[PATCH v3 2/5] cpukit/aarch64: Add exception extensions support
    Kinsey Moore
    kinsey.moore at oarcorp.com
    Wed Oct 27 21:44:04 UTC 2021
This adds the calls and support functions necessary to add exception
extensions support to AArch64.
 .../cpu/aarch64/aarch64-exception-default.S   | 131 +++++---------
 .../cpu/aarch64/aarch64-exception-default.c   |  59 ++++++-
 .../cpu/aarch64/aarch64-exception-interrupt.S | 165 ++++++++++++++++++
 .../cpu/aarch64/include/rtems/score/cpu.h     |  17 ++
 spec/build/cpukit/optexceptionextensions.yml  |   1 +
 5 files changed, 289 insertions(+), 84 deletions(-)
diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-default.S b/cpukit/score/cpu/aarch64/aarch64-exception-default.S
index 2a4ddbcc61..c7c9d03465 100644
--- a/cpukit/score/cpu/aarch64/aarch64-exception-default.S
+++ b/cpukit/score/cpu/aarch64/aarch64-exception-default.S
@@ -72,7 +72,7 @@
  * * The exception returns to the previous execution state
-	.macro	JUMP_HANDLER_SHORT
+	.macro	JUMP_HANDLER
 /* Mask to use in BIC, lower 7 bits */
 	mov x0, #0x7f
 /* LR contains PC, mask off to the base of the current vector */
@@ -109,10 +109,6 @@
 	nop
 	nop
 	nop
-	.endm
-	JUMP_HANDLER_SHORT
 	nop
 	.endm
@@ -144,11 +140,48 @@ Vector_table_el3:
  * using SP0.
 curr_el_sp0_sync:
-	stp x0,	lr,	[sp, #-0x10]!	/* Push x0,lr on to the stack */
-	bl curr_el_sp0_sync_get_pc	/* Get current execution address */
-curr_el_sp0_sync_get_pc:		/* The current PC is now in LR */
-	JUMP_HANDLER
-	JUMP_TARGET_SP0
+	sub sp, sp, #AARCH64_EXCEPTION_FRAME_SIZE			/* reserve space for CEF */
+	str lr, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_LR_OFFSET]	/* shove lr into CEF */
+	bl .push_exception_context_start				/* bl to CEF store routine */
+/* Save original sp in x0 for .push_exception_context_finish */
+	add x0, sp, #AARCH64_EXCEPTION_FRAME_SIZE			/* save original sp */
+/* Push the remainder of the context */
+	bl .push_exception_context_finish
+/* get jump target and branch/link */
+	bl curr_el_sp0_sync_get_pc		/* Get current execution address */
+curr_el_sp0_sync_get_pc:			/* The current PC is now in LR */
+	mov x0, #0x7f				/* Mask to use in BIC, lower 7 bits */
+	bic x0,	lr,	x0			/* Mask LR to base of current vector */
+	ldr x1,	[x0,	#0x78]			/* Load target from last word in vector */
+	and lr, lr, #0x780			/* Mask off bits for vector number */
+	lsr lr, lr, #7				/* Shift the vector bits down */
+/* Store the vector */
+	str lr, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_VECTOR_OFFSET]
+	mov x0, sp
+	blr x1
+	b twiddle
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+/* Takes up the space of 2 instructions */
+#ifdef AARCH64_MULTILIB_ARCH_V8_ILP32
+	.word _AArch64_Exception_default
+	.word 0x0
+#else
+	.dword _AArch64_Exception_default
+#endif
 .balign 0x80
 /* The exception handler for IRQ exceptions from the current EL using SP0. */
 curr_el_sp0_irq:
@@ -204,13 +237,11 @@ curr_el_spx_sync_get_pc:			/* The current PC is now in LR */
 	mov x0, sp
 	blr x1
-/* bl to CEF restore routine (doesn't restore lr) */
-	bl .pop_exception_context
-	ldr lr, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_LR_OFFSET]	/* get lr from CEF */
-/* drop space reserved for CEF and clear exclusive */
-	add sp, sp, #AARCH64_EXCEPTION_FRAME_SIZE
-	msr spsel, #1				/* switch to thread stack */
-	eret					/* exception return */
+	b twiddle
+	nop
+	nop
+	nop
+	nop
 	nop
 	nop
 	nop
@@ -475,69 +506,3 @@ twiddle:
 	stp q30, q31, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1e0)]
 /* Done, return to exception handler */
 	ret
- * Apply the exception frame to the current register status, SP points to the EF
-.pop_exception_context:
-/* Pop daif and spsr */
