[PATCH] rtems-kernel: Implement kernel recipe using waf
Fri Oct 8 23:44:24 UTC 2021
Hi Ryan,
Thank you for taking this on.
I would like see one addition, a user supplied config.ini file that bypasses any
generated config file. The config needs to match the tool chain being built and
waf will need to complain if it does not but that is not a problem for the RSB
to manage.
On 9/10/21 2:03 am, Ryan Long wrote:
> Closes #4145
>  rtems/config/tools/rtems-kernel-6.cfg      |  8 ++-
>  rtems/config/tools/rtems-kernel-common.cfg | 95 +++++++++++++-----------------
>  2 files changed, 47 insertions(+), 56 deletions(-)
> diff --git a/rtems/config/tools/rtems-kernel-6.cfg b/rtems/config/tools/rtems-kernel-6.cfg
> index f1d0990..edc0eb1 100644
> --- a/rtems/config/tools/rtems-kernel-6.cfg
> +++ b/rtems/config/tools/rtems-kernel-6.cfg
> @@ -2,10 +2,12 @@
>  # RTEMS 5
> -%define rtems_kernel_version 3ec5f20484cc4201e1d7b87844505644533b6148
> -%hash sha512 rtems-kernel-%{rtems_kernel_version}.tar.bz2 \
> -              BjMKrf5n1YR6IpiZrY5TUEzKATPRJxA2/6m6f833DdRu+RyLxccXqA4gHRdVUqFelFNQ3o0XdG4o1naBKYfhkQ==
> +%define rtems_kernel_version 3bb97a30b17b6c138dead3e3a6b329c3b301cdb3
> +%source set rtems_kernel --rsb-file=rtems-kernel-%{rtems_kernel_version}.tar.gz https://codeload.github.com/RTEMS/rtems/tar.gz/%{rtems_kernel_version}
Please use the rtems.org repo.
> +%hash sha512 rtems-kernel-%{rtems_kernel_version}.tar.gz \
> +              m/ogwrJj4X60ewDIbV6WRj1MJa/22gQHQd56XiNMfvCr0nsvcXdkXKAObLIGYIGYfUyEwlVk3SRjjRFkFalDGQ==
>  # The RTEMS build instructions.
> diff --git a/rtems/config/tools/rtems-kernel-common.cfg b/rtems/config/tools/rtems-kernel-common.cfg
> index 157c7a4..38af264 100644
> --- a/rtems/config/tools/rtems-kernel-common.cfg
> +++ b/rtems/config/tools/rtems-kernel-common.cfg
> @@ -38,6 +38,11 @@
>  %define rtems_bsp %{with_rtems_bsp}
> +# Configuration file used with waf
> +%define config_file config-%{_target}-%{rtems_bsp}.ini
>  # If no tools are provided use the prefix.
>  %ifn %{defined with_tools}
> @@ -98,14 +103,6 @@ URL: 	 https://www.rtems.org/
>   %define rtems_posix 0
>  %endif
> -%if %{defined with_rtems_legacy_network}
> - %define rtems_networking 1
> -%endif
> -%if %{defined with_rtems_cxx}
> - %define rtems_cxx 1
>  %if %{defined with_rtems_bspopts}
>   %define bspopts %{with_rtems_bspopts}
>  %endif
> @@ -129,8 +126,10 @@ URL: 	 https://www.rtems.org/
>   %error No RTEMS kernel version defined
>  %endif
> +#%if ! %{defined rtems_kernel}
>  %source set rtems_kernel --rsb-file=%{rtems_kernel_file} \
>                https://git.rtems.org/rtems/snapshot/rtems-%{rtems_kernel_version}.tar.bz2
> +#%endif
>  # Check the various --with/--without options we support. These are
> @@ -151,51 +150,38 @@ URL: 	 https://www.rtems.org/
>  %if %{defined without_rtemsbsp}
>   %error Option --without-rtemsbsp is not supported.
>  %endif
>  %if %{defined without_rtems_tests}
> - %define with_rtems_tests no
> + %define rtems_tests False
> + %define rtems_sample_tests False
>  %endif
>  %if %{defined with_rtems_tests}
>   %if %{with_rtems_tests} == 1
> -  %define with_rtems_tests yes
> +   %define rtems_tests True
> +   %define rtems_sample_tests True
>   %endif
> - %if %{with_rtems_tests} == yes || \
> -     %{with_rtems_tests} == no || \
> -     %{with_rtems_tests} == samples
> -  %define rtems_tests %{with_rtems_tests}
> +  %if %{with_rtems_tests} == samples
>   %endif
>  %endif
>  %if %{defined with_rtems_smp}
>   %define rtems_smp 1
>  %endif
Please raise an error. Users will need to change their set up.
