[PATCH v3 1/5] cpukit: Add exception extensions
Sebastian Huber
Thu Oct 28 06:00:33 UTC 2021
On 27/10/2021 23:44, Kinsey Moore wrote:
> This adds the set of functions necessary to allow more generic handling
> of machine exceptions. This initial patch offers the ability to
> manipulate a CPU_Exception_frame and resume execution using that
> exception information with or without thread dispatch. These functions
> are gated behind the RTEMS_EXCEPTION_EXTENSIONS configuration option.
> .../cpu/no_cpu/include/rtems/score/cpu.h | 78 +++++++++++++++++++
> spec/build/cpukit/cpuopts.yml | 2 +
> spec/build/cpukit/optexceptionextensions.yml | 18 +++++
> 3 files changed, 98 insertions(+)
> create mode 100644 spec/build/cpukit/optexceptionextensions.yml
> diff --git a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
> index e224a5e56e..f9afbe7243 100644
> --- a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
> @@ -1142,6 +1142,84 @@ typedef struct {
> void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
> +#ifdef RTEMS_EXCEPTION_EXTENSIONS
What is the purpose of this option? Who controls it. Who is supposed to
use it?
The way this feature is implemented, an application which doesn't use it
will not get it linked in. So, from my point of view we don't need an
API visible option.
> + * @brief Resumes normal execution using the provided exception frame.
> + * This routine helps to avoid dead code in the exception handler epilogue and
> + * does not return. This routine may assume that the provided pointer is valid
> + * for resetting the exception stack.
> + * @param exception_frame The CPU_Exception_frame describing the machine
> + * exception.
> + RTEMS_NO_RETURN void _CPU_Exception_resume( CPU_Exception_frame *ef );
The parameter name in the function signature and the documentation
should match. Also abbreviations are normally not used in the score.
Maybe just use "frame".
> + * @brief Performs thread dispatch and resumes normal execution.
> + * for resetting the exception stack. This function is expected to decrement
> + * the ISR nest level and thread dispatch disable level in the Per_CPU_Control
> + * structure.
> + * exception.
> + RTEMS_NO_RETURN void _CPU_Exception_dispatch_and_resume( CPU_Exception_frame *ef );
> + * @brief Disables thread dispatch.
> + * This must be called before calling _CPU_Exception_dispatch_and_resume
> + * since that function is expected to reduce the levels incremented below.
> + * exception.
> + void _CPU_Exception_disable_thread_dispatch( void );
> + * @brief Retrieves the generic exception class of the machine exception.
> + * exception.
> + * @return The signal associated with the CPU_Exception_frame.
> + int _CPU_Exception_frame_get_signal( CPU_Exception_frame *ef );
> + * @brief Sets the execution address of the exception frame.
> + * exception.
> + void _CPU_Exception_frame_set_resume( CPU_Exception_frame *ef, void *address );
> + * @brief Sets the execution address of the exception frame to the next
> + * instruction.
> + * exception.
> + void _CPU_Exception_frame_set_resume_next_instruction( CPU_Exception_frame *ef );
Mabye name it _CPU_Exception_frame_make_resume_next_instruction() since
there is no parameter with a value.
> + * @brief Copies data to the new exception frame from the old exception frame.
> + * @param old_ef The existing CPU_Exception_frame describing the machine
> + * exception.
> + * @param new_ef The new CPU_Exception_frame describing the machine
> + * exception.
> + void _CPU_Exception_frame_copy(
> + CPU_Exception_frame *new_ef,
> + CPU_Exception_frame *old_ef
If not used, then please remove it.
> +#endif
> * @defgroup RTEMSScoreCPUExampleCPUEndian CPUEndian
> diff --git a/spec/build/cpukit/cpuopts.yml b/spec/build/cpukit/cpuopts.yml
> index 908c65d3b9..301d49ccea 100644
> --- a/spec/build/cpukit/cpuopts.yml
> +++ b/spec/build/cpukit/cpuopts.yml
> @@ -39,6 +39,8 @@ links:
> uid: optdebug
> - role: build-dependency
> uid: optdrvmgr
> +- role: build-dependency
> + uid: optexceptionextensions
> uid: optmpci
> diff --git a/spec/build/cpukit/optexceptionextensions.yml b/spec/build/cpukit/optexceptionextensions.yml
> new file mode 100644
> index 0000000000..1bc6d8686f
> --- /dev/null
> +++ b/spec/build/cpukit/optexceptionextensions.yml
> @@ -0,0 +1,18 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +actions:
> +- get-boolean: null
> +- env-enable: null
> +- define-condition: null
> +build-type: option
> +copyrights:
> +- Copyright (C) 2021 On-Line Applications Research (OAR)
> +default: true
> +default-by-family: []
> +default-by-variant: []
> +description: |
> + Enable the RTEMS Exception Extensions for manipulating and acting on exception
> + frames.
> +enabled-by:
> +links: []
> +name: RTEMS_EXCEPTION_EXTENSIONS
> +type: build
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
