[RTEMS Docs 5 v2] task-stack-alloc.rst: Add CONFIGURE_TASK_STACK_FROM_ALLOCATOR
Joel Sherrill
joel at rtems.org
Thu Oct 7 21:32:06 UTC 2021
Updates #4520.
c-user/config/task-stack-alloc.rst | 36 +++++++++++++++++++++++++++++++++++-
1 file changed, 35 insertions(+), 1 deletion(-)
diff --git a/c-user/config/task-stack-alloc.rst b/c-user/config/task-stack-alloc.rst
index 297c624..a779c9f 100644
--- a/c-user/config/task-stack-alloc.rst
+++ b/c-user/config/task-stack-alloc.rst
@@ -1,7 +1,7 @@
.. SPDX-License-Identifier: CC-BY-SA-4.0
.. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
-.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+.. Copyright (C) 1988, 2008, 2021 On-Line Applications Research Corporation (OAR)
Task Stack Allocator Configuration
@@ -171,3 +171,37 @@ DESCRIPTION:
NOTES:
This configuration option may be used if a custom task stack allocator is
configured, see :ref:`CONFIGURE_TASK_STACK_ALLOCATOR`.
+.. index:: _CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE
+.. index:: IDLE task stack allocator
+.. _CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE:
+CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE
+CONSTANT:
+ ``CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE``
+OPTION TYPE:
+ This configuration option is an initializer define.
+DEFAULT VALUE:
+ The default value is ``_Stack_Allocator_allocate_for_idle``, which
+ indicates that IDLE task stacks will be allocated from an area statically
+ reserved by `<rtems/confdefs.h>``.
+VALUE CONSTRAINTS:
+ The value of this configuration option shall be defined to a valid
+ function pointer of the type ``void *( *allocate )( uint32_t, size_t )``.
+DESCRIPTION:
+ The value of this configuration option is the address for the the
+ IDLE stack allocator allocate handler.
+NOTES:
+ This configuration option is independent of the other thread stack allocator
+ configuration options. It is assumed that any memory allocated for IDLE
+ task stacks will not be from the RTEMS Workspace or the memory statically
+ reserved by default.
1.8.3.1
