[PATCH v3 4/5] cpukit: Add signal mapping support
Kinsey Moore kinsey.moore at oarcorp.com
Wed Oct 27 21:44:06 UTC 2021
This adds a confdef option allowing an application to request mapping
machine exceptions to POSIX signals. This is required for some languages
such as Ada.
 cpukit/doxygen/appl-config.h               | 23 +++++++
 cpukit/include/rtems/confdefs/extensions.h |  7 ++
 cpukit/include/rtems/score/exception.h     | 71 ++++++++++++++++++++
 cpukit/score/src/exceptionmapping.c        | 77 ++++++++++++++++++++++
 spec/build/cpukit/librtemscpu.yml          |  3 +
 spec/build/cpukit/objexceptionmapping.yml  | 15 +++++
 6 files changed, 196 insertions(+)
 create mode 100644 cpukit/include/rtems/score/exception.h
 create mode 100644 cpukit/score/src/exceptionmapping.c
 create mode 100644 spec/build/cpukit/objexceptionmapping.yml
diff --git a/cpukit/doxygen/appl-config.h b/cpukit/doxygen/appl-config.h
index c0e5b0b717..4735af8766 100644
--- a/cpukit/doxygen/appl-config.h
+++ b/cpukit/doxygen/appl-config.h
@@ -1773,6 +1773,29 @@
 #define CONFIGURE_ATA_DRIVER_TASK_PRIORITY
+/* Generated from spec:/acfg/if/exception-to-signal-mapping */
+ * @brief This configuration option is a boolean feature define.
+ * In case this configuration option is defined, then the machine exception to
+ * POSIX signal mapping is configured during system initialization.
+ * @par Default Configuration
+ * If this configuration option is undefined, then the described feature is not
+ * enabled.
+ * @par Notes
+ * @parblock
+ * This device driver is responsible for setting up a mapping from machine
+ * exceptions to POSIX signals so that applications may consume them and alter
+ * task execution as necessary.
+ * This is especially useful for applications written in Ada or C++.
+ * @endparblock
+#define CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING
 /* Generated from spec:/acfg/if/max-drivers */
diff --git a/cpukit/include/rtems/confdefs/extensions.h b/cpukit/include/rtems/confdefs/extensions.h
index 83d690d50a..6492407934 100644
--- a/cpukit/include/rtems/confdefs/extensions.h
+++ b/cpukit/include/rtems/confdefs/extensions.h
@@ -93,6 +93,10 @@
   #include <rtems/stackchk.h>
 #endif
+#ifdef CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING
+  #include <rtems/score/exception.h>
+#endif
 #ifdef __cplusplus
 extern "C" {
 #endif
@@ -103,6 +107,9 @@ extern "C" {
   || defined(CONFIGURE_INITIAL_EXTENSIONS) \
   || defined(BSP_INITIAL_EXTENSION)
   const User_extensions_Table _User_extensions_Initial_extensions[] = {
+    #ifdef CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING
+      { .fatal = _Exception_Raise_signal },
+    #endif
     #ifdef _CONFIGURE_RECORD_NEED_EXTENSION
         #ifdef CONFIGURE_RECORD_EXTENSIONS_ENABLED
diff --git a/cpukit/include/rtems/score/exception.h b/cpukit/include/rtems/score/exception.h
new file mode 100644
index 0000000000..979a5aae7e
--- /dev/null
+++ b/cpukit/include/rtems/score/exception.h
@@ -0,0 +1,71 @@
+ * @file
+ * @ingroup RTEMSScoreException
+ * @brief This header file provides the interfaces for mapping
+ *   exceptions to signsls.
+ * Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
+ * are met:
+#ifndef _RTEMS_EXCEPTION_H
+#define _RTEMS_EXCEPTION_H
+#include <rtems/fatal.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @defgroup RTEMSScoreException Exception Mapping Interfaces
+ * @brief This group contains the interfaces for mapping machine exceptions to
+ *   signals using the fatal error handler.
+ * @brief Handle an exception frame for the purpose of mapping signals
+ * See CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING documentation in the
+ * "RTEMS Classic API Guide".
+void _Exception_Raise_signal(
+  Internal_errors_Source source,
+  bool                   always_set_to_false,
+  Internal_errors_t      code
+#ifdef __cplusplus
+#endif
+#endif /* _RTEMS_EXCEPTION_H */
diff --git a/cpukit/score/src/exceptionmapping.c b/cpukit/score/src/exceptionmapping.c
index 0000000000..e714935bf6
--- /dev/null
+++ b/cpukit/score/src/exceptionmapping.c
@@ -0,0 +1,77 @@
+ * @file
+ * @ingroup RTEMSScoreExceptionMapping
+ * @brief AArch64 machine exception to POSIX signal mapping.
+ * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
+ * are met:
+#include <pthread.h>
+#include <signal.h>
+#include <rtems/score/exception.h>
+ * Exception handler. Map the exception class to SIGFPE, SIGSEGV
+ * or SIGILL for Ada or other runtimes.
+  CPU_Exception_frame *ef;
+  int raise_signal;
+  if ( source != RTEMS_FATAL_SOURCE_EXCEPTION ) {
+    return;
+  ef = (rtems_exception_frame *) code;
+  raise_signal = _CPU_Exception_frame_get_signal( ef );
+  if ( raise_signal < 0 ) {
+    return;
+  /* Disable thread dispatch */
+  _CPU_Exception_disable_thread_dispatch();
+   * While it would be preferable, the call to raise() cannot be deferred to a
+   * post-switch action because it attempts to lock the post-switch action list
+   * to add another item and the list is already locked for iteration. This
+   * causes a deadlock.
+  raise( raise_signal );
+  /* Perform dispatch and resume execution */
+  _CPU_Exception_dispatch_and_resume( ef );
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 2017ab058c..2b25b5dcce 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -343,6 +343,7 @@ install:
   - cpukit/include/rtems/score/coresem.h
   - cpukit/include/rtems/score/coresemimpl.h
   - cpukit/include/rtems/score/cpustdatomic.h
+  - cpukit/include/rtems/score/exception.h
   - cpukit/include/rtems/score/freechain.h
   - cpukit/include/rtems/score/hash.h
   - cpukit/include/rtems/score/heap.h
@@ -497,6 +498,8 @@ links:
   uid: objdl
 - role: build-dependency
   uid: objdrvmgr
+- role: build-dependency
+  uid: objexceptionmapping
   uid: objgnat
diff --git a/spec/build/cpukit/objexceptionmapping.yml b/spec/build/cpukit/objexceptionmapping.yml
index 0000000000..40f559c73f
--- /dev/null
+++ b/spec/build/cpukit/objexceptionmapping.yml
@@ -0,0 +1,15 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: objects
+cflags: []
+copyrights:
+- Copyright (C) 2021 On-Line Applications Research (OAR)
+cppflags: []
+cxxflags: []
+enabled-by:
+- RTEMS_EXCEPTION_EXTENSIONS
+includes: []
+install: []
+links: []
+source:
+- cpukit/score/src/exceptionmapping.c
+type: build
2.30.2
