dmP+mjd4
> Um0PewQ1I1luOzGGcIV5vtHqqLNnxA2M8m7vMGhy0hJ2I3S6t1JXBilX9kg1qEPo
> pGwBfxTWPM1WRmdpSAc5AgMBAAGjggJGMIICQjAOBgNVHQ8BAf8EBAMCBaAwHQYD
> VR0lBBYwFAYIKwYBBQUHAwEGCCsGAQUFBwMCMAwGA1UdEwEB/wQCMAAwHQYDVR0O
> BBYEFBQ5XKKYcDqC5Z2oomD50z8b7rKrMB8GA1UdIwQYMBaAFBQusxe3WFbLrlAJ
> QOYfr52LFMLGMFUGCCsGAQUFBwEBBEkwRzAhBggrBgEFBQcwAYYVaHR0cDovL3Iz
> Lm8ubGVuY3Iub3JnMCIGCCsGAQUFBzAChhZodHRwOi8vcjMuaS5sZW5jci5vcmcv
> MBgGA1UdEQQRMA+CDWdpdC5ydGVtcy5vcmcwTAYDVR0gBEUwQzAIBgZngQwBAgEw
> NwYLKwYBBAGC3xMBAQEwKDAmBggrBgEFBQcCARYaaHR0cDovL2Nwcy5sZXRzZW5j
> cnlwdC5vcmcwggECBgorBgEEAdZ5AgQCBIHzBIHwAO4AdQDfpV6raIJPH2yt7rhf
> Tj5a6s2iEqRqXo47EsAgRFwqcwAAAXyyjeKEAAAEAwBGMEQCIGdxPoInCappGYjS
> Q5GX0c7V/k3zNUoUdbsXC+34NrwvAiB1RYRmgn9h5h7bach9x0HyVKYBICaTiSvu
> Fdwa0FdSrwB1ACl5vvCeOTkh8FZzn2Old+W+V32cYAr4+U1dJlwlXceEAAABfLKN
> 4nQAAAQDAEYwRAIgW3QfcFdvFLMG+eDgizx2sHiidWGB1Ozg4NryjWtToMACIDSc
> pGhubVCBQN1L4Fd6lYw0NYp4DxEA08+GQUZcsf7sMA0GCSqGSIb3DQEBCwUAA4IB
> AQAaSfA+yhmWQPEJXx/HrSlF0SXYQIGpynBYTGkRgENBvlGBQeuPKpMFc0QnnLsE
> sFJ3JMgrkEsU28KZivELPZfmd4i3is6ild3l4DYONO67L4Y1By7V2S6AzVhWdp3c
> gZHgmr9+I6dNBOR8n5LpDmqY//8YbHYwRa1jaFXC9TNwKU/aJu6Yw167xFZVP3C1
> 3KPLByARgC8428nNOR6WUzFkfsKPgslaA5XS6CewaleSc5wEZWZHSXAgpKwsf7yT
> Orpvs0AgMy14iAZMUzJAIcdwrhXNXPDX/0U/x3ZisV/2pTDeRFET70IwUpBEgJ9O
> wekZTREGgLUAPxD/zwNU8ApC
> -----END CERTIFICATE-----
> subject=CN = git.rtems.org
> issuer=C = US, O = Let's Encrypt, CN = R3
> No client certificate CA names sent
> Peer signing digest: SHA256
> Peer signature type: RSA
> Server Temp Key: ECDH, P-256, 256 bits
> SSL handshake has read 4752 bytes and written 471 bytes
> Verification: OK
> New, TLSv1.2, Cipher is ECDHE-RSA-AES128-SHA256
> Server public key is 2048 bit
> Secure Renegotiation IS supported
> Compression: NONE
> Expansion: NONE
> No ALPN negotiated
> SSL-Session:
>      Protocol  : TLSv1.2
>      Cipher    : ECDHE-RSA-AES128-SHA256
>      Session-ID:
> D0CB98B91EE36A3AC90D0EDBA7FDE066E5A48EC940549A8EC0BA2E922DD34618
>      Session-ID-ctx:
>      Master-Key:
> 5675E199AB067347223245EAEBB6C59896AA25858222C9DEEDD3E35927539E592974EE705A1C3DC40FA60E9F288B5F71
>      PSK identity: None
>      PSK identity hint: None
>      SRP username: None
>      TLS session ticket lifetime hint: 300 (seconds)
>      TLS session ticket:
>      0000 - ab c1 dc e5 3f 92 28 3e-65 d9 ef 95 08 a5 26 cf
> ....?.(>e.....&.
