[PATCH 1/4] rtemsbsd: Clear bus DMA memory a byte at a time
chrisj at rtems.org chrisj at rtems.org
Wed Oct 20 03:16:32 UTC 2021
- memset may be optimized for performance and might work
  with device type memory. Clear a byte at a time.
 rtemsbsd/rtems/rtems-kernel-bus-dma.c | 9 +++++++--
 1 file changed, 7 insertions(+), 2 deletions(-)
diff --git a/rtemsbsd/rtems/rtems-kernel-bus-dma.c b/rtemsbsd/rtems/rtems-kernel-bus-dma.c
index 45c4287d..1d28f62c 100644
--- a/rtemsbsd/rtems/rtems-kernel-bus-dma.c
+++ b/rtemsbsd/rtems/rtems-kernel-bus-dma.c
@@ -9,7 +9,7 @@
- * Copyright (c) 2009-2012 embedded brains GmbH.
+ * Copyright (c) 2009-2012 embedded brains GmbH.
  * All rights reserved.
  *  embedded brains GmbH
@@ -258,7 +258,12 @@ bus_dmamem_alloc(bus_dma_tag_t dmat, void** vaddr, int flags,
 	(*mapp)->buffer_size = dmat->maxsize;
 	if ((flags & BUS_DMA_ZERO) != 0) {
-		memset(*vaddr, 0, dmat->maxsize);
+		unsigned char* mem = *vaddr;
+		int len = dmat->maxsize;
+		while (len-- > 0) {
+			bsp_bus_space_write_1(mem, 0);
+			mem++;
 	return (0);
2.19.1