> -%endif
>   %define rtems_bspopts %{with_rtems_bspopts}
>  %endif
> -# If C++ defined for the tool set use it to control RTEMS's setting..
> -%if %{defined enable_cxx}
> - %define rtems_cxx %{enable_cxx}
I think raise an error.
> -%endif
>  # Default set up. Override these in a BSP if you want a
>  # specific setup.
>  %ifn %{defined rtems_posix}
>   %define rtems_posix 1
>  %endif
> -%ifn %{defined rtems_networking}
> - %define rtems_networking 0
> -%endif
> -%ifn %{defined rtems_cxx}
> -%endif
>  %ifn %{defined rtems_tests}
> - %define rtems_tests samples
>  %endif
>  %ifn %{defined rtems_bspopts}
>   %define rtems_bspopts %{nil}
> @@ -213,8 +199,9 @@ URL: 	 https://www.rtems.org/
>      %if %{defined _internal_autotools_path}
>        export PATH="%{_internal_autotools_path}/bin:${PATH}"
>      %endif
> -    ./bootstrap -c
> -    ./rtems-bootstrap
> +    pwd
> +    ls
> +    ./waf distclean
I am not sure this works by itself when you use --out with configure?
This could be ...
  ./waf distclean configure ....
>    %endif
>    cd ..
> @@ -225,32 +212,34 @@ URL: 	 https://www.rtems.org/
>    else
>      build_dir="build"
>    fi
> +  cd ${source_dir_rtems}
> +  cpu=`echo %{_target} | cut -d- -f1`
> +  echo "[${cpu}/%{rtems_bsp}]" > %{config_file}
> +  echo "RTEMS_POSIX_API = %{?rtems_posix:True}%{!?rtems_posix:False}" >> %{config_file}
> +  echo "RTEMS_SMP = %{?rtems_smp:True}%{!?rtems_smp:False}" >> %{config_file}
> +  echo "BUILD_TESTS = %{rtems_tests}" >> %{config_file}
> +  echo "BUILD_SAMPLES = %{rtems_sample_tests}" >> %{config_file}
>    mkdir -p ${build_dir}
> -  cd ${build_dir}
> -  ../${source_dir_rtems}/configure \
> -    --build=%{_build} --host=%{_host} \
> -    --target=%{_target} \
> -    --enable-rtemsbsp="%{rtems_bsp}" \
> -    %{?rtems_cxx:--enable-cxx}%{!?rtems_cxx:--disable-cxx} \
> -    %{?rtems_posix:--enable-posix}%{!?rtems_posix:--disable-posix} \
> -    %{?rtems_networking:--enable-networking}%{!?rtems_networking:--disable-networking} \
> -    %{?rtems_tests:--enable-tests=%{rtems_tests}} \
> -    %{?rtems_smp:--enable-smp} \
> +  ./waf configure \
> +    --rtems-bsps=%{_target}/%{rtems_bsp} \
>      --prefix=%{_prefix} --bindir=%{_bindir} \
> -    --exec-prefix=%{_exec_prefix} \
> -    --includedir=%{_includedir} --libdir=%{_libdir} \
> -    --mandir=%{_mandir} --infodir=%{_infodir} \
> -    %{rtems_bspopts}
> +    --out=b-%{rtems_bsp} \
Why change the build directory?
> +    %{rtems_bspopts} \
Does this work?
> +    --rtems-config=%{config_file}
> -  %{__make} %{?_smp_mflags} all
> -  cd ..
> +  ./waf %{?_smp_mflags}
> +  cd -
>  %install
>    %{__rmdir} $SB_BUILD_ROOT
> -  cd ${build_dir}
> -  %{__make} DESTDIR=$SB_BUILD_ROOT install
> +  ./waf --destdir=$SB_BUILD_ROOT install
>    %if %{rtems_tests} != no
>     %define rtems_test_install %{_target}/%{rtems_bsp}/tests
> @@ -259,4 +248,4 @@ URL: 	 https://www.rtems.org/
>        -exec cp -v \{\} $SB_BUILD_ROOT/%{_prefix}/%{rtems_test_install}/ \;
>    %endif
> -  cd ..
> +  cd -
Why the change?