>      0010 - c9 d8 4a e9 22 2d be e6-24 f2 e7 0b 96 54 57 a9
> ..J."-..$....TW.
>      0020 - 9e 39 ab ba 3e 00 2a 1c-1a 5d bb d1 6f a3 4e e7
> .9..>.*..]..o.N.
>      0030 - 37 54 78 84 52 26 48 ba-1e ae 30 01 c2 0e ca 4c
> 7Tx.R&H...0....L
>      0040 - 19 b1 86 4a f2 67 7c 15-d7 20 5a c6 79 f9 34 67   ...J.g|..
> Z.y.4g
>      0050 - d2 28 ae bf e5 45 c5 97-db dc ad 77 98 49 33 82
> .(...E.....w.I3.
>      0060 - 02 13 3e e1 de c6 be 7d-b1 0e 9c 9d 4a 90 da 84
> ..>....}....J...
>      0070 - 34 bc 4d d6 38 08 af 2e-34 26 6a 9f cf 8a f6 6a
> 4.M.8...4&j....j
>      0080 - 91 e2 1d 00 74 26 d7 63-25 8e 6f af 89 3d 96 ed
> ....t&.c%.o..=..
>      0090 - dd 25 66 50 ea 0d f1 8a-52 17 58 40 8c 11 6c 08
> .%fP....R.X at ..l.
>      00a0 - 66 4c ff f7 10 79 2a fb-9f 49 d3 76 b0 c9 50 93
> fL...y*..I.v..P.
>      00b0 - f7 40 48 b9 ae 15 2e 4e-08 6a 1c f1 d2 70 54 e2
> . at H....N.j...pT.
>      00c0 - eb 86 2a ab f9 05 c3 94-3b 4e c3 47 47 46 b1 74
> ..*.....;N.GGF.t
>      Start Time: 1638285819
>      Timeout   : 7200 (sec)
>      Verify return code: 0 (ok)
>      Extended master secret: no
> closed
> so the issue seems to be on the client side. By any chance have you
> forgotten to install your OS/distro certificates package? You need that
> in order to verify server cert chain...
> Karel
> On 11/30/21 3:07 PM, Ryan Long wrote:
>> Hi,
>> I'm trying to do a forced build of all of the tools and BSPs for RTEMS
>> 5, but I'm getting this error.
>> script: 86: source_dir_rtems_tools=${rtems_tools_source}
>> source setup: rtems-tools-0a5d2057749066e7d184836e92c7ce5334fccc90-1:
>> source rtems-tools -q -n ${rtems_tools_source}
>> making dir: /home/tester/rtems-cron-5/rtems-source-builder/rtems/sources
>> download: (full)
>> https://git.rtems.org/rtems-tools/snapshot/rtems-tools-0a5d2057749066e7d184836e92c7ce5334fccc90.tar.bz2
>> -> sources/rtems-tools-0a5d2057749066e7d184836e92c7ce5334fccc90.tar.bz2
>> download:
>> https://git.rtems.org/rtems-tools/snapshot/rtems-tools-0a5d2057749066e7d184836e92c7ce5...<see
>> log> ->
>> download:
>> log>: error: <urlopen error [Errno 0] Error>
>> error: downloading
>> https://git.rtems.org/rtems-tools/snapshot/rtems-tools-0a5d2057749066e7d184836e92c7ce5334fccc90.tar.bz2:
>> all paths have failed, giving up
>> "rsb-report-rtems-tools-0a5d2057749066e7d184836e92c7ce5334fccc90-1.txt"
>> [noeol] 407L, 32689B
>> Yesterday, it was failing to pull in some patches from a ticket because
>> the certificates had expired, but I'm not sure if this is the same
>> issue. I was able to get this tarball with wget.
>> Does anyone know what the issue might be?
>> Thanks,
>> Ryan
>> devel mailing list
>> devel at rtems.org
