Workspace Initialization Faliure Bug
Sebastian Huber
Fri Oct 1 17:10:02 UTC 2021
On 01/10/2021 16:27, Joel Sherrill wrote:
> On Fri, Oct 1, 2021, 8:42 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 01/10/2021 00:38, Joel Sherrill wrote:
> > I think in this configuration, the workspace is essentially unneeded
> > but has to be able to be initialized. It shows that the static
> > allocation work has succeeded in trimming the workspace at least. But
> > now we have to account for an empty one. :)
> Did you get this error with an unmodified master branch?
> Not yet. I am updating to 5 first since the last released version was from a
> pre-branching spot and the decision was made to move to the release
> branch.
> I am hoping to get it updated to where we can more easily track the
> master but there are a few things ahead of that.
I would update to the master. We should be close to an RTEMS 6 release.
Our pre-qualification activity is nearly done.
> Why is the workspace initialized? I tried to arrange everything so that
> the workspace doesn't get initialized if it is not needed. What pulled
> in the workspace initialization?
> Looking at the map from ticker, it looks like it comes from
> malloc_initialize.c
> ./../../cpukit/librtemscpu.a(wkspace.o)
> ./../../cpukit/librtemscpu.a(malloc_initialize.o) (_Workspace_Area)
> ./../../cpukit/librtemscpu.a(wkspaceisunifieddefault.o)
> ./../../cpukit/librtemscpu.a(malloc_initialize.o) (_Workspace_Is_unified)
> And malloc_initialize.c looks different in 5 versus master.
> I don't want to get into pulling back a LOT of code. If there is a small
> patch
> set that can be backported, I'm ok with that. But a simple fix to let it
> have a
> minimum workspace is safe and simple on 5.
> But this can really occur on 5 so we need at least a fix there.
Back porting things in the workspace and confdefs.h area will be difficult.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
