[PATCH v2 2/6] cpukit: Add Exception Manager
Sebastian Huber
Mon Oct 4 17:51:35 UTC 2021
On 01/10/2021 21:39, Kinsey Moore wrote:
> Sebastian,
> Could you be more specific about which parts of the
> architecture-dependent interface still seem tied to the AArch64 port? I
> thought I had made them sufficiently abstract by relying on
> architecture-specific functions to manipulate and take action on the
> exception frame. The signal mapping code written on top of this should
> work for any architecture that implements those functions and contains
> no reliance on architecture that I can see. The set of exception classes
> in particular includes exceptions that don't exist on AArch64, but were
> added because they're known to be present on SPARC and need to be
> handled. I'm only really familiar with ARM and AArch64, so that could be
> why I'm missing it.
I would provide a new CPU feature flag
#define CPU_HAS_EXCEPTION_TO_SIGNAL_MAPPING TRUE|FALSE
If it is TRUE, then the CPU port shall provide:
* @retval -1 There is no signal associated with the exception.
* @retval SIGSEGV, SIGFPE, ...
int _CPU_Exception_frame_get_signal( const CPU_Exception_frame *frame );
RTEMS_NO_RETURN _CPU_Exception_resume( CPU_Exception_frame *frame );
The architecture-independent part just needs to provide a fatal extension:
_Thread_local Thread_Action _Exception_Raise_signal_action;
void _Exception_Raise_signal( source, true, code )
int sig;
if ( source != RTEMS_FATAL_SOURCE_EXCEPTION ) {
return;
sig = _CPU_Exception_frame_get_signal( code );
switch ( sig ) {
case SIGSEGV:
handler = _Exception_Raise_sigsegv;
break;
default:
return;
_Thread_Prepend_post_switch_action( executing,
&_Exception_Raise_signal_action, handler );
_CPU_Exception_resume( code );
Using a post-switch extension has the benefit that you don't have to
call the complicated raise() function in the exception context. It is
called in thread context.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
