[RTEMS 5 v2] Add support for IDLE Thread stack allocator
Wed Oct 6 05:19:23 UTC 2021
> + * If the application wants to provide an IDLE threads stack allocator, it
> + * must also provide a custom allocator/deallocator for user thread stacks.
> +#elif (!defined(CONFIGURE_TASK_STACK_ALLOCATOR) \
> +  && !defined(CONFIGURE_TASK_STACK_DEALLOCATOR)) \
> +  && defined(CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE)
> +  #error "CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE can only be provided if both CONFIGURE_TASK_STACK_ALLOCATOR and CONFIGURE_TASK_STACK_DEALLOCATOR are provided"
>   #endif
Is this really a hard error? The allocators are independent.
>   #ifdef CONFIGURE_DIRTY_MEMORY
> diff --git a/cpukit/include/rtems/config.h b/cpukit/include/rtems/config.h
> index e82c7abf11..a826581658 100644
> --- a/cpukit/include/rtems/config.h
> +++ b/cpukit/include/rtems/config.h
> @@ -129,6 +129,9 @@ uint32_t rtems_configuration_get_maximum_extensions( void );
>   #define rtems_configuration_get_stack_free_hook() \
>     (_Stack_Allocator_free)
> +#define rtems_configuration_get_stack_allocate_for_idle_hook() \
> +  (_Stack_Allocator_allocate_for_idle)
>     * This macro assists in accessing the field which indicates whether
>     * RTEMS is responsible for zeroing the Executive Workspace.
> diff --git a/cpukit/include/rtems/score/stack.h b/cpukit/include/rtems/score/stack.h
> index df1df74867..6b20d4b977 100644
> --- a/cpukit/include/rtems/score/stack.h
> +++ b/cpukit/include/rtems/score/stack.h
> @@ -23,6 +23,7 @@
>   #define _RTEMS_SCORE_STACK_H
>   #include <rtems/score/basedefs.h>
> +#include <rtems/score/percpu.h>
Please do not include this header in an header visible to the API.
>   #ifdef __cplusplus
>   extern "C" {
> @@ -81,6 +82,23 @@ typedef void *( *Stack_Allocator_allocate )( size_t stack_size );
>   typedef void ( *Stack_Allocator_free )( void *addr );
> + * @brief Stack allocator allocate for idle handler.
> + * The allocate for idle handler is optional even when the user thread stack
> + * allocator and deallocator are configured.
> + * @param cpu Information for the CPU for the IDLE thread using this stack
> + * @param stack_size The size of the stack area to allocate in bytes.
> + * @retval NULL Not enough memory.
> + * @retval other Pointer to begin of stack area.
> +typedef void *( *Stack_Allocator_allocate_for_idle )(
> +  Per_CPU_Control *cpu,
Please use
uint32_t cpu_index
instead.
> +  size_t           stack_size
>    * @brief The minimum stack size.
> @@ -124,6 +142,30 @@ extern const Stack_Allocator_allocate _Stack_Allocator_allocate;
>   extern const Stack_Allocator_free _Stack_Allocator_free;
> + * @brief The stack allocator allocate stack for idle thread handler.
> + * Application provided via <rtems/confdefs.h>.
> +extern const Stack_Allocator_allocate_for_idle
> +  _Stack_Allocator_allocate_for_idle;
> + * @brief Default stack allocator allocate for idle handler.
> +void *_Stack_Allocator_allocate_for_idle_default(
> +  size_t           stack_size
>   #ifdef __cplusplus
> diff --git a/cpukit/score/src/stackallocatorforidle.c b/cpukit/score/src/stackallocatorforidle.c
> new file mode 100644
> index 0000000000..d33cd4dbf5
> --- /dev/null
> +++ b/cpukit/score/src/stackallocatorforidle.c
> @@ -0,0 +1,36 @@
> + * SPDX-License-Identifier: BSD-2-Clause
> + * Copyright (C) 2021 OAR Corporation
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <rtems/score/stack.h>
> +#include <rtems/score/wkspace.h>
Why the wkspace.h include?
> +const Stack_Allocator_allocate_for_idle _Stack_Allocator_allocate_for_idle =
> +        _Stack_Allocator_allocate_for_idle_default;
Please move the definition to this file and make
_Stack_Allocator_allocate_for_idle_default() static.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
