[PATCH rtems-tools] rtems-bsp-builder: Fix mail support
Alex White alex.white at oarcorp.com
Thu Oct 28 20:01:14 UTC 2021
This fixes a problem with mailer options support that occurred because
check.py uses argparse.ArgumentParser instead of tester.rt.options.
 rtemstoolkit/mailer.py |  2 +-
 tester/rt/check.py     | 17 ++++++++++++++++-
 2 files changed, 17 insertions(+), 2 deletions(-)
diff --git a/rtemstoolkit/mailer.py b/rtemstoolkit/mailer.py
index 085a2ce..32cbc23 100644
--- a/rtemstoolkit/mailer.py
+++ b/rtemstoolkit/mailer.py
@@ -70,7 +70,7 @@ class mail:
     def __init__(self, opts):
         self.opts = opts
         self.gitconfig_lines = None
-        if opts.find_arg('--use-gitconfig') is not None:
+        if self._get_arg('--use-gitconfig'):
             # Read the output of `git config --list` instead of reading the
             # .gitconfig file directly because Python 2 ConfigParser does not
             # accept tabs at the beginning of lines.
diff --git a/tester/rt/check.py b/tester/rt/check.py
index c01c25d..ec92e7e 100755
--- a/tester/rt/check.py
+++ b/tester/rt/check.py
@@ -105,7 +105,22 @@ def title():
     return 'RTEMS Tools Project - RTEMS Kernel BSP Builder, %s' % (version.string())
 def command_line():
-    return wrap(('command: ', ' '.join(sys.argv)), lineend = '\\')
+    # Filter potentially sensitive mail options out.
+    filtered_args = [
+        arg for arg in sys.argv
+        if all(
+            smtp_opt not in arg
+            for smtp_opt in [
+                '--smtp-host',
+                '--mail-to',
+                '--mail-from',
+                '--smtp-user',
+                '--smtp-password',
+                '--smtp-port'
+    return wrap(('command: ', ' '.join(filtered_args)), lineend = '\\')
 def jobs_option_parse(jobs_option):
     try:
2.27.0
