[PATCH 1/2] rtems: Regenerate for IDLE task allocator option
Sebastian Huber
Tue Oct 19 14:44:38 UTC 2021
Update #4524.
cpukit/doxygen/appl-config.h | 28 +++++++++++++++++++++++++++-
cpukit/include/rtems/config.h | 30 ++++++++++++++++++------------
2 files changed, 45 insertions(+), 13 deletions(-)
diff --git a/cpukit/doxygen/appl-config.h b/cpukit/doxygen/appl-config.h
index bbeb438bec..c0e5b0b717 100644
--- a/cpukit/doxygen/appl-config.h
+++ b/cpukit/doxygen/appl-config.h
@@ -3,7 +3,7 @@
* Copyright (C) 2019, 2021 embedded brains GmbH (http://www.embedded-brains.de)
* Copyright (C) 2010 Gedare Bloom
- * Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+ * Copyright (C) 1988, 2021 On-Line Applications Research Corporation (OAR)
* modification, are permitted provided that the following conditions
@@ -4671,6 +4671,32 @@
#define CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE
+/* Generated from spec:/acfg/if/task-stack-allocator-for-idle */
+ * @brief This configuration option is an initializer define.
+ * The value of this configuration option is the address for the stack
+ * allocator allocate handler used to allocate the task stack of each IDLE
+ * task.
+ * @par Default Value
+ * The default value is ``_Stack_Allocator_allocate_for_idle_default``, which
+ * indicates that IDLE task stacks will be allocated from an area statically
+ * allocated by ``<rtems/confdefs.h>``.
+ * @par Value Constraints
+ * The value of this configuration option shall be defined to a valid function
+ * pointer of the type ``void *( *allocate )( uint32_t, size_t )``.
+ * @par Notes
+ * This configuration option is independent of the other thread stack allocator
+ * configuration options. It is assumed that any memory allocated for the
+ * stack of an IDLE task will not be from the RTEMS Workspace or the memory
+ * statically allocated by default.
+#define CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE
/* Generated from spec:/acfg/if/task-stack-allocator-init */
diff --git a/cpukit/include/rtems/config.h b/cpukit/include/rtems/config.h
index 7b15bc34a2..32dd662b3e 100644
--- a/cpukit/include/rtems/config.h
+++ b/cpukit/include/rtems/config.h
@@ -10,6 +10,7 @@
+ * Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
* Copyright (C) 2009, 2021 embedded brains GmbH (http://www.embedded-brains.de)
@@ -302,6 +303,23 @@ uint32_t rtems_configuration_get_maximum_extensions( void );
#define rtems_configuration_get_number_of_initial_extensions() \
((uint32_t) _User_extensions_Initial_count)
+/* Generated from spec:/rtems/config/if/get-stack-allocate-for-idle-hook */
+ * @ingroup RTEMSAPIConfig
+ * @brief Gets the thread stack allocator allocate hook used to allocate the
+ * stack of each IDLE task configured for this application.
+ * @return Returns the thread stack allocator allocate hook used to allocate
+ * the stack of each IDLE task configured for this application.
+ * @par Notes
+ * See #CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE.
+#define rtems_configuration_get_stack_allocate_for_idle_hook() \
+ _Stack_Allocator_allocate_for_idle
/* Generated from spec:/rtems/config/if/get-stack-allocate-hook */
@@ -368,18 +386,6 @@ uint32_t rtems_configuration_get_maximum_extensions( void );
#define rtems_configuration_get_stack_free_hook() _Stack_Allocator_free
- * @ingroup RTEMSAPIConfig
- * @brief Gets the IDLE thread stack allocator hook configured for this
- * application.
- * @return Returns the IDLE thread stack allocator hook configured for this
- * application.
-#define rtems_configuration_get_stack_allocate_for_idle_hook() \
- (_Stack_Allocator_allocate_for_idle)
/* Generated from spec:/rtems/config/if/get-stack-space-size */
2.31.1
