[PATCH] rtems-gdb-9.1-1.cfg: Add patch for Cygwin
Joel Sherrill
joel at rtems.org
Fri Oct 8 15:21:02 UTC 2021
The patch is needed to address link failures introduced when
Cygwin apparently changed their base address for executables.
This is not an issue with gdb 10 and this is a minimalistic
approach to addressing this failure on the 5 branch.
Closes #4523.
rtems/config/tools/rtems-gdb-9.1-1.cfg | 7 +++++++
1 file changed, 7 insertions(+)
diff --git a/rtems/config/tools/rtems-gdb-9.1-1.cfg b/rtems/config/tools/rtems-gdb-9.1-1.cfg
index 1d14a20..73648c5 100644
--- a/rtems/config/tools/rtems-gdb-9.1-1.cfg
+++ b/rtems/config/tools/rtems-gdb-9.1-1.cfg
@@ -12,4 +12,11 @@
%patch add gdb https://devel.rtems.org/raw-attachment/ticket/4366/gdb-9-1-linker-error-fix.diff
%hash sha512 gdb-9-1-linker-error-fix.diff QAtNCgJsDdfKno+IqHwqRGz1SR3YdTm34ERox2fqpgaGHI6H4GqNfmkJcJaIvSgzNxif24vqWO+bF/Djqa6wNg==
+%if %{_build_os} == win32
+ %if %{_windows_os} == cygwin
+ %patch add gdb https://devel.rtems.org/raw-attachment/ticket/4523/gdb-9-1-thread-local.diff
+ %hash sha512 gdb-9-1-thread-local.diff ln3rFWltmLCzXvRTz4ts/UoeX7MA49oBtkZWWuslpLEIpm7C/lxDG3/xT0GgJ2eQbENknttittCG31UKhUeljg==
+ %endif
+%endif
%include %{_configdir}/gdb-common-1.cfg
2.33.0
