[PATCH v2] spec/libdebugger: Only enable for supported architectures
chrisj at rtems.org
chrisj at rtems.org
Thu Oct 21 23:35:12 UTC 2021
Closes #4533
spec/build/cpukit/cpuopts.yml | 2 ++
spec/build/cpukit/libdebugger.yml | 2 +-
spec/build/cpukit/optlibdebugger.yml | 16 ++++++++++++++++
spec/build/testsuites/libtests/debugger01.yml | 4 +---
4 files changed, 20 insertions(+), 4 deletions(-)
create mode 100644 spec/build/cpukit/optlibdebugger.yml
diff --git a/spec/build/cpukit/cpuopts.yml b/spec/build/cpukit/cpuopts.yml
index 0a07f6d5e9..908c65d3b9 100644
--- a/spec/build/cpukit/cpuopts.yml
+++ b/spec/build/cpukit/cpuopts.yml
@@ -51,6 +51,8 @@ links:
uid: optprofiling
- role: build-dependency
uid: optsmp
+- role: build-dependency
+ uid: optlibdebugger
uid: optlibdl
diff --git a/spec/build/cpukit/libdebugger.yml b/spec/build/cpukit/libdebugger.yml
index f316cc18e8..5069571a76 100644
--- a/spec/build/cpukit/libdebugger.yml
+++ b/spec/build/cpukit/libdebugger.yml
@@ -5,7 +5,7 @@ copyrights:
- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
cppflags: []
cxxflags: []
-enabled-by: true
+enabled-by: BUILD_LIBDEBUGGER
includes: []
install: []
install-path: ${BSP_LIBDIR}
diff --git a/spec/build/cpukit/optlibdebugger.yml b/spec/build/cpukit/optlibdebugger.yml
new file mode 100644
index 0000000000..5c7df0e0c9
--- /dev/null
+++ b/spec/build/cpukit/optlibdebugger.yml
@@ -0,0 +1,16 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- set-value: true
+- env-enable: null
+build-type: option
+copyrights:
+- Copyright (C) 2021 Chris Johns (chrisj at rtems.org)
+default: null
+default-by-variant: []
+description: ''
+enabled-by:
+- arm
+- i386
+links: []
+name: BUILD_LIBDEBUGGER
+type: build
diff --git a/spec/build/testsuites/libtests/debugger01.yml b/spec/build/testsuites/libtests/debugger01.yml
index 720b643925..20c538bbb8 100644
--- a/spec/build/testsuites/libtests/debugger01.yml
+++ b/spec/build/testsuites/libtests/debugger01.yml
@@ -5,9 +5,7 @@ copyrights:
cppflags: []
cxxflags: []
-enabled-by:
-- arm
-- i386
features: c cprogram
includes: []
ldflags: []
2.19.1