-	ldp x2, x3, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_DAIF_OFFSET]
-/* Restore daif and spsr */
-	msr DAIF, x2
-	msr SPSR_EL1, x3
-/* Pop FAR and ESR */
-	ldp x2, x3, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_SYNDROME_OFFSET]
-/* Restore ESR and FAR */
-	msr ESR_EL1, x2
-	msr FAR_EL1, x3
-/* Pop fpcr and fpsr */
-	ldp x2, x3, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_FPSR_OFFSET]
-/* Restore fpcr and fpsr */
-	msr FPSR, x2
-	msr FPCR, x3
-/* Pop VFP registers */
-	ldp q0,  q1,  [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x000)]
-	ldp q2,  q3,  [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x020)]
-	ldp q4,  q5,  [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x040)]
-	ldp q6,  q7,  [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x060)]
-	ldp q8,  q9,  [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x080)]
-	ldp q10, q11, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0a0)]
-	ldp q12, q13, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0c0)]
-	ldp q14, q15, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0e0)]
-	ldp q16, q17, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x100)]
-	ldp q18, q19, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x120)]
-	ldp q20, q21, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x140)]
-	ldp q22, q23, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x160)]
-	ldp q24, q25, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x180)]
-	ldp q26, q27, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1a0)]
-	ldp q28, q29, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1c0)]
-	ldp q30, q31, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1e0)]
-/* Pop x0-x29(fp) */
-	ldp x2,  x3,  [sp, #0x10]
-	ldp x4,  x5,  [sp, #0x20]
-	ldp x6,  x7,  [sp, #0x30]
-	ldp x8,  x9,  [sp, #0x40]
-	ldp x10, x11, [sp, #0x50]
-	ldp x12, x13, [sp, #0x60]
-	ldp x14, x15, [sp, #0x70]
-	ldp x16, x17, [sp, #0x80]
-	ldp x18, x19, [sp, #0x90]
-	ldp x20, x21, [sp, #0xa0]
-	ldp x22, x23, [sp, #0xb0]
-	ldp x24, x25, [sp, #0xc0]
-	ldp x26, x27, [sp, #0xd0]
-	ldp x28, x29, [sp, #0xe0]
-/* Pop sp and ELR */
-	ldp x0, x1, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_SP_OFFSET]
-/* Restore thread SP */
-	msr spsel, #1
-	mov sp, x0
-	msr spsel, #0
-/* Restore exception LR */
-	msr ELR_EL1, x1
-	ldp x0,  x1,  [sp, #0x00]
-/* We must clear reservations to ensure consistency with atomic operations */
-	clrex
-	ret
diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-default.c b/cpukit/score/cpu/aarch64/aarch64-exception-default.c
index 2ebb3dee9f..aec93808d9 100644
--- a/cpukit/score/cpu/aarch64/aarch64-exception-default.c
+++ b/cpukit/score/cpu/aarch64/aarch64-exception-default.c
@@ -41,10 +41,67 @@
 #include "config.h"
 #endif
-#include <rtems/score/cpu.h>
 #include <rtems/fatal.h>
+#include <rtems/score/aarch64-system-registers.h>
+#include <rtems/score/cpu.h>
+#include <rtems/score/percpu.h>
 void _AArch64_Exception_default( CPU_Exception_frame *frame )
   rtems_fatal( RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) frame );
+void _CPU_Exception_disable_thread_dispatch( void )
+  Per_CPU_Control *cpu_self = _Per_CPU_Get();
+  /* Increment interrupt nest and thread dispatch disable level */
+  ++cpu_self->thread_dispatch_disable_level;
+  ++cpu_self->isr_nest_level;
+void _CPU_Exception_frame_copy(
+  CPU_Exception_frame *new_ef,
+  CPU_Exception_frame *old_ef
+  *new_ef = *old_ef;
+int _CPU_Exception_frame_get_signal( CPU_Exception_frame *ef )
+  uint64_t EC = AARCH64_ESR_EL1_EC_GET( ef->register_syndrome );
+  switch ( EC ) {
+    case 0x1:  /* WFI */
+    case 0x7:  /* SVE/SIMD/FP */
+    case 0xa:  /* LD64B/ST64B* */
