Scope of variables flagged by code inspector
Mon Oct 11 11:14:07 UTC 2021
Hello Zack,
On 10/10/2021 20:25, zack leung wrote:
> I recently was invited to look at a new code review tool by Joel. It's used
> to help with reducing technical debt. It suggests various fixes and
> highlights various possible errors. One of them relates to the fact that
> some of the variable scopes and be reduced. For example, we can define
> variables when they are needed not at the beginning of functions. I don't
> know if it matters much. Maybe it helps with memory due to the timing of
> things allocated on the stack.  This also helps with the compiler not
> needing to analyze long lifespans. This also prevents the variable to be
> flagged as uninitialized.
I guess modern compiler don't care about when you define a variable. It
is probably more an issue for the human reader.
> But personally, I feel it's easier to read if we don't change where
> variables are defined. An example of this is found in
> testsuites/mptests/mp09/task1.c. An array called recieve_Buffer could be
> defined later. I'm not sure if this matters much. I want to know your
> input.
Moving the variable to the most local scope is already covered by the
current coding style (I hope). Maybe this needs to be clarified in the
coding style.
 From my point of view we should go one step further and allow the
declaration and preferably also the initialization of local variables as
close to their first use as possible in contrast to only the scope begin.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
