[PATCH] testsuite/spcache01: Clear allocated coherent cache memory
Mon Oct 18 09:37:09 UTC 2021
On 18/10/2021 09:53, Chris Johns wrote:
> On 18/10/21 4:50 pm, Sebastian Huber wrote:
>> On 18/10/2021 07:19,chrisj at rtems.org  wrote:
>>> From: Chris Johns<chrisj at rtems.org>
>>> - Coherent cache memory is used in libbsd for things like descriptors
>>>     and it optionally clears the memory on allocation. Test is works.
>> There is no guarantee that memset() and memcpy() work with cache coherent
>> memory. Such memory areas may disallow misaligned access for example.
> That seems reasonable however this change about testing the implicit
> requirements we have that memset works. LibBSD requires memset works ...
> https://git.rtems.org/rtems-libbsd/tree/rtemsbsd/rtems/rtems-kernel-bus-dma.c?h=6-freebsd-12#n260
Using memset() here could be a bug in libbsd.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
