[PATCH 0/1] Implement clockrdlock / clockwrlock and test
Matt Joyce
mfjoyce2004 at gmail.com
Fri Oct 8 13:22:58 UTC 2021
Hello,
Please find the attached implementions of pthread_rwlock_clockrdlock
and pthread_rwlock_clockwrlock, two newly added POSIX Issue 8
Standard methods. Also included is the psxrwlock02 test, which is
based on the previously existing test for the rwlock_timed*lock
methods.
Thank you!
Matt Joyce (1):
Added implementations of the pthread_rwlock_clockrdlock and the
pthread_rwlock_clockwrlock methods to cpukit/posix/src. Both of
these methods have been newly added to the POSIX Issue 8 Standard.
cpukit/posix/src/prwlockclockrdlock.c | 70 ++
cpukit/posix/src/prwlockclockwrlock.c | 71 ++
spec/build/testsuites/psxtests/grp.yml | 2 +
.../build/testsuites/psxtests/psxrwlock02.yml | 22 +
testsuites/psxtests/Makefile.am | 9 +
testsuites/psxtests/configure.ac | 1 +
testsuites/psxtests/psxrwlock02/main.c | 55 ++
testsuites/psxtests/psxrwlock02/test.c | 784 ++++++++++++++++++
8 files changed, 1014 insertions(+)
create mode 100644 cpukit/posix/src/prwlockclockrdlock.c
create mode 100644 cpukit/posix/src/prwlockclockwrlock.c
create mode 100644 spec/build/testsuites/psxtests/psxrwlock02.yml
create mode 100644 testsuites/psxtests/psxrwlock02/main.c
create mode 100644 testsuites/psxtests/psxrwlock02/test.c
2.31.1
