[PATCH v2 2/6] cpukit: Add Exception Manager
    Sebastian Huber
    Fri Oct  1 13:29:25 UTC 2021
On 01/10/2021 06:39, Gedare Bloom wrote:
> You also might separate the exception manager addition away from the
> topic of recoverable exceptions. This introduces/extends the classic
> API, so it needs to be vetted carefully. Although the new header
> claims to be a classic API, it appears to not follow classic API
> conventions. You might need to think about what needs to be exposed to
> the application level, and how, versus what should be internal. And
> follow the conventions for classic API usage (e.g., opaque types not
> pointers).
Yes, the <rtems/*.h> is reserved for API header files. The
architecture-independent implementation part (Exception Handler) should
go to <rtems/score/*.h>. The architecture-dependent part should go in
<rtems/score/cpuimpl.h>.  If something really (!) needs to be visible to
the API, then it should go in <rtems/score/cpu.h>. The
architecture-dependent parts should be documented in the no_cpu header
files.
Please make the architecture-dependent interface more abstract. From my
point of view your current approach contains to many details of the
aarch64 port.
There should be documentation in the RTEMS CPU Supplement with a status
for each architecture (similar to the TLS support).
At the moment I only see one API element and this is the new application
configuration option.
If you really need new rtems_* interfaces, then please add a proper
documentation for them so that it could be included in the RTEMS Classic
API Guide. I would prefer to wait with new API elements until at this is
implemented on at least another architecture.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
