[PATCH 3/3] bsps/aarch64: use SMC API in bspreset-arm-psci
Kinsey Moore kinsey.moore at oarcorp.com
Mon Oct 18 14:40:38 UTC 2021
Comments below.
On 10/16/2021 15:12, Gedare Bloom wrote:
>   bsps/shared/start/bspreset-arm-psci.c | 20 ++++++++++++++++++++
>   1 file changed, 20 insertions(+)
> diff --git a/bsps/shared/start/bspreset-arm-psci.c b/bsps/shared/start/bspreset-arm-psci.c
> index 215be5c9b5..bafdfe6299 100644
> --- a/bsps/shared/start/bspreset-arm-psci.c
> +++ b/bsps/shared/start/bspreset-arm-psci.c
> @@ -37,9 +37,28 @@
>   #include <bsp.h>
>   #include <bsp/bootcard.h>
> +#if defined( AARCH64_MULTILIB_ARCH_V8 ) || \
> +  defined( AARCH64_MULTILIB_ARCH_V8_ILP32 )
> +#include <rtems/score/aarch64-smc.h>
> +#endif
>   void bsp_reset(void)
>   	uint32_t PSCI_FN_SYSTEM_RESET = 0x84000009;
> +#ifdef BSP_RESET_SMC
> +  (void) _AArch64_SMC_Invoke(
> +      PSCI_FN_SYSTEM_RESET,
> +      0,
> +      0,
> +      0,
> +      0,
> +      0,
> +      0,
> +      0,
> +      0,
> +      NULL
> +#else
>   	__asm__ volatile(
>   #if defined(AARCH64_MULTILIB_ARCH_V8) || defined(AARCH64_MULTILIB_ARCH_V8_ILP32)
>   		"mov x0, %0\n"
> @@ -53,4 +72,5 @@ void bsp_reset(void)
>   #endif
This leaves dead code just above the break in this patch.
>   		: : "r" (PSCI_FN_SYSTEM_RESET)
> +#endif
The existing PSCI functionality was coded such that both ARM and AArch64
could use it in either mode. The way this has been added breaks SMC
conduit functionality on 32-bit ARM for both secondary CPU startup and
system reset.
Kinsey
