[PATCH] spec/aarch64: Enable previously unbuildable tests
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Oct 19 21:15:53 UTC 2021
The spconfig01 and spmisc01 tests were disabled for all AArch64 BSPs due
to a toolchain issue preventing them from compiling correctly. The
binutils version that contains the fix has been released and integrated
into RSB such that these two tests now build and operate correctly.
spec/build/bsps/aarch64/a53/tsta53.yml | 4 ----
spec/build/bsps/aarch64/a72/tsta72.yml | 4 ----
spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml | 4 ----
spec/build/bsps/aarch64/xilinx-versal/tstvck190.yml | 4 ----
spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml | 4 ----
spec/build/bsps/aarch64/xilinx-zynqmp/tstzu3eg.yml | 3 ---
6 files changed, 23 deletions(-)
diff --git a/spec/build/bsps/aarch64/a53/tsta53.yml b/spec/build/bsps/aarch64/a53/tsta53.yml
index 6876d23f56..6af1b186a3 100644
--- a/spec/build/bsps/aarch64/a53/tsta53.yml
+++ b/spec/build/bsps/aarch64/a53/tsta53.yml
@@ -4,10 +4,6 @@ actions:
# expected to fail, don't compile these
minimum: exclude
- # don't compile due to toolchain issues
- spconfig01: exclude
- spmisc01: exclude
# tests that are passing intermittently
spcpucounter01: indeterminate
rtmonuse: indeterminate
diff --git a/spec/build/bsps/aarch64/a72/tsta72.yml b/spec/build/bsps/aarch64/a72/tsta72.yml
--- a/spec/build/bsps/aarch64/a72/tsta72.yml
+++ b/spec/build/bsps/aarch64/a72/tsta72.yml
minimum: exclude
- spmisc01: exclude
diff --git a/spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml b/spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml
index 8828185cd8..a02232b239 100644
--- a/spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml
+++ b/spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml
# expected to fail
minimum: exclude
- # don't compile due to toolchain issues, see RTEMS issue #4218
- spmisc01: exclude
build-type: option
copyrights:
- Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
diff --git a/spec/build/bsps/aarch64/xilinx-versal/tstvck190.yml b/spec/build/bsps/aarch64/xilinx-versal/tstvck190.yml
index 4f9a21e9d7..cbc1c7e381 100644
--- a/spec/build/bsps/aarch64/xilinx-versal/tstvck190.yml
+++ b/spec/build/bsps/aarch64/xilinx-versal/tstvck190.yml
# expected to produce a fatal-error when run
minimum: exclude
- spmisc01: exclude
build-type: option
copyrights:
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
index 80d338fda1..e0c1b9a137 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
# expected to fail
minimum: exclude
- spmisc01: exclude
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/tstzu3eg.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/tstzu3eg.yml
index 8bf646b1d4..6cd6dc0954 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/tstzu3eg.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/tstzu3eg.yml
@@ -4,9 +4,6 @@ actions:
minimum: exclude
- spmisc01: exclude
build-type: option
copyrights:
- Copyright (C) 2020 On-Line Applications Research (OAR)
2.30.2