+    case 0x18: /* MSR/MRS/system instruction */
+    case 0x19: /* SVE */
+    case 0x15: /* Supervisor call */
+    case 0x26: /* SP Alignment */
+    case 0x31: /* Breakpoint */
+    case 0x33: /* Step */
+    case 0x35: /* Watchpoint */
+    case 0x3c: /* Break Instruction */
+      return -1;
+    case 0x2c: /* FPU */
+      return SIGFPE;
+    case 0x21: /* Instruction Abort */
+    case 0x25: /* Data Abort */
+      return SIGSEGV;
+    default:
+      return SIGILL;
+void _CPU_Exception_frame_set_resume( CPU_Exception_frame *ef, void *address )
+  ef->register_pc = address;
+#define AARCH64_INSTRUCTION_SIZE 4
+void  _CPU_Exception_frame_set_resume_next_instruction( CPU_Exception_frame *ef )
+  ef->register_pc += AARCH64_INSTRUCTION_SIZE;
diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S b/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
index b206f5764b..4d87d3fae4 100644
--- a/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
+++ b/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
@@ -45,6 +45,8 @@
 .globl	_AArch64_Exception_interrupt_no_nest
 .globl	_AArch64_Exception_interrupt_nest
+.globl	_CPU_Exception_dispatch_and_resume
+.globl	_CPU_Exception_resume
   #ifdef RTEMS_SMP
@@ -324,3 +326,166 @@ Return to embedded exception vector code
 	pop_interrupt_context
 /* Return to vector for final cleanup */
 	ret
+ * This function is expected to resume execution using the CPU_Exception_frame
+ * provided in x0. This function  does not adhere to the AAPCS64 calling
+ * convention because all necessary state is contained within the exception
+ * frame.
+_CPU_Exception_resume:
+/* Reset stack pointer */
+	mov	sp, x0
+/* call CEF restore routine (doesn't restore lr) */
+	bl .pop_exception_context
+/* get lr from CEF */
+	ldr lr, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_LR_OFFSET]
+/* drop space reserved for CEF */
+	add sp, sp, #AARCH64_EXCEPTION_FRAME_SIZE
+/* switch to thread stack */
+	msr spsel, #1
+	eret
+ * This function is expected to undo dispatch disabling, perform dispatch, and
+ * resume execution using the CPU_Exception_frame provided in x0. This function
+ * does not adhere to the AAPCS64 calling convention because all necessary
+ * state is contained within the exception frame.
+_CPU_Exception_dispatch_and_resume:
+/* Get per-CPU control of current processor */
+	GET_SELF_CPU_CONTROL	SELF_CPU_CONTROL_GET_REG
+	mov	sp, x0
+/* Check dispatch disable and perform dispatch if necessary */
+/* Load some per-CPU variables */
+	ldr	w0, [SELF_CPU_CONTROL, #PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL]
+	ldrb	w1, [SELF_CPU_CONTROL, #PER_CPU_DISPATCH_NEEDED]
+	ldr	w2, [SELF_CPU_CONTROL, #PER_CPU_ISR_DISPATCH_DISABLE]
+	ldr	w3, [SELF_CPU_CONTROL, #PER_CPU_ISR_NEST_LEVEL]
+/* Decrement levels and determine thread dispatch state */
+	eor	w1, w1, w0
+	sub	w0, w0, #1
+	orr	w1, w1, w0
+	orr	w1, w1, w2
+	sub	w3, w3, #1
+/* Store thread dispatch disable and ISR nest levels */
+	str	w0, [SELF_CPU_CONTROL, #PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL]
+	str	w3, [SELF_CPU_CONTROL, #PER_CPU_ISR_NEST_LEVEL]
+/* store should_skip_thread_dispatch in x22 */
+	mov x22, x1
+ * It is now safe to assume that the source of the exception has been resolved.
+ * Copy the exception frame to the thread stack to be compatible with thread
+ * dispatch. This may arbitrarily clobber corruptible registers since all
+ * important state is contained in the exception frame.
+ * No need to save current LR since this will never return to the caller.
+	bl .move_exception_frame_and_switch_to_thread_stack
+ * Check thread dispatch necessary, ISR dispatch disable and thread dispatch
+ * disable level.
