[PATCH] rtems/6: Update binutils to 2.37
Mon Oct 18 22:23:15 UTC 2021
Was there something wrong with Ryan's patch to do this? He also bumped
RTEMS 7 tools.
You reviewed it. :)
On Mon, Oct 18, 2021, 5:20 PM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
>  rtems/config/6/rtems-default.bset          |  2 +-
>  rtems/config/tools/rtems-binutils-2.37.cfg | 15 +++++++++++++++
>  2 files changed, 16 insertions(+), 1 deletion(-)
>  create mode 100644 rtems/config/tools/rtems-binutils-2.37.cfg
> diff --git a/rtems/config/6/rtems-default.bset
> b/rtems/config/6/rtems-default.bset
> index 0c07b08..8bf6922 100644
> --- a/rtems/config/6/rtems-default.bset
> +++ b/rtems/config/6/rtems-default.bset
> @@ -12,6 +12,6 @@ devel/expat-2.1.0-1
>  devel/gmp-6.1.0
>  tools/rtems-gdb-10
> -tools/rtems-binutils-2.36
> +tools/rtems-binutils-2.37
>  tools/rtems-gcc-10-newlib-head
>  tools/rtems-tools-6
> diff --git a/rtems/config/tools/rtems-binutils-2.37.cfg
> b/rtems/config/tools/rtems-binutils-2.37.cfg
> new file mode 100644
> index 0000000..3aa7a41
> --- /dev/null
> +++ b/rtems/config/tools/rtems-binutils-2.37.cfg
> @@ -0,0 +1,15 @@
> +%include %{_configdir}/checks.cfg
> +%include %{_configdir}/base.cfg
> +%define binutils_version binutils-2_37
> +%define binutils_external 1
> +%define binutils_expand_name
> sourceware-mirror-binutils-gdb-%{binutils_version}
> +%source set binutils --rsb-file=%{binutils_expand_name}.tar.gz \
> https://codeload.github.com/RTEMS/sourceware-mirror-binutils-gdb/tar.gz/%{binutils_version}
> +%hash sha512 %{binutils_expand_name}.tar.gz \
> NOEmH3J6oPTTA85U8iL5Spb944pgKWv/EHInJOAtA8jY4xigCP2UzYFisfhPawYaQIfjCVICLdpAJU1ybi6UpQ==
> +%define with_deterministic_archives 1
> +%define with_64_bit_bfd 1
> +%include %{_configdir}/binutils-2-1.cfg
> 2.24.1
> devel mailing list
> devel at rtems.org
