[PATCH] rtems: Generate <rtems/cpuuse.h>
Sebastian Huber
Fri Oct 1 17:36:51 UTC 2021
Write the documentation from scratch.
cpukit/include/rtems/cpuuse.h | 217 ++++++++++++++++++++++++++++------
1 file changed, 178 insertions(+), 39 deletions(-)
diff --git a/cpukit/include/rtems/cpuuse.h b/cpukit/include/rtems/cpuuse.h
index 50c986671d..da51e9708a 100644
--- a/cpukit/include/rtems/cpuuse.h
+++ b/cpukit/include/rtems/cpuuse.h
@@ -1,87 +1,226 @@
* @file
* @ingroup libmisc_cpuuse
- * @brief CPU Usage Report
+ * @brief This header file provides the CPU usage reporting API.
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
- * This include file contains information necessary to utilize
- * and install the cpu usage reporting mechanism.
- * COPYRIGHT (c) 1989-2011.
- * On-Line Applications Research Corporation (OAR).
+ * This file is part of the RTEMS quality process and was automatically
+ * generated. If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual. The manual is provided as a part of
+ * a release. For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
-#ifndef __RTEMS_CPUUSE_h
-#define __RTEMS_CPUUSE_h
+/* Generated from spec:/rtems/cpuuse/if/header */
-#include <rtems.h>
-#include <rtems/print.h>
+#ifndef _RTEMS_CPUUSE_H
+#define _RTEMS_CPUUSE_H
- * @defgroup libmisc_cpuuse CPU Usage
- * @ingroup RTEMSAPIClassic
#ifdef __cplusplus
extern "C" {
#endif
- * rtems_cpu_usage_report_with_handler
+/* Generated from spec:/rtems/cpuuse/if/group */
+ * @defgroup libmisc_cpuuse CPU Usage Reporting
+ * @ingroup RTEMSAPI
+ * @brief The CPU usage reporting directives can be used to report and reset
+ * the CPU usage of threads.
-void rtems_cpu_usage_report_with_plugin( const rtems_printer *printer );
+/* Generated from spec:/rtems/cpuuse/if/printer */
+/* Forward declaration */
+struct rtems_printer;
+/* Generated from spec:/rtems/cpuuse/if/cpu-info-report */
- * @brief Report CPU usage.
+ * @ingroup libmisc_cpuuse
+ * @brief Reports the CPU information using the printer plugin.
+ * @param printer is the printer plugin to output the report.
- * CPU Usage Reporter
+ * @par Constraints
+ * @parblock
+ * The following constraints apply to this directive:
+ * * The directive may be called from within any runtime context.
+ * * The directive will not cause the calling task to be preempted.
+ * @endparblock
+int rtems_cpu_info_report( const struct rtems_printer *printer );
+/* Generated from spec:/rtems/cpuuse/if/report */
+ * @brief Reports the CPU usage of each thread using the printk() printer.
+ * @par Notes
+ * See also rtems_cpu_usage_report_with_plugin().
+ * @parblock
+ * * The directive may be called from within device driver initialization
+ * context.
+ * * The directive may be called from within task context.
+ * * The directive may obtain and release the object allocator mutex. This may
+ * cause the calling task to be preempted.
+ * @endparblock
void rtems_cpu_usage_report( void );
+/* Generated from spec:/rtems/cpuuse/if/report-with-plugin */
- * @brief CPU usage Top plugin
+ * @brief Reports the CPU usage of each thread using the printer plugin.
- * Report CPU Usage in top format to
- * to a print plugin.
+ * @parblock
+ * context.
+ * @endparblock
-void rtems_cpu_usage_top_with_plugin( const rtems_printer *printer );
+void rtems_cpu_usage_report_with_plugin( const struct rtems_printer *printer );
+/* Generated from spec:/rtems/cpuuse/if/reset */
- * @brief CPU usage top.
+ * @brief Resets the CPU usage of each thread.
+ * @parblock
+ * context.
- * CPU Usage top
+ * @endparblock
+void rtems_cpu_usage_reset( void );
-void rtems_cpu_usage_top( void );
+/* Generated from spec:/rtems/cpuuse/if/top */
- * @brief Reset CPU usage.
+ * @brief Starts an interactive CPU usage reporting using the printk() printer.
+ * @par Notes
+ * See also rtems_cpu_usage_top_with_plugin().
+ * @parblock
+ * * The directive sends a request to another task and waits for a response.
+ * This may cause the calling task to be blocked and unblocked.
+ * @endparblock
+void rtems_cpu_usage_top( void );
-void rtems_cpu_usage_reset( void );
+/* Generated from spec:/rtems/cpuuse/if/top-with-plugin */
- * @brief Reports per-processor information.
- * @return The number of characters printed.
+ * @brief Starts an interactive CPU usage reporting using the printer plugin.
+ * @par Notes
+ * The directive starts a task to do the reporting. The getchar() function is
+ * used to get commands from the user.
+ * @parblock
+ * @endparblock
-int rtems_cpu_info_report( const rtems_printer *printer );
+void rtems_cpu_usage_top_with_plugin( const struct rtems_printer *printer );
#ifdef __cplusplus
#endif
-#endif
-/* end of include file */
+#endif /* _RTEMS_CPUUSE_H */
2.26.2