+	cmp     x22, #0
+	bne     .Lno_need_thread_dispatch_resume
+	bl .AArch64_Perform_Thread_Dispatch
+.Lno_need_thread_dispatch_resume:
+	eret
+/* Assumes sp currently points to the EF on the exception stack and SPSel is 0 */
+.move_exception_frame_and_switch_to_thread_stack:
+	mov x1, sp                                                      /* Set x1 to the current exception frame */
+	msr spsel, #1                                                   /* switch to thread stack */
+	ldr x0, [x1, #AARCH64_EXCEPTION_FRAME_REGISTER_SP_OFFSET]       /* Get thread SP from exception frame since it may have been updated */
+	mov sp, x0
+	mov x0, sp                                                      /* Set x0 to the new exception frame */
+	mov x20, lr                                                     /* Save LR */
+	bl _CPU_Exception_frame_copy                                    /* Copy exception frame to reserved thread stack space */
+	mov lr, x20                                                     /* Restore LR */
+	msr spsel, #0							/* switch to exception stack */
+	add sp, sp, #AARCH64_EXCEPTION_FRAME_SIZE			/* release space for CEF on exception stack */
+	ret
+ * Apply the exception frame to the current register status, SP points to the EF
+.pop_exception_context:
+/* Pop daif and spsr */
+	ldp x2, x3, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_DAIF_OFFSET]
+/* Restore daif and spsr */
+	msr DAIF, x2
+	msr SPSR_EL1, x3
+/* Pop FAR and ESR */
+	ldp x2, x3, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_SYNDROME_OFFSET]
+/* Restore ESR and FAR */
+	msr ESR_EL1, x2
+	msr FAR_EL1, x3
+/* Pop fpcr and fpsr */
+	ldp x2, x3, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_FPSR_OFFSET]
+/* Restore fpcr and fpsr */
+	msr FPSR, x2
+	msr FPCR, x3
+/* Pop VFP registers */
+	ldp q0,  q1,  [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x000)]
+	ldp q2,  q3,  [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x020)]
+	ldp q4,  q5,  [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x040)]
+	ldp q6,  q7,  [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x060)]
+	ldp q8,  q9,  [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x080)]
+	ldp q10, q11, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0a0)]
+	ldp q12, q13, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0c0)]
+	ldp q14, q15, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0e0)]
+	ldp q16, q17, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x100)]
+	ldp q18, q19, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x120)]
+	ldp q20, q21, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x140)]
+	ldp q22, q23, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x160)]
+	ldp q24, q25, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x180)]
+	ldp q26, q27, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1a0)]
+	ldp q28, q29, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1c0)]
+	ldp q30, q31, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1e0)]
+/* Pop x0-x29(fp) */
+	ldp x2,  x3,  [sp, #0x10]
+	ldp x4,  x5,  [sp, #0x20]
+	ldp x6,  x7,  [sp, #0x30]
+	ldp x8,  x9,  [sp, #0x40]
+	ldp x10, x11, [sp, #0x50]
+	ldp x12, x13, [sp, #0x60]
+	ldp x14, x15, [sp, #0x70]
+	ldp x16, x17, [sp, #0x80]
+	ldp x18, x19, [sp, #0x90]
+	ldp x20, x21, [sp, #0xa0]
+	ldp x22, x23, [sp, #0xb0]
+	ldp x24, x25, [sp, #0xc0]
+	ldp x26, x27, [sp, #0xd0]
+	ldp x28, x29, [sp, #0xe0]
+/* Pop ELR, SP already popped */
+	ldr x1, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_SP_OFFSET + 0x8)]
+/* Restore exception LR */
+	msr ELR_EL1, x1
+	ldp x0,  x1,  [sp, #0x00]
+/* We must clear reservations to ensure consistency with atomic operations */
+	clrex
+	ret
diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
index ae7e2bdcba..df6ec0f34e 100644
--- a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
@@ -524,6 +524,23 @@ typedef struct {
 void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
+RTEMS_NO_RETURN void _CPU_Exception_resume( CPU_Exception_frame *ef );
+RTEMS_NO_RETURN void _CPU_Exception_dispatch_and_resume( CPU_Exception_frame *ef );
+void _CPU_Exception_disable_thread_dispatch( void );
+int _CPU_Exception_frame_get_signal( CPU_Exception_frame *ef );
+void _CPU_Exception_frame_set_resume( CPU_Exception_frame *ef, void *address );
+void _CPU_Exception_frame_set_resume_next_instruction( CPU_Exception_frame *ef );
 void _AArch64_Exception_default( CPU_Exception_frame *frame );
 /** Type that can store a 32-bit integer or a pointer. */
diff --git a/spec/build/cpukit/optexceptionextensions.yml b/spec/build/cpukit/optexceptionextensions.yml
index 1bc6d8686f..67c787e7dd 100644
--- a/spec/build/cpukit/optexceptionextensions.yml
+++ b/spec/build/cpukit/optexceptionextensions.yml
@@ -13,6 +13,7 @@ description: |
   Enable the RTEMS Exception Extensions for manipulating and acting on exception
   frames.
 enabled-by:
+- aarch64
 links: []
 type: build
2.30.2
