[PATCH 2/4] waf: Move the tools/BSP include path to be last
Kinsey Moore kinsey.moore at oarcorp.com
Wed Oct 20 13:41:48 UTC 2021
Thanks for this fix. It had been on my todo list for a while now.
Kinsey
On 10/19/2021 22:16, chrisj at rtems.org wrote:
> From: Chris Johns <chrisj at rtems.org>
> - This change lets you rebuild libbsd after it is installed
>   waf_libbsd.py | 29 +++++++++++++++++++++--------
>   1 file changed, 21 insertions(+), 8 deletions(-)
> diff --git a/waf_libbsd.py b/waf_libbsd.py
> index 97e6d6ee..0901537e 100644
> --- a/waf_libbsd.py
> +++ b/waf_libbsd.py
> @@ -2,7 +2,7 @@
>   """LibBSD build configuration to waf integration module.
> -# Copyright (c) 2015, 2020 Chris Johns <chrisj at rtems.org>. All rights reserved.
> +# Copyright (c) 2015, 2021 Chris Johns <chrisj at rtems.org>. All rights reserved.
>   # Copyright (c) 2009, 2015 embedded brains GmbH.  All rights reserved.
> @@ -62,6 +62,13 @@ def _add_flags_if_not_present(current_flags, addional_flags):
>           if flag not in current_flags:
>               current_flags.append(flag)
> +def _remove_bsp_include_path(bsp_include_path, current_flags):
> +    # this does not handle quted strings; maybe needed
> +    for bsp_path in bsp_include_path:
> +        if bsp_path in current_flags:
> +            current_flags = [flag for flag in current_flags if flag != bsp_path]
> +    return current_flags
>   # The waf builder for libbsd.
> @@ -190,6 +197,12 @@ class Builder(builder.ModuleManager):
>               _add_flags_if_not_present(conf.env.CFLAGS, section_flags)
>               _add_flags_if_not_present(conf.env.CXXFLAGS, section_flags)
>               _add_flags_if_not_present(conf.env.LINKFLAGS, ["-Wl,--gc-sections"])
> +            conf.env.CFLAGS = _remove_bsp_include_path(conf.env.IFLAGS,
> +                                                       conf.env.CFLAGS)
> +            conf.env.CXXFLAGS = _remove_bsp_include_path(conf.env.IFLAGS,
> +        conf.env.CXXFLAGS)
> +            conf.env.LINKFLAGS = _remove_bsp_include_path(conf.env.IFLAGS,
> +                                                          conf.env.LINKFLAGS)
>       def build(self, bld):
> @@ -236,7 +249,7 @@ class Builder(builder.ModuleManager):
>           inc_paths = sorted(include_paths)
>           inc_paths.remove('build')
>           inc_paths.remove('cpu')
> -        includes = {}
> +        includes = { 'bsp': [p[2:] for p in bld.env.IFLAGS] }
>           for inc in inc_paths:
>               includes[inc] = include_paths[inc]
>           # cpu include paths must be the first searched
> @@ -431,7 +444,7 @@ class Builder(builder.ModuleManager):
>               bld.objects(target='kvmsymbols',
>                           features='c',
>                           cflags=cflags,
> -                        includes=kvmsymbols_includes + includes['kernel'],
> +                        includes=kvmsymbols_includes + includes['kernel'] + includes['bsp'],
>                           source=kvmsymbols['files']['all']['default'][0])
>               libbsd_use += ["kvmsymbols"]
> @@ -486,7 +499,7 @@ class Builder(builder.ModuleManager):
>                       bld.objects(target='lex_%s' % (lex['sym']),
>                                   features='c',
>                                   cflags=cflags,
> -                                includes=lexIncludes + includes['user'],
> +                                includes=lexIncludes + includes['user'] + includes['bsp'],
>                                   defines=defines + lexDefines,
>                                   source=lex['file'][:-2] + '.c')
>                   libbsd_use += ['lex_%s' % (lex['sym'])]
> @@ -526,7 +539,7 @@ class Builder(builder.ModuleManager):
>                       bld.objects(target='yacc_%s' % (yaccSym),
>                                   features='c',
>                                   cflags=cflags,
> -                                includes=yaccIncludes + includes['user'],
> +                                includes=yaccIncludes + includes['user'] + includes['bsp'],
>                                   defines=defines + yaccDefines,
>                                   source=yaccFile[:-2] + '.c')
>                   libbsd_use += ['yacc_%s' % (yaccSym)]
> @@ -560,7 +573,7 @@ class Builder(builder.ModuleManager):
>                               cflags=cflags + bld_cflags,
>                               cxxflags=cxxflags,
>                               includes=sorted(build.get('includes', [])) +
> -                            includes[space],
> +                            includes[space] + includes['bsp'],
>                               defines=defines,
>                               source=bld_sources)
>                   libbsd_use += [target]
> @@ -580,7 +593,7 @@ class Builder(builder.ModuleManager):
>                     features='c cxx',
>                     cflags=cflags,
>                     cxxflags=cxxflags,
> -                  includes=includes['kernel'],
> +                  includes=includes['kernel'] + includes['bsp'],
>                     defines=defines,
>                     source=bld_sources,
>                     use=libbsd_use)
> @@ -657,7 +670,7 @@ class Builder(builder.ModuleManager):
>                   bld.program(target='%s.exe' % (testName),
>                               features='cprogram',
>                               cflags=cflags,
> -                            includes=includes['user'],
> +                            includes=includes['user'] + includes['bsp'],
>                               source=test_sources,
>                               use=['bsd'],
>                               lib=libs,
